Introduction: Desktop Decepticon: a Transformers Maquette
After really enjoying the first Transformers movie, I wanted to try and make a little Transformer model but didn't get round to it. Once the second movie came out I thought it was about time to follow through on the little sketches I'd done ages ago.
The idea came from the scene near the end of Transformers 1, where a phone gets fried with some Allspark energy and turns into a Decepticon. Now I'm not a diehard Transformers fan but I did grow up on the 80s cartoons and I have to admit, while the movie renderings of the Autobots was incredible, I was dissapointed by the unrecognisable, spiky decepticons. So, here is my little interpretation of what I think the Decepticons could have looked like in the live action movies.
This little Decepticon is made from an old Motorola V600. Before I go any further, I have to say that unfortunatly, this model does NOT transform back into a phone! It's got a bit of articulation, but that's as far as it goes!
Step 1: Gathering Parts and Planning
When it comes to a project like this, one made from re-using existing components instead of starting from scratch, it's important to try and figure out what you want to achieve with the basic parts you've collected, before you start cutting and gluing. This particular phone was a lucky choice to use, as it has an aluminium shell, and lot's of separate components, perfect to hack up into bits of transformer "armour"
I had a couple of VERY basic sketches and knew, for example that I wanted to use the phone's keypad as the breastplate for the transformer.
That said, once the basic skeleton was conceived, the rest of the time was spent making bits up as I went along! You'll notice the evolution of the head as the photos progress, he had at least three heads until I settled on one I liked!
Step 2: Beginning the Build
Step 3: Shoulders and Arms
Once this was done, I cut four pieces of 4mm aluminium rod (from BandQ) with a junior hacksaw. Then used a glue gun to attach the rods into the shoulder sockets, and into a pair of "hands free kit" headphones that I gutted then glued back together. These acted as the elbows and the forearms.
I then started to cut the aluminium shell into appropriate sizes to use as the Decepticons arm armour. I used a demel with a cutting wheel to cut the aluminium. (wear goggles!)
Step 4: Torso and Hips
The phone's keypad is a selection of plastic buttons attached to a rubber base, this makes it nice and easy to bend into a "torso" shape, but pretty tricky to glue into place. In the end I made small holes in the rubber, and used very thin wire to almost tie the keypad onto the skeleton. I then added a strip from the back of the phones cover to the middle of the chest to add to the armoured look. I used the rest of this piece to bulk out the back a bit.
Step 5: Legs and Feet
In this shot you can see the wires of the superbright LED I've placed behind the old keypad. It stands about 7 inches tall.
Step 6: Fitting the Electrics
The first shot here shows the parts before they are secured on to the model, the second shows them fixed into place, as well as painted black, to make them a little less obvious.
Step 7: Finishing the Build
Step 8: Completed
The photo below with the black background shows the model with the light switched on.
