Deodorant Frugality
Introduction: Deodorant Frugality
I hate waste!
It seemed to me that part of every stick of deodorant was being wasted. And, like I said, I didn't like that, actually I said hate but now I'm thinking that waste doesn't deserve such strong feelings. So I decided to do something about it. This Instructable is about how I use all of the deodorant I buy.
My idea comes from leaving deodorant in a hot car. Talk about waste! The deodorant melts away leaving big smelly spot on your seat or carpet. But that told me that deodorant melts easily.
Step 1: Save the Waste and Choose Your Receiving Stick
So I saved all those little extra bits of deodorant with the idea to melt them into a new stick. It turns out that stick deodorant also dries out and shrinks. That leaves a gap around the edge. So one must use a less than empty stick to receive the molten deodorant. Otherwise it just runs through the crack and all over the counter. You don't have to do that because I have already done it!
Step 2: Make Room for the Molten Deodorant
Take your less than empty stick and back it down as far as possible leaving plenty of room for your molten deodorant.
Step 3: Remove the Inserts
It used to be that if you turn a stick far enough the insert would fall out. Lately, they have changed the design so that there is clip at the top. For the new design, you must take a knife and pry the insert out. The clip is not very strong, it doesn't take much force to pry one out.
Step 4: Load the Inserts in a Cup
I used a plastic cup for this demonstration. A microwavable glass would probably be better. The liquid can get hot enough to melt a plastic cup. As one can see in my after picture for the cup. I show this here as a cautionary note. The deodorant melts very easily and gets hot very fast. DO NOT MICROWAVE FOR LONG.
Step 5: Microwave the Inserts
I microwave in small periods. For my microwave I choose 11 seconds ( I'm too lazy to hit 1 and 0 for 10 seconds). It took me 3 times until I was happy with the melt. And as I showed before that melted the plastic cup. The above pictures show the partial melt and then the final melt. Note the inserts are bare and there is a pool of molten deodorant in the bottom of the cup.
Step 6: Pour the Molten Deodorant Into the Prepared Container
Now one can pour the molten deodorant into the prepared container. I don't remove the inserts, I just let the liquid run around them. Be aware, the liquid can be pretty hot. Don't burn yourself! I would compare it to molten wax.
And it will melt some of the existing deodorant in the receiving container. If it is too hot or there is not enough deodorant in the receiving container, you can get deodorant on the counter. I am confident now and didn't use a paper towel. But you might want to do this over a paper towel.
Step 7: Allow to Cool
Allow the liquid to cool and solidify. One can speed the process along in the refrigerator or freezer. Be patient, if you try to turn the stick up and it isn't hardened it can be messy.
Step 8: Finally Your New Stick of Deodorant
Feel the pride of turning waste into usable deodorant!
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Would that work also with talc/white deodorant?
    Love your Waste Not Want Not Instructable, sir. I use the same brand & am always annoyed by the hidden & lost product in the plastic pusher.
    I have done this with my Arm And Hammer baking soda deodorant push ups. I recovered two full containers after holding about 10 expended ones, so the loss rate is very high and guess what? You get to pay for that waste unless you recover it by this means. My next gripe is the mass of plastic that is now in the waste stream, I couldn't figure out anything to do with them, I'd feel a whole lot better if they were made of some heavy waxed paper.
    I've actually been meaning to do this, thanks for posting this ible!
