loading
Building your own tools can be a great thing and knives are no exception. From the caveman times to Bear Grylls, knives have been an essential part of outdoor survival and just basic utility and around the house use. This Instructable is a basic guideline for making your own unique survival tool that will be suited to your use and designed to your specifications. Also, if you use recycled materials like I did, your knife should be practically free! This is obviously not the only way to make a knife. There are many other tried and true techniques, but this it what i have found to work best. If you don't find all parts helpful, pick and choose. develop your own basic style and make it work best for you. This could take one knife or it could take ten, but keep at it. A tool that you have made is truly a joy to behold. And just because I don't want to get in trouble is people hurt themselves: Knives are tools but also can be weapons. Treat them with extreme care and respect them. Making sharp pointy things has an inherent danger to it so use common sense. Also, dull knives are more dangerous than sharp ones. Forcing a dull knife will increase the chance of slipping and that's bad, even with a dull knife. Ok, I'm done ranting. On to the important part!
Step 1: Designing the Knife: Materials
The first step in making most things is a design and the same holds true to knives. To design my knives, I use graph paper, a metal ruler, a French curve, and a normal pencil. Also, since I use found metal for my knives, I like to have the metal in front of me so I know what I have to work with.
Step 2: Basic Design: Overall and the Handle
The essential parts of a knife are the blade and the handle, so this is where you should focus most of your efforts. If you want to spend time on guards and pommels and such, that's good too. I don't make them because I don't have access to soft metal (brass, copper, aluminum) and I don't have a band saw. For the design of this knife I had a freehand rendering that I drew in English class under my desk that I used as a template. I liked the basic proportions, but I needed to increase the scale by 75%. This made the knife too big for graph paper so i had to tape some together.
I started with the handle. Working off my original sketch and with lots of measuring, i drew a full scale rendering of the handle. To make curves I draw dots at the correct measurements, then connect the dots with a French curve. This is where a lot of personal preference comes in. Design what you like and what looks good, it's your knife!
Step 3: Basic Design: the Blade
When people see a knife, the first thing they see is the blade. Therefore, it should set the theme for the knife, and make the knife look great. For this knife I chose a simple blade with no complex curves. This basic type of blade is a good one to start with, because it is not nly easy to design, it involves less grinding, and functions well. This knife has an 8 by 1.75 inch blade so i started with a rectangle of these dimensions. I then drew a curve in that I thought went well with the overall knife design. The main image is the design cut out and ready to be taped to the stock.
Step 4: Making the Blade: Cutting From the Stock
Now the fun part: Rough cutting of the blade. this is where you go from paper to metal in the design process, and is the first step in the manufacturing of the blade. Start by taping the pattern to the blade; I use loops of masking tape. Then head outside. This makes a huge amount of sparks and sends small metal shavings all over. Clamp your workpiece to a bench of sorts (or an Adirondack chair). Put a cutting wheel in your angle grinder and have at it. But please use proper saftey gear!! I use a full face shield, ear protection and tight-fitting gloves, and if you work inside use a dust mask!
Start cutting away at the metal, staying away from the pattern. Make sure to leave yourself room to shape it on the grinder. make sure you don't overheat the metal, because this causes it to lose its temper. Sorry for so few pictures, its hard to cut and take pics at the same time.
Step 5: Making the Blade: Grinding the Shape
This step is fairly simple, the only tool you need is a bench grinder. You can use an angle grinder, but it can be hard to see what you're doing, and getting straight edges is hard to accomplish. I just recently got a bench grinder, and the work and pain it saves is amazing. Use the same safety gear for the angle grinder, and wear clothes you don't care about because they will get covered in metal. Again, sorry for the lack of pictures. It's kinda boring, but it is fun to see the knife take shape.
Step 6: Making the Blade: Grinding the Bevel
This step may be the one with the most consequence if you screw up. the cutting edge is the most important part, and when forming it, go slow. You only want to grind half of the edge away on each side. Make sure you clamp the blank securely. I like to use C clamps because they cover less of the knife. You don't want it moving anywhere while you grind.
To form the bevel I use a 36 grit wheel for my angle grinder, because it makes a wide cutting path. While forming, check the angle by looking down the blank. When you hit halfway, flip it over and grind the other side. when you see a wire edge forming, stop. you have made a successful edge.
Step 7: Making the Blade: Rust Removal and Finishing
Now for the part where your knife starts to look like a knife: Finishing. This makes it shiny, which as everyone knows is an essential part of a knife! This blade was made from an old backsaw blade, so it had some surface rust that needed to be cleaned off. To do this I used an angle grinder with a 120 grit flap wheel. Make sure to clamp it securly (Again, it's the Adirondack chair!)
Focus most of your effort on the blade, although you can clean the handle area too if you want. After you remove the rust and make it look halfway decent, it's time for hand sanding. Clamp the knife securely to a block of wood, then clamp that in a vise. I start with 180 grit and work my way up to 1000 grit. This gives it a nice smooth satin finish. On this knife I chose to go for a weathered-ish look. If you want you can use some rough sandpaper on the handle to help the epoxy stick better. Once you have a nice shiny blade it's on to the next step!
Step 8: Making the Handle: Rough Cutting and Gluing
The first step of making a handle is making the handle scales (Scales are the pieces that are on either side of the blade). For this knife I chose to use some nice red oak that I got at Lowes. Note: This was the only material that I actually had to buy. Yay for recycled materials! To make the scales, figure out the size by placing the knife over the wood and marking the largest dimensions you will need. Use a square to mark out a rough rectangle, then go ahead and cut it out. I use a table saw because it is fast and easy, but if you have a lot of patience, you could do it with a hand saw.
Once you cut out the scales it's time to glue them. This part is pretty easy, but you want to make sure and get it right. Mix up a good bit of glue (I use two-part epoxy), and spread it on a scale. place the knife on the scale, then repeat with the other scale. Get them lined up the way you like, then clamp them. I usually wait two hours before working with the knife, to allow plenty of time to set. Make sure to wear proper saftey gear like a dust mask! These fumes are nasty!
Step 9: Making the Handle: Achving the Correct Thickness
I have discovered that most knife handles shouldn't be much more than 3/4 inch thick, but since this is a big knife, I went a bit larger. Set your calipers to half the thickness you want, and start rasping. You could use a plane if you wanted to. Continue the filing until you get the correct thickness on both sides. This is faily quick if you have a sharp rasp, just make sure to file evenly on both sides.
Step 10: Making the Handle: Rough Shaping
Now for the most long and tedious part: rough shaping. Similar to grinding, this is where the handle looks more like a handle and less like a block of wood. This stage reqires a bit perception, since you want to know where the metal starts. Hitting metal with a wood rasp makes it duller. The basic idea behind this is use the rasp until you think you are close to metal, then switch to a file that can deal with both metal and wood. This part is fairly tedious, but you want to take your time. The pictures show the basic outline taking shape, which is what you want at this stage. Also, you may want to cover the blade with duct tape so you can clamp it in the vise and work on the whole handle.
Step 11: Making the Handle: Final Sanding and Installing Pins
Getting close to the end, it's just basic sanding and pins now. The sanding is pretty self-explanatory, just work through the grits until you get to about 320 or 400. If you want to be silly you can use up to 1000, but I don't think it would make a huge difference to the overall feel of the knife. This knife handle was sanded up to 320 grit before finishing.
Since installing the pins goes with final finishing, I'm going to include everything in one step. Since I don't have any fancy rivets and such I use a method that may seem like cheating to some hardcore knife makers: I drill through the handle and blade, epoxy the pins in, then file them flat. The first step in this process is marking the holes. I usually eyeball the marks, then check their orientation with a straightedge to make sure they all line up. Next, you want to measure and cut your pins. For this knife I just used a brass rod (it may be a welding rod). To measure, just lay them across the handle and mark with a Sharpie. Make them a bit oversized though. It's a lot easier to remove material than it is to add it. Clamp the rod in a vise and use an ordinary hacksaw to cut the pins off. Then it's off to the drill press! Clamp your piece securely somehow, then drill through everything in one go. I put the drill on its slowest speed and use a really sharp bit. Repeat with however many pins you want to. When you finish, make sure to double check the fit of the pins in the holes. If they just barely fit, then you're in luck! Just tap them in with a mallet and file off the ends. If they slide in easily, then its epoxy time! Mix up some more epoxy, then put a bit on the middle of the pin. slide it in, and wipe any excess epoxy with a clean rag. leave it to dry before filing. When It's dry, just file the pins flush using a mill file.
Almost there, don't give up now!
Step 12: Making the Handle: Finish Him!!!
It's the last step of construction! Technically this step is optional; if you want to leave your handle as bare wood you can. I chose to treat it with some Danish oil and two coats of polyurethane. The technique for applying oil is fairly simple. Just wipe off the handle with a clean cloth, then use a rag to apply the oil. make sure to get even coverage of the handle. I applied two coats, then let them sit overnight.
Before applying polyurethane, lightly sand the surface with the finest grit that you used. In my case, that was 320 grit. Then make sure you wipe off all of the sawdust, again with a clean cloth. Use a foam brush to apply a very thin coat of polyurethane to the wood. I used two coats, and sanded in between coats. After the last coat, let it sit for 24 hours. This gives it a chance to set completely. Congratulations, you're done with the manufacturing process!
Step 13: It's Sharpening Time!
This is where your knife finally becomes a tool! Getting a very sharp edge on a knife is essential, but can be a bit more difficult with a homemade knife. Grinding the edge by hand inevitably produces irregularities, but that is part of handcrafting your own tool. Small things like this can be worked around though, so don't worry. To sharpen my knives I work through a progression of stones; a coarse synthetic, medium Arkansas, and fine Arkansas. I'm assuming that anyone who gets to this last stage has a fairly good idea of knives and how to sharpen them, so I'm not going to include a whole slew of facts, techniques, and angles. If you want a basic primer, do a search for "knife sharpening" on Instructables. There are many good Instructables that cover this subject. Ok enough ranting about that, now back to the main subject. Work through your stones until you reach a nice sharp edge. At this point, you can leave it like that, or strop the edge. This produces a razor edge on your knives, and I like to finish my knives with it. I use a homemade strop to do this, and if there is interest in how to make and use it, please leave a comment saying so. To test the edge, try slicing up some paper. It should cut cleanly and easily, if not, keep at it. When you can consistently cut paper into ribbons with your knife, you're done!
Step 14: Congratulations! :)
At this point you should have a finished knife. There is great satisfaction in using a tool that you made yourself, and to see it perform as good or better than most store-bought knives. Also, being able to make a tool from scratch is a nice skill to have (for when the zombies come!). If there are any improvements or corrections that I need to make, please leave them in the comments and I will try to get to them ASAP. Also, if anyone makes a knife using this or any other Instructable for that matter, please post it. I think I speak for a lot of people when I say that I love to see what other people can do, and what twists of their own they add. Be safe and have fun with your new knife!
Thanks for reading and hope you enjoyed it!!
<p>Heres the thing, I have a kitchen clever which the handle fell off on, and I wanna put it in a bigger handle. Will it be unsafe if its not a full tang and i'm using it to chop wood?</p>
Can you post s PDF of the design for it
<p>Look awesome mate. Looks like I found a project for the weekend.</p>
Great ible! Here's a picture of mine, I made them out of an old saw blade from a skill saw! They polished up great!
<p>You've inspired me, they look great!</p>
<p>These knives look amazing! You really made those? They are beautiful and the shine is a nice touch too!</p>
Wow. The shine is amazing. How did you do this?
Basically the same as atomicturkey27 did. But then used different grade sand paper to get the big scratches out and then finally a buffing wheel! I was surprised out how well they came out. Glad you like them!
It looks amazing. Honestly, I would love to buy one off of you I like it so much. With the sand paper, did you just keep going up in grade every time you felt it was necessary?
Thanks! dont know if I wanna sell them yet, maybe if I make some more! but yeah I just sanded it forever, making sure i go every little scratch out.
<p>My first attempt at a stock removal knife.</p>
<p>I bought this blade blank on eBay and cut the scales from some Osage Orange heartwood I had cut and seasoned for 5 years. This wood is one of the densest woods grown in USA and is really hard to work, but that's not nearly as difficult as making one completely from scratch</p>
hi, looks good.... but what you could have done was drill 2 holes thru both handles and metal.. then 2 small metal bars thru.. and round off the ends..<br>similar to two rivets....
<p>Hi <a href="https://www.instructables.com/member/th3_v1k1ng/" rel="nofollow">th3_v1k1ng</a></p><p>Some metal that can be used for blades is harder than drill bits. My grandson bought a Damascus blade blank on eBay. The vendor said he would send pin if buyer would ask. He didn't ask and the holes were an odd size, slightly under 1/8&quot;. He couldn't drill them bigger and had to sand 1/8&quot; SS welding rod down to fit the holes, making for a lot of extra work.</p><p>Really a nice knife, <a href="https://www.instructables.com/member/atomicturkey27/" rel="nofollow">atomicturkey27</a></p>
Please watch and subscribe. Thanks https://www.youtube.com/watch?v=CKka02CejCo
Looks really good and easy to make
@The Metal One: 1020 is &quot;sub-par to worthless&quot; for knives. You will be much better off with a steel that has a carbon percentage above 0.7%. The second two numbers in the 10xx series steels stand for the carbon percentage (1020 is 0.2% carbon, 1080 is 0.8%, etc.) also, the heat treat regimen you prescribe will harden only a few, if any, types of steel.
your knives will be sub-par to worthless unless you use a carbon steel (such as 1020 1/8 inch plate stock) and then heat treat it by heating the blade to 800 degrees for an hour then quenching in oil. otherwise i love your design, you did well with materials on hand. good work ;)<br>
For my more recent knives I've been using A2 or O1 tool steel. These steels contain elements like chromium that greatly improve wear resistance, which makes them a great choice for knives. Also, many of the exotic woods make really excellent knife handles. I've found that purpleheart works quite well, although it is difficult to machine.
How are you doing your heat treat? I am wondering as those steels (specifically the A2) are quite difficult to heat treat.
Just one question, where can i get the steel for the knife? <br>
I use 1084 from NJSteelBaron.com.
Although your method will produce a serviceable knife, you will get infinitely better results if you start with a known steel (my favourite is 1085), file out your profile and bevels, and harden by heating to slightly above the point where a magnet will no longer stick and quenching in canola oil. The reason I use 1085 is because it is extremely simple to heat treat as it requires no soak.
hey! I made a knife like your! <br>here's photos of me making the knife and the finished image <br>sorry for my english , im brazilian <br>thanks for the tutorial! make more!
i cant send the images! fuuuu! <br>how i send it?
If you dont mind me asking, what steel is used? and would a dremel with a metal cutting wheel be able to replace the edge grinder? <br>
I almost asked the same question, but then I looked at the pictures in step 4 more closely and it appears to be made out of a saw blade, which is pretty cool. I'm curious about how stiff the blade is. I know some saw blades are flimsy, but that one appears to be a miter or backsaw blade which is usually stiffer. <br> <br>If you're just using the dremel to cut out the shape of the blade it should work as long as the metal you're using for the knife isn't too thick. It will take a while though, and you might go through quite a few cutting wheels.
You can save a lot of cutting wheels if you only cut half way through the metal, then clamp it in a vice and whack it with a hammer. If done right it should snap apart! This makes it go a lot faster but only works with higher carbon metals.
I don't think some of the people here understand that your metal is already heat treated. &quot;This blade was made from an old backsaw blade&quot; . This metal was already heat treated (tempered) at the factory when the original tool was made. <br> <br>This is the reason knife makers *use* old saw blades, files, leaf springs, and the like to make high quality carbon steel blades. The heat treating has already been professionally done. <br> <br>As for the handle finish, atomicturkey27's method seems to work for him. If you want something different, go for it. &quot;Your mileage may vary&quot;. <br> <br>You don't *have* to finish it at all. If you use it regularly, your natural hand oils will eventually give it a finish. <br> <br>Personally, I'm partial to Tung Oil. Quick, easy, and forgiving. I use it on all my hand whittled walking sticks because it really brings out the look of the wood without covering it up. <br> <br>But you could just dunk it in some &quot;Tool Dip&quot;. <br> <br>BTW atomicturkey27, Great Instructable. Thank you. <br>I'm re-designing a knife (an old cheap machete cut in half long ways. Super Pig Sticker!) and your info showed me how to properly put on the handles. I was spinning wheels until now. Thanks again!
If this was a truly functional knife, you would harden the blade before fitting the handles, thus making it almost impossible to drill through. <br> <br>Ideally, drill the holes in the &quot;tang&quot; before hadening. Then harden, anneal, glue on one scale and drill the hole through from the exposed tang. Then glue the second scale on and drill through from the first scale.
Very nice knife. My grandfather made knives out of old saw blades too. Tool steel takes a nice edge. I see one problem though and that is using danish oil with polyurethane. The oil never truly dries and I am fairly certain that will prevent the poly from fully curing. Poly alone should be enough.
I gave the oil 24 hours to set, which was the time recommended on the can. It said that you could follow up with wax or poly to achieve a nicer finish. Also, the main purpose of the oil was to darken the wood. I found that it gives the wood a nice rich color and brings out the long grain that is present in oak.
Doesn't the oil also help prevent water from permeating the wood? That's why i 'mineral oil'<br>my kitchen cutting boards, salad bowls, etc ..<br><br>and ya, 'pharmacy-grade' mineral oil is edible, but never give it to someone who has difficulty swallowing: if it gets into the lung: big big problems!
atomicturkey27, You can get poly in various shades that will stain the wood if you like. Minwax has quite a variety, and poly brings out the grain too.<br><br>tktkj: Poly seals the wood against moisture. You use mineral oil on cutting boards because it is non-toxic. It doesn't have to be &quot;pharmacy-grade&quot; which is something I've never heard of and is probably a marketing gimmick. You should not use polyurethane, varnish, and other finishes on cutting boards.
ya but there really is a need for a 'pharmacy grade' mineral oil .. Ya see, it's used medically as a laxative, but there are a bunch of issues that must be explained to any patient to use it safely. Having a 'USP' (US Pharmacopea) formulation lets users or care-givers to be able to read the label. Misuse can kill a patient!<br>And i do say 'formulation' not simply 'packaging' cuz the USP offering contains a 'stabilizer' (Vit. E , actually) ... If you've the interest i can send ya the medical info. I also doubt that the users of the 'paint store' variety would be concerned much were there to be some infectious agent or two in the batch. Knife handles need not be sterile .. Cutting boards should not be contaminated so i'd strongly advise people to use the USP version in the kitchen where food contact occurs .. including the lubricating of blender blade bearings!
YA BUT ?
Honestly tkjtkj, I don't think it makes a difference. I buy my mineral oil at the grocery store. The hardware store doesn't carry it.
Ok, fair enough .. but please do understand that many people could do that only with grave danger to themselves or others. One could even propose that a prescription should be required, so important are the warnings on the drug store label!<br>One can easily die by not having read them. <br>My prescription suggestion is based on fact that so many elderly (who do have more intestinal problems) can't even read the small print on the pharmacy formulation... it can be life-saving for them to be told by some practitioner how mineral oil is to be used and how misuse can result in a very very bad thing.<br><br>As far as we know, death is a one-way street.<br>Apparently enough professionals recognize these issues and do require that at the least, a USPharmacopia version of the product be available.<br>
&quot;Then let them die, and reduce the surplus population&quot;, Ebeneezer Scrooge.
too much rhetoric!
Okay tkjtkj, but what's your point? You can find info about food safe finishes in any woodworking magazine and plenty of online woodworking sites.<br><br>&gt;&gt;Apparently enough professionals recognize these issues and do require that at the least, a USPharmacopia version of the product be available.<br><br>No they don't. I'm telling you - it is a marketing gimmick, nothing more. I'm sure they charge you more for the same product too. Sorta like shampoo from the olcal market versus shampoo from a beautician. The beautician will overcharge you every time.
B.S.
More B.S.!
<em>I don't have a band saw.</em><br> <br> You actually don't need a band saw to cut those parts out. You can make do with a coping saw (check any hardware store, they're usually around $10 to $15) with a metal cutting blade (a few dollars more). Then you just need to find the brass, copper, whatever (ask around the hardware store while you're in there). Good luck!
I have looked for softer metal at the hardware store, and can't find an and i can't be bothered to order offline.
mmm.. i think just about every TrueValue hardware store (and HomeDespot, and Low's) i've ever been in carried brass rod, aluminum material, etc, in many form-factors ..<br><br>(oh, and there are NO misspellings in this note!)
Who cares! B.S.!
I don't blame you for not wanting to buy it online. It can get pricey with the shipping since the metal is heavy. <br><br>You might check out the link below for fittings. He only charges one price for shipping, no matter what you buy, and he's real friendly. I've bought several things from him and have always been happy with the experience.<br><br>http://www.ragweedforge.com/BladeCatalog.html<br><br>And I didn't say it before but thank you for the Instructable! I enjoyed reading it.
alright i'll take a look. Thanks and glad you enjoyed the instructable!
About This Instructable
264,855views
722favorites
License:
Bio: Currently studying Mechanical Engineering as an undergraduate at Worcester Polytechnic Institute. I love designing and building things, woodworking, and rowing in my free time.
More by pfdanielson:Sugru Lighter Grip Design and Build a Full Tang Knife Knex Castle
Add instructable to:
