Introduction: Derezzed (Knex Ball Machine)
Picture of Derezzed (Knex Ball Machine)
My TRON themed ball machine.  Made summer-fall 2012. Designed to be viewed under a blacklight, hence the two videos.
Step 1: Flat Spiral
Picture of Flat Spiral
I haven't ever seen a flat spiral made from track connectors, so I thought I'd post mine.
Pictures 3-6 are from my new ball machine.
Step 2: Alternate Elliptica Rails
Picture of Alternate Elliptica Rails
Since I don't have many gold connectors, I made alternate rails for the IAC's elliptica that use green track connectors.
IAC's instructable is here: https://www.instructables.com/id/Knex-ball-machine-element-The-Elliptica/
The rails are a little closer together, so the axle needs to be adjusted as well.
The top half attaches to the blue connectors at either end.
Step 3: Micro Roller Coaster Track
Picture of Micro Roller Coaster Track
Not too hard.  Similar to KneXtreme's path, but connects the rails together with micro pieces.  The easiest way is to use short yellow rods with a yellow connector on each end.  Attatches to the tower using transitional pieces, similar to a mini roller coaster.Easy too build, doesn't sag much, rolls very smoothly.  Turns are easy, drops are near impossible (unless you have the curve pieces).
KneXtreme's track can be found here: https://www.instructables.com/id/KneXtremes-Guide-to-Ball-Machine-Elements/step13/Mini-Roller-Coaster-Track/
Step 4: Roller Coaster Bridge
Picture of Roller Coaster Bridge
A simple way to use three railed roller coaster track to bridge gaps.  This technique minimizes sagging.  Use the dark orange rods for the bottom rails, and put the track connector in the separated spot so that it cannot slide.  Put a red rod through the center, and a blue spacer on each end.  This prevents the rod from sliding through the connectors, which is what would cause the track to bend.  Middle rail on the bottom is optional.
Blacklights...you've got to be kidding me. Why didn't I think of that? ;-)
Nice machine!
Thanks! Using the blacklight changes a lot of things, since only a few kinds of pieces glow. But once you figure out which ones, it's pretty awesome.
www139 (author)2013-01-26
cool
sandroknexmaster (author)2013-01-25
That's really great!
Cool elements and nice idea to use the blacklight, very innovative.
I hope you'll build more ball machines in the future!
I hope to have my next one done by the end of the month, but we'll see. 12 tracks, 3 networks. Its gonna be big.
Cool can't wait!
I'm also building a new ball machine, but it will probably take more then 1 month to finish it.
About This Instructable
698views
1favorite
License:
More by fenrir119:Space Tower (Knex Ball Machine)Fenrir119's Knex Ball Machine ElementsDerezzed (Knex Ball Machine)
Add instructable to:
