If you spend a lot of hours behind your desk in the evenings, than good lighting is crucial. Make yourself this ecological and economical efficient desk lamp.
The total cost of the 10w led lamp plus dimmer plus power supply = 26 dollar. All the other parts were laying around in my garage.
Remove these ads by
Signing UpStep 1: Materials and tools
Materials:
- Four bolts M3
- Four bolts M6
- Four screws
- Wooden board approximately 9 cm x 324 cm
- Four dowels
- Heat sink
- Aluminum disk 20 mm
- Led dimmer (Velleman MK 187)
- 10w high power led
- 12v, 1 amp power supply
- Thermal paste
- Electric wires
Tools:
- Wood glue
- Wood wax
- Jig saw
- Screw driver
- Sand paper
- Wood clamps
- Drill
- Drill bit 2,5 mm, 5 mm, 6 mm, 10 mm, 32 mm
- Router
- Router bit 12 mm
- Solder
- Solder iron
Visit Our Store »
Go Pro Today »
again , nice design
salutes from mexico
Thanks!
simple and elegant.
But, I think it need a wider "base" structure.
It's tall and a bit top-heavy.
You should add weight to the bottom or a wider base (or both)
Other than that it's a great idea and a nice build
The base structure may also be cut 45 Degrees so as to get more footing and one kilo of weight added into the triangle base. That may keep the lamp steady.
Since the advent of LED modules and dimmers, the imagination is the limit to create LED lights.
FYI, all the incandescent lights at my home has been replaced with LEDS that give more illumination than the counterparts, less the energy consumption.
Bravo good design. Thanks Harry.
May I suggest flat head phillips brass screws. I use them a lot in wood projects the brass goes very nicely with most woods. The flat head gives a very clean look.
Another nice looking screw would be the "blackened flat head socket screw. It looks better with the darker woods.
As to the heat sink, be careful when reducing or shrouding the heat sink fins. Air "MUST" be allowed to circulate around and between them.
Another possibility would to design your own heat dissipation system. A large flat plate positioned slightly above the wood, using standoffs, might suffice.
The wax is a very nice idea.
I've use a product from "Watco". It is an oil based product. I learned many years ago to wet sand it into the wood using 220 grit. With a little effort it produces a very nice "feel" to the wood while imparting a nice subtle color. Watco also has a product called Satin Wax that would be applied over the oil finish. This system would be more durable than using just wax. You could apply your wax over that for even a more lustrous finish. Oh, Watco also handles a "natural" finish.
All in all though, a very nice piece of work!
only comments are that it would be nice if you could cut down the heat sink so that it doesn't protude so much. if it could be entirely withtin the thickness of the wood that would be best but i don't know if that's possible. i think if you widened the heat sink recess and used insulated washers so that the heat sink doesn't come in direct contact with the wood, then you could cut back the heat sink. heat rises so you should still get good heat dissopation.
it would also be nice if you could mount the light differenlty so you don't have the 4 exposed screws. i love how clean the knob is and would like the light to have the same simplicity.
nice job!
