Introduction: Desktop 3D String Art
About: I love to snowboard, hang out with friends, explore, and have a good time :)
Back in geometry class we used to draw these on paper. I could never remember what they were actually called, but I think they went by "string art". (That’s what came up in a search too)
Basically the Idea is making a curve with straight lines. Usually it's done on paper or 'stitched' onto cardboard. The plan for this one was to make a 3D version that I could hang on the wall or display on my desk. I think it turned out awesome, so I hope you like it and I can get more people to try it also.
Step 1: Supplies & Tools
 For this project you’re going to need a couple tools and supplies.
Tools:
- Drill
- 3/16" Drill Bit
- Pencil (writing utensil)
- Tape Measure, Ruler
- Heavy Duty Stapler (this part is optional you could just use glue alone, you would need something else as an anchor then)
- Saw (I used a coping saw, but any fine toothed saw should work, you don't need to cut much)
- Clamps will be a big help, even more so if you’re just using glue.
Supplies:
- About 4 Feet of 3/4" Screen molding (also sold as plywood edging) this is the wood frame of the project.
- A Roll of String (I used mason line)
- Staples (If you’re using them)
- A Piece of Scrap Wood that’s about 1/2" thick
- Paint (optional of course)
(If I missed anything Sorry it will be somewhere in here)
Step 2: Measure and Cut the Frame
This Part is fairly easy, just take your tape measure and mark out four 9" sections of edging. Once you're done marking it, Take your saw and cut out the four sections. See, that was simple enough.
Step 3: Mark It for Drilling
This step is fairly simple. Start off by making marks every 3/4". I made the first mark on the 1" and the last mark before 8", so there are 10 marks in total. Go ahead and mark the same marks on the other three.
Now, The edging I’m using is 3/4 inch so the middle of it is 3/8". Make that mark on both sides and trace a line down the middle with a straightedge. Now you’re ready to drill it.
Step 4: Vroom Vroom, Drill It
Speaks for itself pretty much, stay on the middle line and drill a hole with the 3/16" bit at each mark. It should give you a fairly consistent line of holes. It doesn’t have to be perfect but if you want to you could use a drill press, I used a regular drill.
You’re drilling all the way through it so drill on a scrap piece of wood.
Step 5: Start Assembling
Ok now you’re going to need that scrap piece of wood. Cut 3 pieces of the scrap that are about 3/4" long (same width as the edging wood).
Now put plenty of glue on the scrap pieces and create the 90 degree L shape (pictures help on this step). If your stapling them now is the time to do it, if not, then you should probably clamp them and let them dry before you do anything.
You should have two L shapes now.
Step 6: Make the "W"
Ok now you should have 2 L shapes. This part is probably the hardest part of the whole thing. Clamps and glue will be your best friend on this one
put lots of glue on the third scrap piece and attach it to one of the L's.
If you’re not stapling them then you should clamp it here and let it dry completely before you attach the next one.
Ok so now attach the other L to the scrap block with plenty of glue. This is the time to clamp everything up and let it dry for an hour or two (overnight is best, if you didn't use staples I would let it go overnight)
Step 7: Strengthen It Up
(You should do this before you leave it to dry)
If you haven’t noticed yet it’s pretty fragile. So what you can do is fill all the gaps with glue. The wood absorbs a lot of glue and it leaves gaps. Fill the gaps with glue. Then let it dry.
Step 8: Paint It (optional)
Now that the glue is dry, if you are going to paint the frame now's the time.
I went with a glossy black; you can go with whatever color you want. I think neon colors would look pretty sweet.
Step 9: Time to String It
This is the time consuming step. You’re going to need lots of string.
There is two ways you can do this, you can string the whole thing in one consecutive piece or you can do 10 separate strings. I did it in one consecutive string. So that’s what I'm going to show you how to do.
Start by pulling out A LOT of string (25 feet or so), there would be nothing worse than stringing the whole thing and then being 5" short at the end. I used just shy of 25 feet of string, it's way better to have extra.
Ok now, pick one side and anchor one end of the string. I did this by tying a loop knot and stapling the knot. (Picture might help)
Now you got to start threading everything. Start at the top hole and string it down to the closest hole at the bottom, pull it all the way through (yes this takes some time). Now take the end and thread it through the next hole out to the next highest hole, and pull it all the way through again.
(Yes this is somewhat confusing, the picture helps)
continue this pattern until you got the first 'L' stitched up.
After this it gets a little trickier the next step explains it.
Stringing Tip: If you hold the tip your threading with while you pull everything through, the line will never actually knot.
Step 10: Just Keep Stringing...
Once you finish the first one it gets a little tricky. You’re going to start sharing the holes. Same threading idea just takes a little bit more work.
Ok so now you are done with the first "L". To get the string to the next L thread in through the top hole of the next 'L' (see picture) and then just keep going with the same pattern.
The pictures really do a better job of explaining, it’s kind of complicated. Look at them ;)
once you finish the second ‘L’, the third 'L' is just like doing the second L. Go from the end of the second L and thread to the hole at the start of the third L.
this is the same thing as going from the first one to the second 'L'.
If you are still super confused leave a comment with your question and I'll try to help out.
Step 11: Finishing Up
Yay! Now all three L's are done! You could just staple it and tie it off right next to the hole but I wanted mine to look the same on both sides. (Well sort of). So I pulled everything tight and wrapped it around to the top and I anchored it there.
Now, go display your work of art on your desk or wall!
Krylon Summer Projects Contest
Finalist in the
