Spread a thin layer of paint out on your palette with a palette knife, charge the roller with paint and go for it!
Step 1: Techniques for Making the Roller Designs
There are several techniques for making the rollers. You can carve into the plastic sleeve itself with a Dremel tool. You can also glue things to the surface.
I sometimes use acrylic gel, or modeling paste, for sticking things like string to the surface of the PVC sleeves. Clear PVC cement works well for sticking down shapes cut from Nagahyde upholstery vinyl. For precise gluing with the PVC cement I sometimes use a hypodermic syringe without the needle. The solvent in the cement eventually damages the syringe, but it is good for a while.
Check out the pictures for ideas as to what is possible.
Step 2: Beginner's Roller Handle
Sections of 1 1/4" PVC pipe fit on the standard paint roller handles. In this step, you see how I made a quick dremel-carved sleeve. After penciling the design on the sleeve, I held it in a vise while carving.
Step 3: Advanced Roller Handles
Inside the sleeve, there are two molded end pieces with the holes for the axle bolts, and a split ring spacer sleeve to keep them the right distance apart. These units slide into the pipe sections that are the roller sleeves.
I made the male part of the molds for the end pieces out of plywood. The female outer part of the mold was a section of the same PVC pipe meant to be used as the roller sleeves. I may have wrapped that section with wire to keep it from expanding as it was in use with heated material and might absorb heat and soften during the molding process. It was many years ago, and I threw out the molds.
For tips on working with PVC, see my other instructable: http://www.instructables.com/id/PVC-Its-Great-for-Inventions
Step 4: Paintings Done With Rollers
These are some paintings I did many years ago on water color paper with acrylic paints. For the most part, I put down abstract backgrounds with the rollers and then did something more realistic over it with brush work. A couple of the paintings were done only with rollers and paper stencils -- no brush work.
Visit Our Store »
Go Pro Today »
this is amazing
very beutifull paintings.
nice work
To get a silicone impression of tree bark, you could just smear some silicone onto the bark and then apply a layer of cloth (to prevent excessive stretching and tearing) with more silicone. When dry, peel it off the bark and clean out whatever bark flakes are sticking to the silicone.
You might be able to make a roller out of the material by sticking it to a PVC sleeve with more silicone. Or, you might be able to just press the flat material into cement and forget the roller idea. Beats me. It would take some experimenting.
I wish you'd make a whole thread of all the awesome ideas you've come up with for using PVC. I'm serious, man--I think you obviously are an "out-of-box"er, and I bet you could write a book with all the stuff you've come up with to "re-purpose" ordinary items. I'm convinced--and a new fan.
You should start playing around with the material, if you haven't already. Shouldn't let that enthusiasm go to waste.
I can not draw decently a glass...
Glass is not easy to draw.
I guess art is not for everybody. I enjoyed it, so I stuck with it. I think everyone has the potential, though. It's a combination of thinking and feeling and a lot of practice.
It is a normal state of being for a true artist personality type. I know this because I met about twenty or more different artists at that art market and they all acted and thought similar ways. Like I did when I was accused of ...being flighty, ungrounded, unproductive, lazy, unmotivated, having personality problems and issues. The more I was around these people, the more I realized I was NOT BROKEN. I was NOT SCREWED UP. I was NOT FLIGHTY, etc. I was a normal artist type, doing normal artist behaviour, acting just like we always do.
We need to be careful what we accept from other people. Don't listen if someone tells you you have an issue if you are happy doing what you are doing. They just do not have knowledge of our personalities or how our minds work. They might have an issue with US is all and they will often be critical of us because we do not fit their mold. It can make them feel threatened.
An artist should always be growing evolving and becomming better than before. Now that you have recognized your personality flaws, it is your job to better yourself by challenging and overcomming them. This is the true struggle of the artist.
I did not but unfortunately I was convinced for many years that I was broken, screwed up and worthless. When I finally realized they were judging me unfairly and did things my normal way and refused to allow them to put me down (by disassociating myself from them)... well, suddenly, I started making money, becoming popular and had many more friends. I have not evolved so much as accepted I am different and stopped being a sheeple and following THEIR leads and trying to fit myself into THEIR molds.
I have never ever said that artists are any of those things.
As I mentioned in my other reply, though, you would possibly save a lot of grief by just making wood end pieces. It's always good to learn how to mold PVC, though. You never know when that trick will come in handy.
I still don't understand the commercial sleeve idea that prevents sticking.
Although almost nothing, when dry, sticks well to silicone I suspect that wet cement would. You can stick two pieces of glass together with water, for example, whereas they don't stick together dry. Air has to get in for the water to let go, or a vacuum is formed. Form a vacuum and the cement would be pulled upward as the roller passes on, I imagine.
By the way, to smooth out some surface defects, a soft paint brush and a little water works well.
"Inside the sleeve, there are two molded end pieces with the holes for the axle bolts, and a split ring spacer sleeve to keep them the right distance apart."
Is the split ring spacer between the two molded end inserts and it is just barely smaller than the roller sleeve minus the end sizes so the ends don't move into the sleeve too far? Is the spacer made from a smaller size pvc, split then heated to open more and fit snug? What do you use to make the end caps?
"I made the male part of the molds for the end pieces out of plywood. The female outer part of the mold was a section of the same PVC pipe meant to be used as the roller sleeves. I may have wrapped that section with wire to keep it from expanding as it was in use with heated material and might absorb heat and soften during the molding process."
Does this mean you made a hole in plywood and melted/heated the material to force into a hole that would tightly fit inside the roller sleeve? Or does it mean that you used a circular wood blank that you forced the end material (that looks like it is pvc) after heating the material up? And forced it into a reinforced pvc pipe for the outer dimension? I was wondering if we could use a piece of cement to hold the female part in it's original dimension? Thanks for helping.
Let's say I am using 4" diameter pipe as the roller sleeves. Some rollers might be 2 inches wide and some might be 6 inches wide. You would need a different handle for each size, because of the different widths.
The molded end pieces could be used for either handle, because they are both for 4" pipe. You would need two different split ring separators, though.
Let's say the molded end pieces take up 1/2" on either side of the width, for a total of 1". You would need a 1" length of end separator for the 2" rollers and a 5" separator for the 6" rollers.
The separators would be sections of 4" diameter pipe with two cuts down the side to remove a narrow strip. The removal of the strip allows it to be compressed more tightly and fit inside the roller sleeve. PVC is springy, so it springs outward once inside the roller sleeve. Because of the separators, the end pieces can not now be pushed inward by pressure from the handle's arms.
Let's say the 4" pipe wall is 1/8" thick. You want the outside of the end pieces to be a tight fit to the inside diameter of 4" pipe, so the diameter of the (let's say 3/4" thick) round plywood male part of the mold would be the inside diameter of the pipe, less 1/4".
The female part of the mold might be a section of 4" pipe about 5/8" long. You have to allow a little over 1/2" to allow for cutting off the excess material after the molding process, if you want your end pieces to measure 1/2" when finished. That is not critical, though, because the spacer length can adjust as needed.
I have used cement before to keep PVC rings from expanding in female molds before. That would probably be more precise than using wire.
You could probably simplify the whole process, especially if you have a drill press with a circle cutter, to just cut plywood rounds for the end pieces and use the same split ring separator idea between them. That would eliminate the molding part of the project and save you a lot of time if it worked. I was just enamored with molding the plastic in those days and made a bunch of similar pieces for end caps for pipe, too.
I have a suspicion that won't work well, because of the stickiness of the cement. Disneyland had a cement Swiss Family Robinson tree house, which was pretty convincing, but I don't know how they did the texture. I think I read somewhere that Disney artists used crumpled aluminum foil to stipple the texture on their fake rocks. They impressed the heck out of me.
Just a thought. You might press grass cuttings into the tinted wet cement and leave them there until the cement hardens. Then you could blast them out with a pressure sprayer, or wait until they rotted out. That could give you a possibly bark-like texture.
Check it out. Like I said, you saved me hundreds of dollars.
A thought that came to me is that maybe silicone rubber might be a good material to use for the texture surface. I don't know exactly how you would do this, but you might spread some silicone over real tree bark, for example and let it harden. Then peel it off and wrap it around a PVC roller core with some more silicone to make it stick. The silicone is very flexible.
The seam where the ends join would need some touch-up by hand, but it would be minimal. That would be a quick and easy way to copy textures.
Please keep me informed as to your progress with this idea; and I imagine it would make a great instructable for you.
It's an idea I might be tempted to play with someday myself, but I would prefer for you to get there first.
So you really definitely know your concrete, Thinkenstein. Or psychic... or both, lol! Now, maybe a texture made with whatever with a silicone sleeve? Plastic wrap? Plastic wrap the concrete then roll? I may have to buy one of there rollers to research deeper. Thanks for the stickiness tip. Go right ahead on testing any ideas. If you want to share the idea here, please do so. *grin* I have been stalking ...um subscribed to you since I read your fabulous concrete ideas.
What is the scale of the paintings?
Are you still painting?
The paintings were all 18 X 24 inches. I bought paper by the ream in those days. Cheaper in bulk.
I haven't painted anything in years. I think about it sometimes, but don't seem to get inspired. I wish I had more models, but wishing doesn't seem to have done much good.
