3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Deflate a tire (Sounds Dumb, don't it?)
Deflate a tire (Sounds Dumb, don\
Gotten stuck in mud or snow before? If you have and realized that (usually) if you let out some of your tires' air, you can get out due to the increased surface. This is what 4x4's will most of the time do if there's no one around to winch them out and there's nothing to attach their winch to.
If you have done this (let air out), then you'd realize how long it usually takes to get down to the psi you want. This is especially no fun in the winter time. Sitting outside in the freezing cold, while cars pass without stopping to ask if you need help, letting the air (slowly) out of your tires to better your chances at getting free.
Well no more shall you have to do this. Now if you follow these instructions, you can easily switch caps and sit in your warm car while your tires deflate (time it around 2 or so minutes, depends on the size you make these and your tires).
These can also be used for "pranks", but I'm not here to say you should use these for such things (although the pictures kind of gives away what I made them for, but never got around to using them).
Step 1Yellow Peas aren't just meant for eating...
Yellow Peas aren\
Sorry, no actual pictures cause I made these a long time ago and never took any.
But I did make these instructable guideline photos when I made them and just found them recently.
We'll start out with the fast (both to make and to deflate) way.
Materials needed:
Yellow Pea
Super glue
Paper clip
Tire valve cap (aka Tire stem cap)
Scissors
Steps (just as the picture says):
1. Cut yellow pea in half
2. Use super glue on the half pea and push into the bottom of the valve cap
3. Let it dry
4. Switch caps on desired vehicle when needed.
21 comments
Nov 28, 2010. 4:41 PMbobbyderf123 says:
I did something similar to this recently, except I intended to use it as a prank, and it works much better in my opinion: I took the cap and drilled a small hole in the top and threaded a small screw(the type you would find on a plastic toy, I have a hole bag full) and then drilled another hole next to it (on the corner of the cap) so it has a place for the air to escape from.
May 14, 2009. 1:04 PMDeb4FlatTires says:
Great prank. ;) Deb
Mar 22, 2009. 11:00 AMmattyts says:
poke the little needle with a screwdriver or something and that should work
Oct 25, 2007. 4:05 PMX_D_3_M_1 says:
muahahahaha keep these in ur ninja army arsenal!lol
Oct 22, 2007. 2:16 AMLokisgodhi says:
Or you can just go to an automotive store and get a schrader valve core repair tool. You can get a nifty 4 way one that has a retapping tool for the inner and outer threads as well as a internal bore reamer.
Tires deflate much faster with the core removed.
Also I recommend replacing the core every once in a while.
http://www.amazon.com/s?ie=UTF8&search-alias=automotive&field-keywords=tire%20valve%20tools&page=1
http://en.wikipedia.org/wiki/Schrader_valve
Sep 30, 2006. 4:32 PMzachninme says:
There are actually a couple beaches where there are places to inflate your tires at the exit, so you deflate them to drive on the beach, then re-inflate them later.
Sep 6, 2006. 11:07 PMcokebottle tuque says:
traditionally you just take the tire cap off put a bb in it then put the cap back on.
Sep 6, 2006. 3:55 PM0.775volts says:
Car tires have the same style (schrader) valve, I had to remove the valve stem when i was using tire slime. you can also remove the central valve when you're re-mounting tires, the higher airflow makes it easier to mount the tire (I've done this with my spare a few times). and if you pull the valve, a tire will deflate QUICKLY. also they have to replace the valve stem to fill the tire, resulting in a longer delay... hypothetically speaking of course.
Sep 6, 2006. 12:36 PMTabLeft says:
Not positive about car tires but atleast for bike tires the inner workings of a valve stem just screw out wich is very easy and fast to do and allowes for fast deflation. they sell a special tool for this but you can just use a small tube with a notch cut in the end...
Sep 6, 2006. 6:44 AMTetranitrate says:
You know they sell these already made right,
http://offroadrecovery.com/c=fcsOAUGA7wHplzPAI3tBtvyBu/product/QD000, I first saw them when I was watching a prank show about how a bunch of kids tried to get the day off from school, so they went to the school bus depot and put them on the bus tires.
Sep 6, 2006. 4:01 AMdarkmotion says:
LOL what if you dont have peas...
Sep 6, 2006. 3:11 AMmtxe says:
sorry you don't have to deflate the tires but for mud sand rocks snow ex. it is recommended, however; we have tire made for such i do like your deflator it might work faster if you make a slot for air to escape(keeping in mind ive yet to makeone)
Sep 5, 2006. 9:51 PMmtxe says:
"This is what 4x4's will most of the time do if there's no one around to winch them out and there's nothing to attach their winch to"
you deflate your tires before you start
but good instructable
http://tacomaterritory.com/wiki/index.php/Tire_Deflators
Sep 5, 2006. 6:32 PMBeanwaur says:
usually the caps are pointed so you can just flip them over and use the pointy end to deflate the tire
Sep 5, 2006. 6:47 PMNeodudeman says:
lol. what an odd idea. it's interesting!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:FrenchCrawler
