Design and Assemble a Wheelchair Lever Arm: Planetary Gear
Published
Introduction: Design and Assemble a Wheelchair Lever Arm: Planetary Gear
Instructions on how to build part of the wheelchair lever arm in solidworks for this project:
https://www.instructables.com/id/Design-and-Assemb...
Step 1: Sketch a 17mm Diameter Circle on the Front Plane
Step 2: Create a Vertical Centerline at the Top of the Circle, Draw Half of a Tooth and Use "Mirror Entities" to Mirror About the Centerline
Step 3: Use "Circular Pattern" to Create 21 Identical Teeth Around the Gear and Use "trim Entities" to Trim the Circle
Step 4: Extrude the Gear by 4mm Using "Extrude Boss"
Step 5: Use "Hole Wizard" to Create and M2 Counterbore Hole in the Center of the Gear
Step 6: History Tree
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
