3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Homemade Photo Booth
Hello,
My fiance and I are getting married in October 2011 and we decided we wanted to build a photobooth for the wedding. We saw that the photobooths out there were nice but $1000 was too much. I asked her if I could build us something dorky for our wedding and she said only if it's not tacky. So I figured what better than this. We decided we could use it as the guest book and we could make our own picture frames and give them out as the wedding favors.
This instructable is broken down into 5 parts
Steps 2-19 are building your own mini itx PC
Steps 20-56 are building the photobooth
Steps 57-58 are schematics for building a serial button for the booth
Steps 59-63 is how to setup the software so you can run this on your laptop or pc
(sorry windows users only for now, also you must have webcam and speakers)
Steps 64+ are future upgrades I'm still working on
I work as an electrical engineer by day so carpentry, software, art and computer aided designs are not my strong point, but I figured it would be fun. So we gave it three months and we wound up designing everything from software to hardware ourselves. There are still a lot of details I'm working on. One big one is the robot that cuts the photostrips and how to access the twitpic api so I can correctly upload these to twitpic rather than using emails. But the basics are working. Any tips or ideas I would gladly pursue.
Keep in mind I will be working on this for ten more months so this is the beta release. I hope you enjoy my instructable. If you are interested in downloading the software just skip ahead to step 60.
For updates and samples go to
http://twitpic.com/photos/diyphotobooth
V0.22 available at Step 60
beta release
-voice enabled
-webcam enabled
-limited config editing enabled
-gui in progress
-tweeting in progress
-printing disabled
[video compressing]
Step 1Intro
36 comments
Mar 10, 2012. 4:30 AMSkywalker123 says:
Congratulations on a fantastic Photobooth!! I don't have a web cam, but I have a Canon Powershot. How do I get the program to recognize the Powershot?.
Nov 11, 2011. 10:07 PMaberson says:
The UUUU from a 555 timer is very clever, but couldn't this button simply have been an SPST button looping back DTR to DSR or CTS? You'd write software to wait for DSR and then do something, and you wouldn't need any components besides the button and some wire.
Oct 12, 2011. 10:07 AMhainesface says:
Will the software work with a canon DSLR isntead of a webcam? thanks!
Jun 11, 2011. 4:28 PMAlgag says:
"... had a darker finish than I has expected." :D I love talking in bad english
Mar 22, 2011. 8:48 AMGarreth says:
Couldn't you just use smaller photo paper in the printer?
Mar 22, 2011. 7:27 AMGarreth says:
If you have a vice, I would suggest a sawzall with a metal cutting blade. Keep the blade oiled so that it doesn't overheat.
Feb 10, 2011. 4:58 PMiApple guy says:
How much did it end up costing
Feb 10, 2011. 1:44 PMkermudgin says:
The program will not display a picture before taking. It also wont let me view the pictures that I have taken. Is there any way you can help me with this. I have your zip file and have downloaded interfran.
Jan 8, 2011. 10:03 AMSeth Black says:
...here's an open source program that's been in development for a little while:
http://www.openphotobooth.com/index.php
It may be of use to you, in working out the bugs in your own program. :)
Jan 9, 2011. 7:10 AMrru96 says:
Great idea on the props. One thing though, is to make sure you have contrasting backgrounds so that certain colors, or skin types, that make up your guests won't cause them to fade into your backdrop colors all because they chose to wear a red shirt., or white..etc.
Jan 6, 2011. 3:01 PMstevemail says:
On printing, why not pre-cut photo paper to the size strips you want? You could probably get 3 strips out of a standard size 8.5 x 11 sheet.
Alternatively, you could use another standard page size--e.g., 4 x 6--and arrange the 4 shots in two columns.
Jan 3, 2011. 11:52 AMSeth Black says:
Fantastic work on this!  I absolutely will keep an eye on how this continues to evolve.
Suggestion:  Don't forget to incorporate a controlled light source into the final design.
- The lighting at the reception venue may be unpredictable and more subdued than you're testing the unit with now.
- The black curtain will greatly reduce the amount  of ambient lighting, and greatly impair the exposure.
Jan 4, 2011. 1:55 PMSeth Black says:
...anytime. :)
You could certainly upgrade to the Canon PowerShot, with its internal flash, or simply retrofit the cabinet with a daylight balanced fluorescent tube, so there's a steady level of light.
Personally, I would explore the possibility of using the constant light source, over the strobe (flash) method:
- Better, precise and predictable control of uniform exposures for each guest.
- Almost complete prevention of red eye, and hot spots.
- Consistency of light source during entire venue.
- Strobes can sometimes misfire and underexpose if the capacitors is not fully charged, when the shutter is tripped.
The black curtain would not impair exposures, once a light source is in use.
The red curtain would be very much like the black, and would not impair exposures.
The white curtain would reflect light back to the camera, and exposure will be effected to some degree.
One thing you could also consider incorporating would be a white FoamCore panel above the seat area.  This reflector could be flat, or in a domed configuration.
With the existing light source, this would function very much like a hairlight, and impart a very professional look to the captured images.
Jan 5, 2011. 12:16 PMSeth Black says:
...any type of white reflective material could be used to bounce the light back down.
"...I'm not sure what you mean by daylight balanced..."
Here's an example of a standard incandescent screw mount:
http://www.porters.com/flash-studio/studio-lighting-bulbs/daylight-balanced-85w-spiral-fluorescent-lamp.html
There are a variety of tube configurations that might work, as well.
The main thing to remember is that you want even lighting on your subject(s):
- Single (or double) horizontal tube
or
- Two or three screw mounts evenly spaced.
Jan 4, 2011. 10:23 AMBuckarooBanzai says:
I like it... a lot!
Chalk up another vote for the Ultimate Photobooth.
Jan 2, 2011. 1:47 PMAngryRedhead says:
Impressive!  I really like how portable it is - very smart and elegant.
I saw you screwing and unscrewing the shelves, and that might be a nightmare on the wedding day when you pass the task off to someone else.  I think french cleats would help immensely while still keeping everything secure.  You would need to attach them to both sides and the back, but then setup is a matter of hanging shelves rather than screwing them in.  They'll also improve the durability should you want to take this to parties and other gatherings.  It would be great for family reunions!
The curtain is probably going to get pulled off a couple times which means reattaching it during the night.  It might be easier to use a folding privacy screen that's detached from the booth itself.  It would be cheap and easy enough to make out of pipe or "sticks in a can", and then, if you do have someone over 6' tall, no one would have to duck to enter.  It will add to the foot print, but privacy screens are also popular home decor items.
Congrats and best of luck on wedding preparations!
Jan 3, 2011. 12:17 PMAngryRedhead says:
I'm impressed you can do it so quickly, but I wonder how quickly someone else would be able to do it.  It's your baby, so I'm sure you're very efficient with setup and tear down.
As for privacy screens, I meant a black fabric privacy screen which would look more like a curtain sort of like this.  It will still give the classic photo booth look but perhaps less troublesome.  You could even make the exterior fabric red and the interior fabric black.  I don't think a solid or wooden privacy screen would work so well.
Jan 2, 2011. 9:36 AMYashknowsbetter says:
Brilliant! :)
Jan 2, 2011. 10:39 AMcarlo$ says:
Outstanding! Make sure you use a high definition camera.
Jan 3, 2011. 5:12 AMpossum888 says:
Great job! You got my vote.
Jan 2, 2011. 1:24 PMDr. Pepper says:
This is a photo booth. LOL
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:splitreaction
Split Reaction, now known as Cunning Turtle, is a group of DIYers, artists, writers, engineers and photographers based in the NY state region.
