I like to call this approach the "novice with a shotgun" research methodology. If you put enough pellets in your cartridge (lots of small designs) and stand close enough to your target (start with simple cubes) then you are bound to hit something. Hopefully you wont self harm in the process (see step 5).
My previous instructable dealt with the software side of creating Ponoko laser cut creations. The main tool being the open source SVG Plugin for Google Sketchup. This plugin exports to SVG, and Inkscape can then import the file. Changes can be made in 2D within Inkscape, and the result can be laser cut by Ponoko.
Remove these ads by
Signing UpStep 1Unboxing
Instruction 1a: Learn from my mistakes (and hopefully my successes).
Remember to peruse the previous Instructable if you haven't already, this one builds upon the designs already presented.
I was genuinely surprised that shipping was so fast (seeing as wooden materials can be delayed in customs). The package arrived in what appeared to be a recycled cardboard. Nice! Be green people... be green...
I ripped the package open as was greeted with the sight below... oh*...
After peeling back the protective and sticky layers that hold the parts in place - everything looked much prettier. I felt a moment of pride in my designs (and then I was brought back to Earth).
Instruction 1b: Don't judge a delivery on its packaging - It'll look pretty once everything is peeled away. Remain calm.
If I were to cut a 1" square, would it be slightly smaller?
Good luck with the monome - I love those things! Never had the chance to play with one though...
http://downloads.sourceforge.net/inkscape/Inkscape-0.47-3.exe
For a quick work around without downloading new software - select your design once it's imported into the Ponoko template then goto Object->Transform (from the menu). Scale your design by 283.465% for both width and height. This should scale your design to the correct size.
It's actually a bit hard to pick without the extra attachments that I'm working on at the moment, but it's an over-sized kalimba - there's some cool Instructables floating around on these.
Thumb Piano
Instant Thumb Piano: How to make a set screw lamellaphone
I wanted something big an hollow so that you could tap your fingers on the top as well - which is why it looks like a cajon.
