Density of Liquids and Materials
3,998
61
Published
Introduction: Density of Liquids and Materials
About: Rudy Explor: Hack, Test, project and experiment is: Simply a quest for discovery. Here are some of my experiences, life hacks, product testing and random weekend
The mass or density of the liquid depends on its nature.
Click to subscribe to my YouTube channel ► http://bit.ly/rudyexplor (thanks)
The density of a material is for the liquid, the ratio of the density compared to that of water (at 4 ° C).
Step 1: Test With Density of Liquids
In this first experience with liquids in order from bottom to top :
  • honey 1 360 kg / m3
  • Sugar Syrup 1 320 kg / m3
  • Dishwashing Liquid 1 120 kg / m3
  • Water 1 000 kg / m3
  • Edible oil 920 kg / m3
In the second experience with liquids in order from bottom to top :
  • Liquid for cutting metal 1 200 kg / m3
  • Milk 1 030 kg / m3
  • Water colored 1 000 kg / m3
  • Lamp Oil 850 kg / m3
If the density is low, the liquid will float.
If the density is higher, the liquid will flow.
This is why the petrol floats on water when there is a black tide.
Step 2: Test With Density of Materials in Liquids
In this third experience with materials in the liquids in order from bottom to top :
  • screw 7 500 kg / m3
  • Corn 1 300 kg / m3
  • ABS plastic 1 250 kg / m3
  • PE-HD plastic 950 kg / m3
  • PP plastique 860 kg / m3
If you use a 3D printer this experience is certainly very intersente for you.
It will let you visualized that the materials you will use will change the final weight of your object .
If you use a material in a liquid it can float or sink depending on the liquid and material used .
This is also why you will have more filament with PP (polypropylene) that in the ABS coil.
Step 3: Cocktails Storey
You can also create cocktails storey for example (bottom to top):
  • Grenadine syrup
  • Orange juice
  • Colored water
  • Alcohol
Pretty cool ! Is not it?
I hope you enjoyed this instructable.
If you want to see more,
you can visit my YouTube channel (please subscribe) :http://bit.ly/rudyexplor
RudyExplor
  • Make it Move Contest
  • Oil Contest
    Oil Contest
  • Clocks Contest
    Clocks Contest
Pretty interesting!
