3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Design and Build a Full Tang Knife
Building your own tools can be a great thing and knives are no exception. From the caveman times to Bear Grylls, knives have been an essential part of outdoor survival and just basic utility and around the house use. This Instructable is a basic guideline for making your own unique survival tool that will be suited to your use and designed to your specifications. Also, if you use recycled materials like I did, your knife should be practically free! This is obviously not the only way to make a knife. There are many other tried and true techniques, but this it what i have found to work best. If you don't find all parts helpful, pick and choose. develop your own basic style and make it work best for you. This could take one knife or it could take ten, but keep at it. A tool that you have made is truly a joy to behold. And just because I don't want to get in trouble is people hurt themselves: Knives are tools but also can be weapons. Treat them with extreme care and respect them. Making sharp pointy things has an inherent danger to it so use common sense. Also, dull knives are more dangerous than sharp ones. Forcing a dull knife will increase the chance of slipping and that's bad, even with a dull knife. Ok, I'm done ranting. On to the important part!
Step 1Designing the Knife: Materials
The first step in making most things is a design and the same holds true to knives. To design my knives, I use graph paper, a metal ruler, a French curve, and a normal pencil. Also, since I use found metal for my knives, I like to have the metal in front of me so I know what I have to work with.
160 comments
1-40 of 160next »
Apr 19, 2012. 9:00 AMKelticpaddler says:
If this was a truly functional knife, you would harden the blade before fitting the handles, thus making it almost impossible to drill through.
Ideally, drill the holes in the "tang" before hadening. Then harden, anneal, glue on one scale and drill the hole through from the exposed tang. Then glue the second scale on and drill through from the first scale.
Apr 18, 2012. 2:10 PMtriumphman says:
What the h--- are you saying?
Oct 7, 2010. 4:02 PMwoodNfish says:
Very nice knife. My grandfather made knives out of old saw blades too. Tool steel takes a nice edge. I see one problem though and that is using danish oil with polyurethane. The oil never truly dries and I am fairly certain that will prevent the poly from fully curing. Poly alone should be enough.
Oct 9, 2010. 7:08 AMtkjtkj says:
Doesn't the oil also help prevent water from permeating the wood? That's why i 'mineral oil'
my kitchen cutting boards, salad bowls, etc ..
and ya, 'pharmacy-grade' mineral oil is edible, but never give it to someone who has difficulty swallowing: if it gets into the lung: big big problems!
Apr 18, 2012. 2:07 PMtriumphman says:
More B.S.!
Oct 9, 2010. 2:55 PMwoodNfish says:
atomicturkey27, You can get poly in various shades that will stain the wood if you like. Minwax has quite a variety, and poly brings out the grain too.
tktkj: Poly seals the wood against moisture. You use mineral oil on cutting boards because it is non-toxic. It doesn't have to be "pharmacy-grade" which is something I've never heard of and is probably a marketing gimmick. You should not use polyurethane, varnish, and other finishes on cutting boards.
Oct 10, 2010. 6:29 PMtkjtkj says:
ya but there really is a need for a 'pharmacy grade' mineral oil .. Ya see, it's used medically as a laxative, but there are a bunch of issues that must be explained to any patient to use it safely. Having a 'USP' (US Pharmacopea) formulation lets users or care-givers to be able to read the label. Misuse can kill a patient!
And i do say 'formulation' not simply 'packaging' cuz the USP offering contains a 'stabilizer' (Vit. E , actually) ... If you've the interest i can send ya the medical info. I also doubt that the users of the 'paint store' variety would be concerned much were there to be some infectious agent or two in the batch. Knife handles need not be sterile .. Cutting boards should not be contaminated so i'd strongly advise people to use the USP version in the kitchen where food contact occurs .. including the lubricating of blender blade bearings!
Apr 18, 2012. 2:12 PMtriumphman says:
YA BUT ?
B.S.
Oct 10, 2010. 7:21 PMwoodNfish says:
Honestly tkjtkj, I don't think it makes a difference. I buy my mineral oil at the grocery store. The hardware store doesn't carry it.
Oct 11, 2010. 12:56 PMtkjtkj says:
Ok, fair enough .. but please do understand that many people could do that only with grave danger to themselves or others. One could even propose that a prescription should be required, so important are the warnings on the drug store label!
One can easily die by not having read them.
My prescription suggestion is based on fact that so many elderly (who do have more intestinal problems) can't even read the small print on the pharmacy formulation... it can be life-saving for them to be told by some practitioner how mineral oil is to be used and how misuse can result in a very very bad thing.
As far as we know, death is a one-way street.
Apparently enough professionals recognize these issues and do require that at the least, a USPharmacopia version of the product be available.
"Then let them die, and reduce the surplus population", Ebeneezer Scrooge.
Apr 18, 2012. 2:06 PMtriumphman says:
too much rhetoric!
Oct 11, 2010. 5:45 PMwoodNfish says:
Okay tkjtkj, but what's your point? You can find info about food safe finishes in any woodworking magazine and plenty of online woodworking sites.
No they don't. I'm telling you - it is a marketing gimmick, nothing more. I'm sure they charge you more for the same product too. Sorta like shampoo from the olcal market versus shampoo from a beautician. The beautician will overcharge you every time.
Feb 2, 2012. 4:33 PMhrenthegreat says:
If you dont mind me asking, what steel is used? and would a dremel with a metal cutting wheel be able to replace the edge grinder?
Mar 9, 2012. 1:16 PMThe Rambler says:
I almost asked the same question, but then I looked at the pictures in step 4 more closely and it appears to be made out of a saw blade, which is pretty cool. I'm curious about how stiff the blade is. I know some saw blades are flimsy, but that one appears to be a miter or backsaw blade which is usually stiffer.
If you're just using the dremel to cut out the shape of the blade it should work as long as the metal you're using for the knife isn't too thick. It will take a while though, and you might go through quite a few cutting wheels.
Mar 2, 2012. 2:07 PMBrazilian Saber Tooth says:
Thank you!
So that 's how it is done?!
I 'll never pay for that again...rs
Dec 15, 2011. 8:06 AMtriumphman says:
See my knives from metal and non-metal polymer on my instructables. Triumphman.
Dec 6, 2011. 11:45 AMghost999 says:
you sould use oil.
Dec 6, 2011. 11:40 AMghost999 says:
Sould i use camo duck tape on the handle for when i go hunting.
Nov 3, 2011. 5:01 PM2Sharp says:
It's not a big deal nor expensive to get either brass or nickel-silver bolsters as well as guards and pins online. There are more than a few shops online who sell knifemaking supplies at very reasonable prices including the shipping. I have ordered pins and guards as well as a couple of thumb studs to replace lost ones on some of my folding knives.
Most hardware stores I have been in carry brass and aluminum rod for welding and other applications. The brass rod for example can be cut into lengths for use as brass pins to hold the handle on.
I have just started making custom knives as a hobby which I enjoy and if someone is interested in getting started, there are many helpful instructional videos as well as books on making knives nowadays.
My own personal suggestion is getting a DIY kit online or from a knifemaking supply store if there is one near you and putting one together, refurbish a broken or old knife or customize an existing knife. This will familiarize you with the tools and give you an idea of what goes into knife construction.
Then you can progress to complete customization including learning how to forge your own blades or if you prefer you can use the material removal method, there are advantages and disadvantages to both methods.
It's satisfying to make a knife which is unique and has all the features you like in a blade! Good Luck!
Oct 3, 2011. 8:56 PMbobthebuilder728 says:
Check out my knives made from circular saw blades
Oct 3, 2011. 8:38 PMSasquatchKid says:
Could I make
The center of the blade hollow?
Aug 22, 2011. 9:18 AMGary Viveiros says:
When I read the part about pasting the pattern onto the blade blank, it brought back memories of a knife I made in High School from a small rectangle of heavy-gauge stainless that had fallen off some vehicle and was lying on the road. Then the memories came back, and the process was similar. Back then I didn't know how to fasten the blade to the handle, so I just slotted the hardwood handle a few inches and painstakingly drilled 4 holes in the stainless, and clamped it all together with the screws. Ah, the younger years, where time was never of the exsence!
Jun 20, 2011. 2:07 PMJodex says:
Will the blade stand really actual use? I mean, shouldn't it be hardened or something? Anyway, this is a very cool project and it is very possible, that I'd make one too!
Jul 30, 2011. 5:46 PMThe Metal One says:
your knives will be sub-par to worthless unless you use a carbon steel (such as 1020 1/8 inch plate stock) and then heat treat it by heating the blade to 800 degrees for an hour then quenching in oil. otherwise i love your design, you did well with materials on hand. good work ;)
Jul 20, 2011. 3:22 AMdsmith49 says:
I was thinking of doing this utilizing a wooden handle that looks like Brass knuckles. also, do you know what kind of wood is the best kind to use?
Jul 30, 2011. 5:49 PMThe Metal One says:
hickory. although red oak is a close second
Dec 16, 2010. 7:47 AMrepear9 says:
That is a amazing knife, I wish i could have your skills on my zombie slaying group, then we would be near invincible.
Anyway good job, currently i am trying to make a boot knife from a old file.
Dec 17, 2010. 8:50 AMrepear9 says:
well i am a good shooter, writer, survivalist.
i am also in good shape, i take karate and i almost have my black-belt after 8 years of training, i have been on long hiking excursions.
I am learning gunsmithing and bladesmithing.
I hope that is enough to make your decision.
Jul 23, 2011. 5:09 AMrenabarai says:
I'm a bomb technician. So if you see me running, try to catch up.
Jul 30, 2011. 2:24 PMthedude000121 says:
IPOD!!! quote.
Dec 17, 2010. 7:08 PMrepear9 says:
I am also reading up on bomb-craft, anarchist cookbook FTW!
Jun 4, 2011. 6:24 PM_Scratch_ says:
^ nitroglycerin much?
Feb 1, 2011. 11:59 AMAbhorsen says:
Thanks alot for your Instructable! Within my limited possibilities as student, i was able to follow your instructions and made something I'm extremely proud of :) Thanks again
1-40 of 160next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:atomicturkey27
i live in new york Quote: Before your criticize someone walk a mile in their shoes. then you're a mile away from them and you have their shoes.
