Introduction: Desktop CNC Machine
Picture of Desktop CNC Machine
This is a CNC machine made out of left over parts from my schools robot build.  The only thing we paid for was the circuit board to run it.  Grand total of about $70.  This was made with no directions, all of it was trial and error.  This should get you started if you want to build one.
Step 1:
Picture of
1.  I started with an aluminum base (19.25 wide, 13.5 deep and .25 thick)
2.  On to that is mounted the two uprights (10.25").
3.  And in between is the cross brace (16.25")
4.  Also mounted to the base is two pieces of 1.5" aluminum angle which two 24" full extension drawer slide are mounted to for the Y   Axis.
Step 2:
Picture of
5.  We used Accuglide rails and slides for the X and Z Axis.
Step 3:
Picture of
6.  For the X the slide rails are mounted to a piece of aluminum (3 x 19.25 x .5)
7.  The X axis gets mounted to the two uprights.  It is adjustable the way we did it, so we can adjust for our dremel travel.
Step 4:
Picture of
8.  Next I made the Z axis slide.  Its another piece of Aluminum with the slide rails mounted to it.
9.  We made some 1" x 1" x .5" aluminum blocks for spacers for the Z axis.
10.  Those are put on and it gets mounted to the slides on the X axis.
Step 5:
Picture of
1.  Next I made some mounting brackets for the motors.  Its kind of hit and miss with these.  You may have to make a few before you get all the clearances you need.  I made these out of 1/8" aluminum.  X is just a flat piece, the Y and Z are 1/8" aluminum with a 90 degree bend.
12.  The X gets mounted to the same piece of aluminum that the X slide rails are mounted to.  That way the motor moves up and down with it if it needs to be adjusted.
13.  The Y axis is centered between the two drawer slide and screwed to the base.
14.  The Z is mounted to the Z axis.  you may need spacers to get the right distance for clearances.
Step 6:
Picture of
15. Next i cut some 1/4" threaded rod close  to the lengths I needed.  On to one end I put a bearing on the rod.  We got the bearings from some old VCR's.  There are two bearings in the video heads of the VCR that fit the rod perfect.
16. You need to put one bearing on the end of each axis rod.
Step 7:
Picture of
17.  Next I made some steel brackets that the coupler nut is welded to, it makes the different axis move when the motor turns.
Again this is hit and miss, you need to measure you machine for sizes.
Step 8:
Picture of
18.  After those are made you can start to mount them.  I started with the X axis.  I threaded the bracket onto the X rod and attached it to the motor with some plastic tubing we had.  The tubing actually works really good.  It threads onto the rod and fits tight on the motor shaft.
Step 9:
Picture of
9.  The other end of the X axis is held in place by a bracket mounted to the upright, and the bearing is held to that by some self tapping screws.
20. You need to screw the X axis coupler bracket to the Z axis so it can move back and forth.  You need to drill and maybe counter bore your holes so you have clearance and check to make sure the screws are not in the way of the X axis rod.
21.  The Z threaded rod is held onto the motor with the same tubing as the X.  Thread the Z coupler bracket onto the Z threaded rod and mount that to the motor.  The bearing is held in place with a few screws again.  The bracket will be screwed to the slides along with your tool holder.
22. The same goes for the Y axis under the table top.  Bearing is held with some self tapping screws.
Step 10:
Picture of
23. The table is just a 3/4" piece of MDF plywood.  There are two pieces of aluminum angle screwed to the edges of the MDF.
Then the two drawer slides are screwed to those.
After you get the table ready, slide it in and make sure it slide back and forth OK.  Next you screw the Y coupler bracket to the back edge of the table.  And screw the bearings in place.
24.  You should have the motors and all the brackets mounted.  Next is hooking up the wires.
Step 11:
Picture of
25.  We used a 3 Axis TB6560 CNC Driver Stepper Board Controller 2.5A.  We bought it off ebay.
26.  The instructions tell what color wire goes where and also what your pin numbers are for the parallel port.
Step 12:
Picture of
27.  We used AutoCAD and AutoCAD inventor to draw things up.  Then we used Visual Mill, and Lazy Cam to generate the G-CODE.  Visual Mill is FREE and works great.
28.  Mach 3 is used to load the G-Code into and run the machine.  Mach 3 is free, but you can only run so many lines of code.
29.  You need to calibrate to machine.  Each one will be different, depending on your motors degree per step, and size and number of threads on the rod.  I put screen shots of all the settings I used in Mach 3.
30. You can add limit switches and home switches if you want them.  I would recommend an E-STOP button on the machine just in case.
31.  After it is calibrated, you draw something up, save it to the right file format, and load it into your g-code and tool path generator.  That was Visual Mill or Lazy Cam for me.
32.  Those programs will generate the G-Code.  It will be a .tap or .nc file.
33.  Load the G-Code into Mach 3 and do a dry run first.  After you are sure it is ready try a test piece.
Step 13:
Picture of
34.  WEAR SAFETY GLASSES!!!  The bits do break.
35.  After a little trial and error, you will get it.
There is a picture of a scorpion the CNC routed out with red LED's to light it up!!!
richard westerfield (author)2017-02-09
no parts list no good for me
BruceF34 (author)2016-11-05
Looks good .
Is that a Dremel...
Nice sturdy frame.
Thanks
Divljina (author)2016-01-02
Hi friend, your project is good :)
Can you tell me, do you know where I can find electrical scheme of driver Toshiba tb6506 ? Thank you in advance
prosperer888 (author)2015-07-23
Great instructables, i found stepper motor, stepper motor driver and psu on here http://goo.gl/zT0D7b is it good deal?
ace101193 (author)2013-08-13
Could you specify what accuglide rails and slides you used and there size
Benjamir85 (author)2013-05-05
ohh genius
krissh0009 (author)2013-03-01
Sir please provide the information about
25. 3 Axis TB6560 CNC Driver Stepper Board Controller 2.5A wiring.
am using 6Lead nema23 287oz-in stepper motors......,Thank you.
My mail id is: krissh0009@gmail.com
AtomRat (author)2012-11-20
Great CNC 'ible! I have looked for these 'square' stepper motors for almost 2 years and unsuccessfully found none. So I guess I will have to ebay for them. If I am to make this project by buying the electronics on ebay ( if I can find them ), what would the project cost roughly be if you know?
anoniemouse (author)AtomRat2013-01-06
Try
http://www.homecnchobby.com/
I used their motor 7 board for one project.
Not ardino abut you could build the thing and learn abit .
jacobsbr (author)AtomRat2012-11-20
Found my motors on ebay a couple years ago. Not sure on the total price, but I will try to get something together. Almost everything was in a junk pile or scrapped off old equipment.
AtomRat (author)jacobsbr2012-11-22
What were the motors scrapped off? I collect heaps off piles, bin jumping and tip visiting, but have never found them. Or were they just a lucky one in the scrap bin. I can make up an estimate price now that I know what the motors are called anywho.
liam2317 (author)AtomRat2012-11-26
You can find smaller stepper motors in many printers, fax machines, and scanners.
astroboy907 (author)AtomRat2012-11-21
I think you are looking for Nema style motors
http://reprap.org/wiki/NEMA_Motor
AtomRat (author)astroboy9072012-11-22
Thank you, exactly what I am after. This will help with my searches
pfred2 (author)astroboy9072012-11-21
NEMA 23 usually 17s are small and 34s are big. Oh, and make your NEMA 23s double stacks too.
pfred2 (author)AtomRat2012-11-20
There are a few specs that affect stepper motor performance. There are lousy square stepper motors too. You want motors with low voltage and inductance ratings, high current doesn't hurt either. Oh and bipolar. Unipolar motors are meh, they work, but they're not nearly as good as bipolar ones.
melissap01 (author)2012-12-31
Thanks for sharing This Articles and Photos,Happy to read This Article learning the How To Buy the Used CNC Machines
AtomRat (author)2012-12-07
Thanks, I've been wondering if I could use those motors as well. I have several hundreds of printer, scanner motors. I just did not know if the bigger ones would support it and did not bother to test them until I got an answer, so thank you heaps :)
useraaaaa (author)2012-11-20
I wana convert Cricut to cnc router... i cave cricut personal and SCAL2 so i can cut any .svg design...
hey guys if it is "simple", may you sell me one
aidanjarosgrilli (author)2012-11-20
EPIC!!!!!
About This Instructable
175,591views
969favorites
License:
Bio: Love Tinkering :)
More by jacobsbr:Military Challenge Coin ShowcaseDesktop CNC MachineRobot Capstone Project
Add instructable to:
