Introduction: Deodorant Hiding Spot!
Do you know those small things, those things that you need to put somewhere out of sight?
Well i made a simple solution for your problem!
No need to make holes in your wall or in your desk!
just recycling an old can of deodoarant.
Step 1: The "Ingredients"
You'l need to gather these items:
An empty deodorant can.
A multitool (knife, little scissors, nose pliers)
Step 2: Depressurising the Can
Make sure you empty the can by spraying until there is no gas left.
Now get the lid of the can.
Poke a little hole with the knife just under the grey part, you will hear a "Shhh" noise.
Step 3: Cutting Time
now just try to get the grey part of the can by cutting.
If cutting does not work use the pliers to twist little parts of.
you should get something like the second picture.
Step 4: Smoothing the Border
Now twist the sharp edges to the inside, otherwise the lid won't fit and you could cut yourself.
Step 5: Storing Your Stuff
put the things you want to hide in there and put the lid back on.
Step 6: Placing
Just place it somewhere, I think the best place is where you could normally set your deodorant.
I hope you liked my instructable , and good luck storing your stuff :D
Hiding Places Contest
