Desk Lamp and Fan From Old Fibre-tip Pens
Published
Introduction: Desk Lamp and Fan From Old Fibre-tip Pens
About: I am an 18 year old hobbyist and tinkerer with a deep interest in DIY recycling, electronics and robotics.
I had a bunch of old fibre-tip pens (we'll call them Dollar Pointers, because this is how they're known here) lying around, so instead of throwing them away, I decided to reuse them. And this is what I made! A desk lamp + fan! This creation of mine will be useful during the summer, when I sit at my desk for long hours - reading, tinkering, e.t.c.
So let's begin!
Step 1: Getting Started: Things You'll Need
Here is a list of things required for making this desk lamp + fan.
  1. Fiber-tip pens (I used 3 of them)
  2. Curtain runners (they are obsolete, so you may use pieces of plastic, or you may make a hole in the pens themselves.)
  3. The cap of a jar or the cover of a box (This will serve as a base for the lamp, so it has to be broad and balanced)
  4. Connecting Wires
  5. Super glue
  6. Soldering iron
  7. Solder wire
  8. Battery (I used a 4V/1.3A one) or an adapter of suitable specifications
  9. White LEDs (Any type will do, make sure you do not use a battery or adapter which gives a higher voltage than what is required by the LEDs)
  10. Regular DC motor
  11. A bendy steel strip or a tin can
  12. A fan blade (any type will do)
  13. 3-4 screws + nuts
Step 2: Preparing the Adjustable Arms
  • We will use three fibre-tip pens (two of them with a curtain runner at one end and the other with runners at both ends)
  • Take a fibre-tip pen (referred to as a pen from now on) and cut off the area around its nib/point.
  • Repeat this step with the other two pens.
  • Now fix the curtain runners or pieces of plastic at the end and add a few drops of super glue.
  • Allow it to dry.
  • On the third pen, fix a runner or piece of plastic at the other end and glue it as well.
  • The arms of our lamp + fan are ready as shown in the 4th picture.
  • Now fix a runner or a piece of plastic to the LEDs as shown in the picture with the help of super glue.
  • Bend the steel strip around a motor to make a motor mount as shown in the picture.
  • Or if you do not have a steel strip, then cut a thin strip out of a tin can and repeat the above step. (WARNING: THE CAN MAY CUT YOUR HANDS, SO EXERCISE CAUTION!)
Step 3: Finishing Off!
  • First of all, we need to make two holes in the base/platform in order to fix the pens/arms.
  • Insert the stopper in the hole from the underside of the base and fix the pen from the top.
  • Repeat this step for the second pen.
  • Now attach the third arm (pen) to the second one, using a nut and screw as shown in the picture.
  • Fix the LED strip in a similar manner.
  • Then secure the DC motor in the motor mount that you have made from a tin can or a metal strip and attach it to the second pen (arm) with a screw and nut.
  • Ensure that you have already soldered the wires to both the LEDs and the motor.
  • Neatly tape the wires to the arms but leave some slack in them so that the arms can be moved easily.
  • The wiring diagram can be used as a reference while making the connections to the switches.
  • You may use a dremel or a soldering iron to make holes in the base for the switches, or you may make a direct connection to the battery/adapter, eliminating the use for a switch.
  • Now check the circuit by turning it on. If everything works then move on to the next step. If it doesn't. then check your connections and the powers source.
  • Your own desk lamp + fan is ready!
Step 4: Enjoy!
Set it up on your desk or workplace and enjoy the light and the breeze!
Good Work!
(NOTE: I didn't turn on the light while taking the pictures because of its sharp glare which would have made the picture useless. But I assure you it works fine!)
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    3 Comments
    If your hunger would be satisfied by it then please, be my guest.
