3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dell Laptop WI-FI High Gain Antenna Mod, Increase Internal Network Cards Range and Signal !!!
Hello, This is my first instructable. Today Im going to sho you how to significantly increase the range and signal power of your laptop for about 15$. I have a Dell E1505 but this can be easily adapted to other brands of laptops. Its very Easy and quick mod but you must be very careful not to hurt your laptop... cuz that would suck, and im not buying ya another one. So Here we go !
Specs on laptop are:
Dell - E1505 - 2.0ghz - 2gb - 100gb - Ati x1400 - 1680x1050 tbhg - 9 cell - Dell Wireless 1500 Draft 802.11n Wireless Mini-Card
Step 1Things You Will Need
Things you need :
U.FL male to RP-SMA Pigtail Cable ( make to get RP-SMA Not SMA )
2.4GHz 10 dBi Gain Wireless WIFI Antenna ( any antenna will do )
Flat # 2 screew driver
Philips #2 screw driver
Small plyers
Needle nose plyers
Dremel with a strait cutting bit ( you could use a drill but dont push to hard )
Optional -1 Tool stealing always getin in the way lovable ferret :)
Link to cable and antenna I used from Ebay @ $10 - $15
http://tiny.cc/antenna
http://tiny.cc/cable183
55 comments
1-40 of 55next »
Sep 21, 2011. 12:39 AMeks01 says:
Is this possible to be put on mobile phones for Signal Boosting? I will be needing one when I go to remoted areas. Thank you.
Mar 16, 2011. 6:41 AMekral says:
i have this same laptop an i buil it to wifi mod
this is the picture
http://i.imgur.com/jdL0p.jpg
Dec 24, 2010. 12:47 AMsuperMacaroni says:
"VIRUS" what a awesome name for a network.
Aug 9, 2010. 1:38 AMrmonge says:
How do you supply energy to the amplifier through USB cable?
Jul 16, 2010. 2:05 PMnjedmonds says:
What does the end of the antenna look like?. I found a bunch on ebay that look like it but I need to know if the RP-SMA connector will fit in the end of it. Can you take a pic or something. Thanks
May 3, 2008. 8:33 PMD33ZZ says:
HI interested indeed of your usb wifi amp so it doesnt come already usb? but yes instructions would be great.
May 21, 2010. 4:38 AMgrimgroper says:
how much does this effect ur battery life? if it drains it quickly you might wanna look at this mod as well...
www.instructables.com/id/Increase-the-capacity-runtime-of-your-laptop-bat/
also would 2 antennas be beneficial? like the routers that have 2?
Feb 10, 2010. 5:15 PMTopcat2021 says:
That is a great modification that you have done. It was the inspiration for performing a similar mod to a dell inspiron 5150. The antenna mod works great.
I ordered a 1 watt broadband amp to use with the laptop and it also works great but I'm wondering about the specs on the amp that you used as the wall adapter is 6vdc @ 2000 ma, this power requirement far exceeds usb power. Can the amp be used at lower power? Right now I'm thinking about making an external battery pack with a charger for portability.
Wish me luck and again great work
Dan
Jul 17, 2008. 8:28 PMjabra says:
I dont have any background in elec and comp field at all...I would need more help from you guys please tell me exactly model# of the amp you were using xxgemini so far I found one on ebay # 280246755001 Not so sure if this is the one you used. I wish we could have some pics from you very soon. Just wanna build an amp for my dell inspiron too. Thanks!
May 21, 2010. 4:33 AMgrimgroper says:
 great instructable, iv always wanted to know if this was possible
this is me expressing my interest for the amplifier mod looks great!!
May 19, 2010. 1:59 PMcj082108 says:
PLZ DO AN INSTRUCTABLE FOR THIS TOO! UR FIRST ONE WAS GREAT! THANK YOU! I would totally appreciate it if you could email me cj082108@live.com when you have an instructable with a link to the page. thanks
cj
Feb 6, 2010. 11:05 PMUser1 says:
I would be curious as to the amp you used for this.  Link or model number?  Nice job on putting your instructable together btw.
Dec 20, 2009. 3:31 PMbiloxigrant says:
I successfully completed the mod on my Compaq Presario.  However, I received no increase in signal compared to the factory setup.  At least now I have an external point to possibly hook up an amplifier.
Oct 6, 2009. 8:43 PMDracoGT says:
I have a question, can you remove this antenna and still get reception? if so, is it better or equal to the original built in antenna? Thanks for the help, Jeff
Sep 28, 2009. 10:31 AMOroka says:
I added a U.FL jack to my Inspiron 1720. Drill one hole, plug it into the wireless card, reassemble the computer. Tada. I am quite interested in your wifi amplifier though!
Sep 26, 2009. 4:15 AMtrt125 says:
I have a d link airplus DWL-630 and it has no places to plug in an antenna, Would an antenna even work in conjunction with the card by plugging it into a usb port, if so what kind. What else could I do please help
Sep 19, 2009. 7:50 PMp0g068 says:
dude yus a bad a. ss thank you for the Instructable ( got me some tools and a antenna)
Sep 11, 2009. 10:59 AMBobTec says:
Just a thought, why hack the amp power plug. might be easier to take the male plug off the power supply and put it at the end of the usb cable you use. Think?
Dec 5, 2008. 7:12 PMbillb says:
I have a Mac Mini and the WiFi reception is very poor. I opened it up and found the WiFi card. It had two connectors for antennas. One of the connectors was used by the Mac and it used the horizontal metal top of the Mac as its antenna (it doesn't work well). I wanted to add a second antenna of high gain so I could use my home router located in another room. The problem is,no one I spoke to in electronics shops that sold antennas could identify the little connectors used by the WiFi card. Your instructable identified it as a "U.FL Connector". Where did you get the MALE U.FL CONNECTOR, and the super thin shielded coaxial cable. And lastly how did you connect it all together using the Reverse Polarity-SMA connector. Thanks in advance for doing all of the heavy lifting and making my (web surfing) life easier.
Sep 8, 2009. 4:33 PMsakinsRFconnector says:
A good source for U.FL to RP-SMA pigtails:
http://www.rfmall.com
Dec 6, 2008. 11:27 AMbillb says:
Thanks for your super quick response. You've helped more than you could know. I'll have to get the camera out and make an instructable when I drill into the Mac Mini. Thanks again.
Sep 7, 2009. 8:35 PMReCreate says:
Ok, Maybe you overdid it a little in the last step >_< Brilliant, I have a similar laptop, i may do that something ;)
Sep 3, 2009. 11:48 AMTobiastdog says:
who makes the amp and about how much should I expect to pay?
Aug 19, 2009. 11:18 AMsp3a12uk says:
Hey Xxgemini thanks for the guide. I followed in your steps and gave you credit. Thank you again.
http://veggietorta.blogspot.com/
Aug 7, 2009. 8:25 AMjeuno says:
Who is the manufacturer of your amplifier?
Oct 4, 2008. 4:52 PMRatfinkracing says:
Very neat how do those USB antenna's work? i understand there's power but how does it draw in signal? through the data side of the usb?
Jul 3, 2009. 12:20 PMellisgeek says:
um the usb is for power
Aug 7, 2009. 8:23 AMjeuno says:
There are some usb devices that claim to extend the signal. I think that is what he is talking about. Not the particular amps power source.
Jul 30, 2009. 1:05 PMmyckro says:
more than a comment a question... how far does it really work, cuz my house is only like 400m from school and I wanted to know id I could use something like this... of course I would have to setup an aces point on the roof... would it work?
Jul 5, 2009. 2:55 AMthrobscottle says:
It would be interesting to see if this can be made using a mc type connector rather than the rp-sma type - I imagine it would be neater. The reason I mention it is because there are more mc to n type pigtails out there for connecting to the home made can-antenna I haven't made yet.... (I'm just doing my research at the moment :-) )
May 10, 2009. 9:30 AMadan.e90 says:
you are the maaaaaaaaaaaaaaaaaaaan
Apr 26, 2009. 3:22 PMnevarDeath says:
This is wonderful! I'm putting this dell 1390 card in my Acer Aspire One and wasn't sure what connectors and stuff I needed for the external antenna. Thank you so much!
Apr 13, 2009. 8:32 PMedwardbuck says:
Hello, I read this several months ago, but I have never been able to get this mod to work. I thought maybe I had a bad antenna or cable, so I purchased another of each, but still no luck. I have tried two different high gain antennas and two different U.FL to RP-SMA cables, but I don't get any better signal than with my builtin antenna. Any ideas on what I'm doing wrong? I have a Dell Vostro 1700 with Dell 1390 WLAN card. If I disconnect the high-gain antenna from the pigtail, I get no signal, so it appears that it is making connection, but if I get one bar with my internal antenna, I still only get one bar with the high-gain antenna. Thanks.
Sep 25, 2008. 9:40 PMFullyInvolvedScientist says:
Great Instructable right down to the ferret! I have a dell XPS and am not sure where it could come out on the side. I'll have to crack open and look. Does anyone out there know where to get laptop internal diagrams? Once again great Instructable!
Apr 8, 2009. 11:38 AMTytanium says:
I know you posted awhile ago but I usually go to http://www.eserviceinfo.com for manuals/diagrams.. Give that a try it may help.
Mar 10, 2009. 9:18 PMnull_x86 says:
can you post a link to where the amp is from?
Apr 5, 2009. 12:25 PMGradius says:
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:xxgemini
