loading
Step 54: Creating safety curtain clips
I just cut some short cloths hangers and painted them black. I'll finish them with some hammer paint. One big concern I had for my booth was any children pulling on the curtain and tipping over the booth. The booth is 150lbs and bottom heavy so it doesn't like to tip by itself but long curtain rods would give the child significant leverage. So these clips made it so the curtain would snap off if too much force was applied. Plus when someone looked close they would see it was just a cloths pin and be able to fix it.
<p>Thank you for the share, i'm going to start with my setup right now!</p>
Congratulations on a fantastic Photobooth!! I don't have a web cam, but I have a Canon Powershot. How do I get the program to recognize the Powershot?.
The UUUU from a 555 timer is very clever, but couldn't this button simply have been an SPST button looping back DTR to DSR or CTS? You'd write software to wait for DSR and then do something, and you wouldn't need any components besides the button and some wire.
Will the software work with a canon DSLR isntead of a webcam? thanks!
&quot;... had a darker finish than I has expected.&quot; :D I love talking in bad english
Couldn't you just use smaller photo paper in the printer?
It's limited to 3 inch widths and the photo strips are a bit more narrow.
If you have a vice, I would suggest a sawzall with a metal cutting blade. Keep the blade oiled so that it doesn't overheat.
That's a good idea. I didn't think of that.
How much did it end up costing
Personally about $500ish with the PC.
The program will not display a picture before taking. It also wont let me view the pictures that I have taken. Is there any way you can help me with this. I have your zip file and have downloaded interfran.
Hmm... It sounds like the webcam isn't working. Are you using XP? I noticed some webcams won't work if you aren't using the windows webcams drivers. I had to uninstall my webcam's driver and use the default ones to get it to work.
...here's an open source program that's been in development for a little while:<br> <br> <a href="http://www.openphotobooth.com/index.php">http://www.openphotobooth.com/index.php</a><br> <br> It may be of use to you, in working out the bugs in your own program. :)
Hmm I wish openphotobooth had more documentation. Doesn't seem like it has a interactive gui or a help file. Is that true or did i miss it all?
cool thanks!<br><br>It's tough fitting updates in between work. At this point I have the twitter/email feature and splash screen working. I figure the twitter feature will be a nice way to share the digital copies.
Great idea on the props. One thing though, is to make sure you have contrasting backgrounds so that certain colors, or skin types, that make up your guests won't cause them to fade into your backdrop colors all because they chose to wear a red shirt., or white..etc.
That's a good idea. I think for my wedding a lighter color like white is probably good. White isn't too much of a problem at a wedding since the bride will be the only one white and it won't be a plain white.
On printing, why not pre-cut photo paper to the size strips you want? You could probably get 3 strips out of a standard size 8.5 x 11 sheet. <br>Alternatively, you could use another standard page size--e.g., 4 x 6--and arrange the 4 shots in two columns.
I have a lot of sheets of 8.5 x 11 photo paper and for now I'm trying to make 6 1.5&quot;x8&quot; strips where they will be precut and printed 2 at a time. I made this little model to demonstrate an automated cutting mechanism.<br><br>http://www.youtube.com/watch?v=yHgxIzcepxc&amp;feature=player_profilepage<br><br>If it fails,I'll probably have to precut them. There really isn't a problem either way. I just felt a little robot would look interesting.
<em><strong>Fantastic</strong></em> work on this!&nbsp; I absolutely will keep an eye on how this continues to evolve.<br> <br> <em>Suggestion</em>:&nbsp; Don't forget to incorporate a controlled light source into the final design.&nbsp;<br> <br> <em>- The lighting at the reception venue may be unpredictable and more subdued than you're testing the unit with now.<br> <br> - The black curtain will greatly reduce the amount&nbsp; of ambient lighting, and greatly impair the exposure.</em>
Thank you, I really appreciate that. <br><br>It was a lot of fun designing it and a lot of time to write up. I'm glad you like it.<br><br>Right now I rely on the monitor, which is a poor illumination source. Hopefully when I find the money to upgrade this to use a canon power shot camera the internal flash will be sufficient. If not I'm gonna sacrifice some of the space up top and use it for illumination.<br><br>The black curtain is my default, but I have a white and red one as a backup.
...anytime. :)<br> <br> You could certainly upgrade to the <em>Canon PowerShot</em>, with its internal flash, or simply retrofit the cabinet with a daylight balanced fluorescent tube, so there's a steady level of light.<br> <br> Personally, I would explore the possibility of using the constant light source, over the strobe <em>(flash)</em> method:<br> <br> <em>- Better, precise and predictable control of uniform exposures for each guest.<br> <br> - Almost complete prevention of red eye, and hot spots.<br> <br> - Consistency of light source during entire venue.<br> <br> - Strobes can sometimes misfire and underexpose if the capacitors is not fully charged, when the shutter is tripped.</em><br> <br> The black curtain would not impair exposures, once a light source is in use.&nbsp;<br> <br> The red curtain would be very much like the black, and would not impair exposures.&nbsp;<br> <br> The white curtain would reflect light back to the camera, and exposure will be effected to some degree.<br> <br> One thing you could also consider&nbsp;incorporating would be a white&nbsp;<em>FoamCore </em>panel above the seat area.&nbsp; This reflector could be flat, or&nbsp;in a&nbsp;domed configuration.&nbsp;<br> <br> With the existing light source, this would function very much like a hairlight, and impart&nbsp;a very professional look to the&nbsp;captured images.
Hmm, never thought of it that way. <br><br>I could permanently install the light source onto the top module. It would still be nice and enclosed. I'm not sure what you mean by daylight balanced. <br><br>The foam board maybe difficult to mount. how do you feel about repositioning the white curtain as a top reflector and using the red curtain as a privacy stand, like in angryredhead's comment? I have a feeling I may lean towards this design. I may have a way to make it all integrated if its in that manner. <br><br>
...any type of white reflective material could be used to bounce the light back down.&nbsp;<br> <br> <em>&quot;...I'm not sure what you mean by daylight balanced...&quot;</em><br> <br> Here's an example of a standard incandescent screw mount:<br> <br> <a href="http://www.porters.com/flash-studio/studio-lighting-bulbs/daylight-balanced-85w-spiral-fluorescent-lamp.html">http://www.porters.com/flash-studio/studio-lighting-bulbs/daylight-balanced-85w-spiral-fluorescent-lamp.html</a><br> <br> There are a variety of tube configurations that might work, as well.<br> <br> The main thing to remember is that you want even lighting on your subject(s):<br> <br> <em>- Single (or double)&nbsp;horizontal tube</em><br> <br> or<br> <br> <em>- Two or three screw&nbsp;mounts evenly spaced.&nbsp;</em>
I like it... a lot! <br> <br>Chalk up another vote for the Ultimate Photobooth.
Impressive!&nbsp; I really like how portable it is - very smart and elegant.<br> <br> I saw you screwing and unscrewing the shelves, and that might be a nightmare on the wedding day when you pass the task off to someone else.&nbsp; I think french cleats would help immensely while still keeping everything secure.&nbsp; You would need to attach them to both sides and the back, but then setup is a matter of hanging shelves rather than screwing them in.&nbsp; They'll also improve the durability should you want to take this to parties and other gatherings.&nbsp; It would be great for family reunions!<br> <br> The curtain is probably going to get pulled off a couple times which means reattaching it during the night.&nbsp; It might be easier to use a folding privacy screen that's detached from the booth itself.&nbsp; It would be cheap and easy enough to make out of pipe or &quot;sticks in a can&quot;, and then, if you do have someone over 6' tall, no one would have to duck to enter.&nbsp; It will add to the foot print, but privacy screens are also popular home decor items.<br> <br> Congrats and best of luck on wedding preparations!<br>
Haha you're definitely right. That's why I had to finally get out the power tools. I started out with hand tools. In the end setup only takes 8 mins and teardown is 4. <br><br>French cleats would be much faster. The center module keeps the two halves from splitting apart so I'm not sure they would work there. I do need additional shelves to hold props so french cleats may do the trick for those. <br><br>Now that I actually built this thing, I doubt I really need screw bolts, some cotter pins would have probably been enough.<br><br>Privacy screen is a better idea. The only reason I stuck with the curtain idea was the traditional look of a photo booth. I've tried to swing the idea, but for some reason, without the curtain, people just don't count it. <br><br>Thanks for all the advice. I still have another ten months of improvements to make.
I'm impressed you can do it so quickly, but I wonder how quickly someone else would be able to do it.&nbsp; It's your baby, so I'm sure you're very efficient with setup and tear down.<br> <br> As for privacy screens, I meant a black fabric privacy screen which would look more like a curtain sort of like <a href="http://www.bedbathandbeyond.com/product.asp?sku=14712291&utm_source=google&utm_medium=organic&utm_campaign=shopping">this</a>.&nbsp; It will still give the classic photo booth look but perhaps less troublesome.&nbsp; You could even make the exterior fabric red and the interior fabric black.&nbsp; I don't think a solid or wooden privacy screen would work so well.<br>
Ooh I see,<br><br>That's pretty cool. It would also keep it light weight. I can probably just re-purpose the PVC rods from the original curtain, It should be long enough too.
Brilliant! :) <br>
Thank you so much!
Outstanding! Make sure you use a high definition camera.
Thanks!<br><br>Surprisingly since the photo strips are so small the web cam quality photos are acceptable. I do want to incorporate this into my wedding albums so I'll be purchasing a canon power shot when I see one come down in price.
Great job! You got my vote.
Thank you so much!
This is a photo booth. LOL
About This Instructable
101,322views
216favorites
Bio: Split Reaction, now known as Cunning Turtle, is a group of DIYers, artists, writers, engineers and photographers based in the NY state region.
More by splitreaction:Ultimate Homemade Photo Booth Charge Your Cellphone Using Wasted Heat (and Build a Steampunk Wall-E)
Add instructable to:
