Demon Halloween Designs
Introduction: Demon Halloween Designs
This instructable is about creating a halloween mask and/or a halloween decoration for the door with 123D Creature.This will be shown in two segments. The application is available from the Apple App Store.
Most of the information that explains the sculpting and painting is very much the same as the 'Monster Bunny Rabbit' instructable
The model I have created can be viewed here in the 123D Creature Gallery.
The final models can become a 3D print, for example with IMaterialise or a cardboard print with 123D Make.
Step 1: The Mask's Skeleton
To start with I made some quick drawings of the design.
Once I decided how I wanted the design to look I began with selecting the 'create new' button and altering the skeleton. To begin with you are given a very basic shape to play around with. You can create and remove appendages and manipulate these by moving , shaping, posing and scaling, however the symmetry of the skeleton cannot be changed/removed.
For this design I used the shape tool to increase the general size of the model.  One thing to remember  when shaping the model  is to not forget the holes for the nose and for the string/elastic/ribbon to go through as well as the eyes holes.
One must keep in mind that if you make this too complicated to begin with it can limit the sculpting detail and may even refuse to 'bake' at the next stage of development.
It may seem obvious but remember to keep saving your work or you may be disappointed to find your work is not up to date.
Step 2: Sculpting
Once you are happy with the skeleton it is time to select the 'Bake Skeleton button'. After this stage  it is time to begin sculpting.
At this stage you have the options to paint or sculpt first, but at this point it is best to concentrate on the shape first and paint later. The tools available are sculpt out, sculpt in, smooth, sharpen, flatten and grab. You can imagine the model as being comparable to a block of clay which can be shaped with these tools. You can also change the size and strength of the tool.
You can now turn the symmetry off allowing you to move parts of the model at one side without interrupting the other but this is not really necessary for this design.
Step 3: Adding More Detail
When adding detail to your model the sculpt out, sculpt in and grab tool is used primarily at this stage.
Once you have sculpted on the main details the grab tool can be handy with moving pushing and pulling detail closer together or apart to gain the desired effect. Be careful not to drag parts of the model too much as this can cause the polygons to stretch and become rough around the edges.
For a sharpened effect it is best not to rely completely on the sharpen tool. For details such as the horns and teeth I usually sharpen slightly before using the smooth tool. To exaggerate the features further use the grab tool on maximum strength and minimum size.
Sometimes finer detail cannot be made successfully whilst sculpting, so it is possible to achieve a similar look with paint and textures.
Step 4: Paint and Texture
Once the sculpting is finished it is time to colour the model. At any time you can still return to sculpting if you wish to change anything later. It is much easier to keep the symmetry on when you are painting but it can be turned off. This is ideal for details such as a scar over one eye or a wart on one side for example.
When painting you can chose to paint with a 'paint brush' or 'air brush'. I prefer the airbrush tool as this gives a much smoother look. Like the sculpting tools the size and strength/opacity of the brush paint can be changed.
For fur or skin I use the minimum size brush possible but this can be a lengthy process. Sometimes using textures can achieve the same or an even better finish. There are some textures already available which can be accessed by going on the 'image paint' button. You have nearly everything you need but for a more specific texture I look at images on the internet. Save them to your photos folder and these can be located on another photos folder in the app on this section. The colours of these can also be changed which is really helpful.
When painting it is good to think about a fake light source for shadows and highlights.
Step 5: The Door Decoration
This small segment describes how to make the door decoration. I used the same design template as the mask. The process of making it is the same as the mask but if you have already made one of them it is easier to select the project and go on 'new creature from skeleton'.
Step 6: The Skeleton and Sculpting
For the shape I have simply moved the sides forwards and straightened them out to make it flat at the back. I have added a large loop on the back so that it can be hung up but this could be changed into a hook shape or anything you need so that it can be displayed onto a door or flat surface.
Step 7: Painting the Decoration
For the colour of the decoration I have chose to have old rusty metal textures and paint in some shaded areas but the Halloween decoration could be coloured differently.
Step 8: Render and Export
This is more or less the same as what I have mentioned on my instructable 'Monster Bunny Rabbit' Halloween model.
Once you are happy with the final result you can render the model on the app. This allows you to change the lighting settings and effects. If you want a 2D image you can also place a photograph of anything you have taken or perhaps an internet image onto the background and save the final image to your photos folder.
Another thing to mention is once you have completed the model and saved it you can share this with the community. You can download my model from the community and it can then be found in your 'my projects' section. This then gives you the opportunity to have a look and make alterations if you wish.
At this point you can export your work to another program such as 123D Make to make a cardboard sculpture. This can be done by accessing the menu options. This will change it into a obj file. You can 3D print the file with IMaterialise also in different materials. You can chose to print them with the existing colours or as a blank paintable resin.  You can export files for 3d printers at home by selecting the 'export mesh' . This can be found when you select a project.
You can order a 3d print on the app. The 3d printing is provided by Sculpteo. On the app you can choose how big you want the model and get a price quote.
If you decide to have a go at making one of these I hope you have fun and remember that there is no right or wrong way to create them. The designs I have done are just as examples but the general shape and colours etc can be done your way to make them individual and interesting. :)
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    these demons(i also saw "killer rabbit") are quite impressive. texture and mapping also of high quality. as a matter of interest can 123d creature export to obj? and can it animate stuff internally or must you export to another program (blender,lightwave,max,c4d) first.
    Hello. Thanks for the nice comments. Yes, the models you make in 123d creature can be made into an obj file. Personally I have not done this yet but I read that you can download it to iTunes or email it to yourself from the app to make it into a obj file. Just select your project and then select the 'export mesh'. Unfortunately you can not animate them internally, this has to be done by exporting them to other programs but I'm not really clued up on them. Im sorry that I can't help you out a little more on that. :)
