Desert Eagle-Slide Action Plus Removable Mag(s)
Published
Introduction: Desert Eagle-Slide Action Plus Removable Mag(s)
About: I like building knex guns and modding nerf guns. I play Call of Duty and Minecraft. I also own a minecraft server.
Hey guys, this is my new desert eagle. I built it yesterday and I have to say it's awesome. It's as long as my forearm (about). It has a slide and removable mags. The mag sucks cause I was running out of pieces and had to improvise. But it works, though.It fires 9mm gray connectors (I measured them, they are, in fact, 9mm). It holds ten rounds and one extra can be chambered just like a real gun.
Here are the pros and cons:
PROS
High power about 60ft range.
Large ammo capacity.
Iron sight
Silent
Slide-Action
Safety
Durable
CONS
Absolutely gargantuan (but desert eagles are big, right? :|)
Mag feeder sometimes sticks
Slide sticks from time to time
Jams a little
Sucky mag (just build your own mag using that brain you were given :D)
Heavy (for a plastic pistol)
Never mind. Just don't post.
UPDATE- FOR ALL YOU HATERS - YES YOU DR. RICHTOFEN - THIS IS A HEAVILY MODDED VERSION OF DUTCHWARLORD'S GUN. CREDIT FOR HIM FOR ONLY THE BASIC PARTS.
UPDATE- The mag feeder is not shown in the pics because I didn't add yet. Either way I quit Knex gun making and I mod nerf guns real well now. The feeder was a light gray connector (the V shaped two-notch one) connected with a green rod to a red connector, and a white rod to stabilize it. Rubber bands wrap around both sides and latch on to the top of the mag.
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    10 Comments
    that looks so cool and is the best replica of this model I've ever seen and I've seen alot!
    I'm back in Knex business with two new guns.
    One is a bit noobish, one is just plain cool.
    This gun doesn't have very good looks, I must say that, but if it gets the ranges you say it does, this gun can't be that bad. Not very realistic to the real Desert Eagle, (meaning that it wouldn't make a good replica), but good gun for performance, in my opinion. I would like to see if you could possibly revise this gun so that it will be smaller. Just a suggestion, but great job overall!
    Revision: I noticed I can cram 12 in mag with when I got more connecters.
