The unit was built entirely in my apartment with a hand drill and a rotary tool. I used a small soup can for the boiler and some various hardware store fittings to plumb the system. If your looking to make a little, attractive looking boiler to steampunk up your place read on!
Remove these ads by
Signing UpStep 1: Parts
Note : The vinyl tubing picture DOES NOT work which I soon found out. Silicone is the way to go for the high heat resistance.
Visit Our Store »
Go Pro Today »
without having to use some sort of pump?
I was browsing the internet for good steam projects and man, this one caught my eye. I'm afraid that I may not have any of the materials for this project in my current possession, so naturally being new to this, I wanted to know if you had an estimate to how much this project would cost all together. Where I live we have quite a few hardware stores and hobby shops, but I wanted an idea of how much cash I should have in my wallet before I go running around.
When I saw the steam coming out I thought of a superheated fuel reheating the boiler and the excess being used for a mantel lamp or stove, in other words put fuel in the boiler and use half to heat it, and the other half to cook or produce light.( never mind the fact that that defeats the purpose of driving a turbine.)
Come on isn't the idea of flaming fuel and metal shards blowing in all directions more exciting than just scalding water and shards?
This concept can be seen in the pop can stoves that heat their own fuel and burn quite well on alcohol.
Your soldering seems quite talented so why not but in a smoke stack up the middle and get rid of the wandering flames, maybe a peice of 1/2 copper.
Don't ya just love after the fact advise? Thanks for posting I love these types of projects.
I usually fill the can about half way and shut the unit down when its nearing the bottom of the slight "glass". Filling it more then half will just lead to a longer boil time...no damage is going to ensue if you fill er up, might just get some water coming thru the steam lines if you reach a rapid boil and possibly a smaller area for a good head of steam to build.
Thanks for the kind words :).
I have used a solder that is for 235 degreas Celcius, and I hope this is enough?
I haven´t tried the boiler at full capacity jet because I dont want to do this inhouse. I have used a "saftyvalue" that is orginaly used on Wilesco toy steam engines. I have built it with my multi-knife, and mini-burner when I had all the tools in the boat.. but it worked well. :)
A question - what was the wattage of the electrical soldering iron that you mention please?
I actually only used a butane torch for the soldering work on this boiler. The soldering station pictured in the background of the parts photograph is one I use for electronic work and its the weller WESD51.
http://www.instructables.com/id/Cool-Little-Miniature-Stove!/
would make for a more controlled heat source without too much complexity?
