Desk Organizer
2,922
6
Posted in WorkshopOrganizing
Introduction: Desk Organizer
This is easy to make with everyday products. It looks good and works great.
Step 1: Materials
Saw
Clamp------3
Elmers wood glue
Ruler-----1’’-22/16’’
Making Tape--- one roll
Drill
Screws------4 that properly fit in a 5/32 inch hole
Notebook Paper------8.5’’-11’’
Calculator-------TI-30 6’’-3’’ front and back  6’’-1’’ sides
Base Wood For Paper------9’’x1.5’’ One piece 1.5’’ thickness
Front/Back wood for paper------9’’x13’’ Two pieces 0.5’’ thickness
Sidewall wood for paper-----3’’x11.5’’ One piece 0.5’’ thickness
Ruler Wood for Backwall------12.5”x1.375”
Sidewall wood for ruler-----12.5”x0.5”
Sandpaper
Drillbit------5/32 in
Marker
.5/1'' wooden dowel
Hot Glue Gun with glue
PVC Pipe---- .5''-2''
90 degree PVC connectors---- 2
Step 2: Cutting the Wood
Using a ruler and a marker mark all of the wood so that you can cut it straight and at the proper dimensions. Cut all of the wood using a saw.
Once the wood is cut, using the sandpaper make sure the sides of each piece of wood is smooth.
Step 3: Making the Paper Holder
Take all of the wood for the paper holder.
Connect the backwall of the paper holder to the side of the base by drilling four holes with a 5/32 inch width, two inches apart from each other
Step 4: Paper Holder Continued
Connect the sidewall to the backwall of the paper holder using the wood glue.
When all of the wood is glued together to make a box clamp the glued areas together until the glue dries properly.
Step 5: Ruler Holder
Take the wood for the back wall and set it aside. Take the cardboard and measure 4 12''x.5'' and hot glue two of them on top of each other so you have two 1.5''x1'' pieces of cardboard.
Sand the cardboard so the edges are smooth
Step 6: Ruler Holder Continued
When the glue dries connect the sidewalls to the open end of the paper sidewall with hot glue
Then when the sidewalls are done hot glue the back of the ruler holder so it makes a box
If the sidewalls are taller than the back wall then you can cut off the tops so that it is even.
Step 7: Clamp
Take the two 90degree pvc connectors.
Take one of them and designate that as the top. Take that connector and drill a 5/32 inch hole in the bottom where it will connect to the wood.
In the top of that connector drill a hole large enough that a screwdriver will be able to screw a nail in the bottom hole.
Step 8: Clamp Continued
Take the base of the wood and drill a 5//32inch hole in line with the other 5/32 inch hole. This is where you will put the screw.
Take the 1''-2'' pvc pipe and put it in the top pvc connector.
Put the other connector in the bottom of the pvc so it will make a U-shape
Step 9: Calculator Holder
Cut with scissors two pieces of cardboard at the dimension of 6’’-3’’
Cut four pieces of cardboard at the dimension of 6’’-1’’
Step 10: Calculator Holder Continued
Hot glue the two pieces of 6’’-3’’ cardboard on top of each other
Take the 6’’-1’’ pieces and hot glue one on top of the other making the two sidewalls for the ruler holder. Do not glue all four on top of each other.
The calculator holder should look like a box connected to the paper holder. You can use a part of the paper holder to use as a backwall.
Step 11: Protractor Holder
Cut a wooden dowel with the dimensions of .5''-1''
Hot glue the wooden dowel to part of the paper holder so that it does not interfere with the calculator holder.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
