loading
Step 10: Fitting the electronics
This is straightforward, just screw everything to the bottom of the base panel! Stick double sided tape to the top of the power supply and tie it down, using angle brackets and tie rips. The tape will stop the unit from moving sideways. Don't forget to fit guards on the fan, as it will be too easy for wires to get trapped otherwise! The power supply does have a built in on/off switch, which saves having to fit an external switch. The RAMPS electronics have been placed with the reset button being accessible from the side of the machine. Access to the USB connector is a bit tricky, just keep a bit of clearance when wiring up in the next step. I only use USB for doing the calibration. At the moment I use a SD memory card for doing actual prints. In the future I want to try and use a Raspberry Pi in order to provide a Wireless connection. I already screwed a Pi to the base of my own Trix, proving there is sufficient room to fit it in.
<p>ok..soo where is the installation and the assembly of the electronics part at? I think thats the whole project. The easy part is building a frame and buying the necessary parts. </p>
for arms what did you use?? threaded rods or carbon tubes?? and of what size??
Kalankit contact me by whatsapp at +91 9775033780
<p>An update on Kickstarter two weeks ago from Richard that he should start shipping the Deltatric printers to the backers. The same as he told a year ago without any of the printers being shipped (except for two local pickups). In the last 11 days no printers has been shipped to the backers. <br>Same story as last year.<br>Last year around this time it was a delay already of 1 year behind schedule.<br>But at least in that year improvements where made.<br>Not everything was critically important, for instance you can make 3D prints without transparant doors.<br>Now just take the delay of last year, that is about 25 backers X 1 man-year of printing = a loss of 25 man-years of printing so far.<br>And still no sign of Richard that he started shipping the printers to the backers.</p>
<p>A year ago I had asked Richard to send me my printer which was finished enough that I could start printing with it. Two 'test-backers' got a printer and they are making prints for a year now. The rest of the backers have not received any printer yet, and Richard refuses any kind of comunication. What Richard is doing, he is busy with sub-projects on the printer that never end. The last sub project that Richard started on was at the end of last year and that is maybe finished by now. And then he probably thinks of another sub project. And every new sub projectis just another excusefor no sending the printers to the backers. The backers own their own printers as the backers have paid for it. But Richard keeps the printers of the backers in a kind of hostage situation at home and refuses to ship them to the backers. I have asked him a year ago to ship me my printer, and he still refuses to ship me my printer.</p>
<p>For people that intend to build the Deltatrix printer themselves, better check out the link below first. It seems that the Deltatrix printer is not functioning as Richard had expected.</p><p><a href="https://www.kickstarter.com/projects/1142241325/deltatrix-3d-printer/comments" rel="nofollow">https://www.kickstarter.com/projects/1142241325/deltatrix-3d-printer/comments</a></p>
<p>I have paid &pound;721 for the Deltatrix printer but Richard never delivered.<br>It is difficult to get in contact with Richard when he does not respond for three months. Richard, are planning to ever deliver the Deltatrix 3D printer or not?</p><p>If you are not planning to deliver, then please return me my &pound;721 within two days.</p>
<p>Have you or could you publish a parts list?</p>
<p>hello! I was wondering, since you now have your own 3D printer, couldn't you use it for Parts for your CNC design? I would love it if you could complete the design and finish the instructable as I am looking for both a 3D printer and a CNC machine. Thanks!</p>
<p>also could you post the 3D printable parts files for both the printer and the CNC? thanks again.</p>
<p>Hello,</p><p>I've baked one complete deltatrix kit at May 2014 with delivery at fall and then at winter and still not delivered.<br></p><p>Do you plan to finish or refund it?<br><br>Rregards,<br>Jan</p>
<p>Hi Jan. A new update will be posted on Kickstarter coming Monday, which will show where we are and how we will progress. Best wishes, Richard.</p>
<p>hey how i send what i want for print?? A usb cable??? </p>
<p>Hi. I use a USB cable for updating and modifying the firmware. I generally leave the printer stand alone and transfer GCode files by means of micro SD card.</p>
<p>Can you provide url with update?</p>
<p>Still nothing.<br>Should I wait or it is definetly scam?</p>
<p>Hey Richard,</p><p>Great design, both functionally and aesthetically. I have the parts sitting in my eBay cart as we speak and I have worked to measure the dimensions of the panels as I plan to attempt the cuts without a CNC setup. Before I pull the trigger, the last thing I need to be sure that I can accomplish from your instructions is the firmware setup. Form earlier comments I see that you have drafts that you are sharing and potentially a more formalized version complete. Are you still willing to share?</p><p>Thank you for your contributions and the vast amount of time you have spend thus far!</p><p>- Jeremy</p>
<p>Hello Richard,</p><p>when do you think you will release a new kickstarter campaign? I can't wait to hear from you :D</p>
<p>Hi Warren,</p><p>I assume you refer to the aluminium tubes on top of the carriage. The tubes are cut from a length of aluminium tube (8mm Outside Diameter x 1mm wall thickness) I obtained from my local DIY shop. I cut them to just over 14mm and file them down afterwards, so they are exactly 14.0mm (check with callipers). Finally, I drill them out to 6 or 6.5mm to fit the carriages. I am not yet selling the plastic bits, but should do so soon.</p>
<p>Hello Richard,</p><p>I'm trying to put together the bits and pieces to build this printer. I really like the Delta look. I have gotten the same Igus rail and carriage system you used with the exception of the extensions on the carriage in the center photograph. Is that an accessory for the carriage? If so do they have a part number or location I might get them? Also I know you are very busy building for the Kickstarter program (congratulations on that) but I will be in need of the plastic bits - can you give me a price?</p><p>Thanks</p><p>Warren </p>
<p>Hi, I would like to know if I can use a raspberry pi as a controller instead of the ramps.</p>
<p>Hi. A RPI does not have a lot of IO ports and it is not necessarily <br>good at doing real time stuff, as it uses a Linux operating system. Of <br>course, there is also LinuxCNC, which is actually used for doing <br>real-time stuff. However, for 3D printers (in 2014) the majority of <br>available OS firmware is written for 8 bit AVR or 32 bit ARM based <br>electronics. A RPI can still be useful for 3D printing, as it can act as a host. Visit Octoprint.org to check out the possibilities...</p>
<p>Hi, gr8 job. I wish if you can post updated CAD model here so that i can machine the structure on My CNC. I see that many plastic parts can also be machined on CNC,</p><p>I am sorry the kickstarter can not get the funds within the time. </p>
What type of distance sensor did you equip your machine with as you mentioned at the end of your instructable and how did it work? I am thinking about trying this and am curious of the results!
<p>Hi Braden, the sensor I used is this one: </p><p><a href="http://www.wayengineer.com/infrared-sensor-for-intelligent-car-accessories-p-1066.html#.U71Qv7HN7qw" rel="nofollow">http://www.wayengineer.com/infrared-sensor-for-int...</a></p><p>I have not yet tried auto levelling as I do not really need it.</p><p>Many consumer level printers lack rigidity, which results in the need for frequent re-calibration. The DeltaTrix frame has been designed to address this issue, by using a very sturdy frame structure.</p><p>Does your own printer need to be re-calibrated often? It looks like you copied the basic frame structure from my own design, so I expect it to be fairly rigid as well.</p>
<p>Hi there,</p><p>I was just wondering if you are going to be starting a new Kickstarter at any point soon. I would love to get a kit of this build as it is hard for me to do the wood working myself and I don't have any connections which would make this easy for me to do. Unfortunately I missed your last Kickstarter and cannot make a pledge. I already own a 3D printer but I absolutely love your design!</p>
Hi. Many thanks for your interest! The plan is to send the kits for the current Kickstarter in August, after which I aim to launch a new Kickstarter. Right now the production need to be set up, but for the new campaign everything will already be in place. This should lead to shorter lead times. Thanks again, and check back in a little while!
<p>Awesome! Thanks for the quick reply!</p><p>I can't wait to see the changes reflected on the original Instructable that you have up. I love the new look of the printers :)</p>
<p>I really want to make one of these since i can't no longer invest in the project on kickstarter :(</p><p>i am having difficulties getting the exact parts though, can you please update the BOM ? i am having difficulty finding info from pulley and below please and thank you</p><p>much appreciated, i love this design more than any other 3d printer in the market, thank in advance</p><p>... peace &amp; love from New York</p>
Hi! At the moment I am very busy sorting out the kits for Kickstarter. Part of the work is in finalising some of the latest design improvements and documenting everything I have changed/updated since publishing the initial Instructable. By the time I will be sending out the kits, I will update the Instructable (including the BOM) so it will reflect the latest version of the DeltaTrix 3D Printer. If you have any specific issues before the update, let me know what it is and I will try to sort it out! Also, I am concidering launching a new Kickstarter after sending the kits for the current campaign...
I just made my instructable if you want to check it out. Its called the delta twister 3d printer
<p>ok i have some questions 1 can i just router the frame because i dont have a cnc machine and how much money did you spend on this total</p>
<p>To router the main parts for the frame would be fairly difficult, as accuracy is essential. The design has been created to make use of the precision a CNC can offer. As long as the panels are correct, the frame would allign by itself. However, anything is possible! If I would not have had access to a CNC machine, I probably would have tried a router as well, making use of jigs or other methods for achieving the desired accuracy. In regards of cost, check my earlier reply to SeppePuelings (about a month ago, on this page).</p>
Hello I have wanted a 3d printer since I heard about them but I couldn't afford one, I am 12 and have advanced electronic but basic arduino skills, could you please put a list of all the parts with specific names, it would make my year, Thanks.
<p>Hi,</p><p>There is a BOM (Bill Of Materials) in step 6. Check it out and let me know if you need more information. Good luck!</p>
Thanks i just sent you my email!
I am now ready for the testing phase of my 3d printer! Any chance you could send me those files for arduino? Thanks so much for putting this instructable up
<p>Hi, sorry not to have replied earlier...</p><p>Send me a private message with your email, and I will send it to you. I still have not fully cleaned up the code, so I do not yet want to publish it properly.</p>
Looking at your design, I am hopeful now that a 3D printer is a possibility. <br> <br>Quick Question: How Do I procure parts when I dont have any one nearby who can 3d print? I do have someone who can laser cut acrylic or wood. Does the geometry of the 3d parts lend itself to a laser cut? which are the parts I can laser cut and which I can machine on a lathe or mill? <br> <br>
The upright panels for the machine frame need to be machined with a (CNC) router. The other panels could possibly be cut by other means, but all the laser cutting machines I know of cannot cut the thickness required.<br> <br> In terms of the 3D printed parts, some could possible be cut on a (CNC) mill using a 3mm straight cutter: spacers for the switches, brackets for idler pulleys, linear carriage brackets (no. 1) for clamping belts, motor brackets, nozzle bracket. The linear carriage brackets (no. 2) for holding the rods and the end nozzle carriage would be difficult to machine.<br> <br> At the moment I am running a <a href="http://www.kickstarter.com/projects/1142241325/deltatrix-3d-printer-open-source-and-fully-hackabl" rel="nofollow">Kickstarter campaign</a> where I am offering the DeltaTrix 3D Printer in kit form. It is also possible to just get hold of a panel set. If other options would be required, ask and I could add them, eg. 3D printed parts only, or panel set + 3D printed parts only. The Kickstarter will receive a big update in a few days, so make sure you keep an eye on it!
Thanks for the advice on the linear rods. I am using 8mm steel rods about 30 inches long. Would that present any sort of a problem? And thanks il wait until you publish the firmware
The<a href="http://reprap.org/wiki/Rostock" rel="nofollow"> Rostock 3D printer</a> uses similar size rods. There will most certainly be some deflection, but as plenty of peoples have been using Rostock type printers I am sure you will be able to get away with it.
Is there any way you could send me the arduino code that you made for this printer? Im really horrible when it comes to coding. Being 15 i havent taken coding classes and dont know how to make that part of the printer. If you dont want to give out that code its fine. Thanks!
My firmware is not yet ready for publishing, as it needs some cleaning up. When the time comes - which should be fairly soon - I am planning to publish the documented code on this very Instructable. Together with the publishing of the code, I will include full instructions on how to setup the printer and how to make changes to the firmware. If you<em> really</em> cannot wait a few days, send me a Private Message with your email address and I will send the 'dirty' files by email. PS. As you are building a printer with linear rods, make sure the rods are thick enough and not too long, otherwise their deflection could become an issue.
Thanks to you i was able to design my own printer and am currently building it. Dude you are my hero. Haha im using linear rods instead of your slide though because i do not have access to a cnc machine. Thanks aton and good luck with your kickstarter!!!!
Nice one! Good luck with your build if you decide to publish it, send me a link!
About This Instructable
186,138views
1,150favorites
License:
Bio: I am a Dutch design engineer, living in Wales (UK) and working in steel industry until recently, as my request for voluntary redundancy did get ... More »
More by RTegelbeckers:3D Printed spectrometer, using Public Lab DIY kit. DeltaTrix 3D Printer Foot operated log splitter
Add instructable to:
