Damage typically occurs where the lead exits the power adapter housing around the plastic strain relief caused by repeated stress from acute bending or pulling of the cable. The outer plastic insulation breaks exposing the braided wire strands of the ground (-) wire and very often these strands fray and break resulting in disruption of current flow.
The inner live (+) wire is often broken inside the insulating sheath indicated by a knot like kink.
What you need:
Pocket knife
Mallet or hammer
Plastic pry tool with chisel shaped end
Cable connector
Electrical insulating tape
Remove these ads by
Signing UpStep 1
On HP and Dell adapters there is a narrow channel between the housings where the blade
can sit so limiting collateral damage to the casing surface.
After repeated tapping, varying the amount of force as necessary the casing halves wiil begin to separate. Repeat this process on the opposte long side of the housing.
The casing ends can be separated by tapping the plastic pry tool into the corner gaps
made previously. The tool itself can be made from any unbreakable plastic about 2mm thick (in this example coathanger plastic).
I just bought the cable tip for my HP after my Bird Cockatoo chewed it while I was out .
Thank you again.
