3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Desktop Fan
Desktop Fan
In this instructable, i will show you how to make a fan for your desk out of things you might have aroung your house.
Step 1Step 1: Gather Parts
  • last photo ←
You will need:
Computer fans
Hot glue gun
Hot glue
Solder
Soldering iron
Solder
Toggle switch ( see picture )
Posicle sticks
DC adaptor
Wire
Resistors and LED ( see picture )
Your hands
Cable ties
20 comments
Jan 27, 2012. 2:52 PMMrJentis says:
Cool. This is basically the same idea I had for my desk fan. I built it before I saw your setup. I guess what they say is true, "Great minds think alike." Here's a link to mine http://www.instructables.com/id/Emergency-Fan-Power-Unit-EFPU/
Oct 16, 2009. 11:46 AMelectronic boy says:
lol ausome!!
Oct 10, 2009. 12:25 PMsharlston says:
are you from the uk?
great ible
Jun 10, 2009. 1:17 PMgrundisimo says:
where did you get all of those?
May 3, 2009. 7:47 PMNikonDork says:
Or you could remove the LED from the circuit all together. A power indicator LED is unnecessary, because you can pretty much tell its on or not by looking at it.
May 5, 2009. 12:19 AMNikonDork says:
So the LED stays on whether the fan is running or not? Cause if it doesn't, then I didn't misunderstand you and its redundant cause you can see with your eyes if the fan is moving or not.
May 4, 2009. 1:12 AMlemonie says:
It's not very clear what you're doing with the resistors, but if the ones I can read stripes on are what they look like I think you've used too little. Can you clarify what resistors you have on the LED? Also steps 12-15 could be replaced by just 1 without the massive graphic L
May 4, 2009. 2:17 AMlemonie says:
You probably want 500 to 1KOhm, see what 1K does and go down from there if it's too much. L
May 4, 2009. 2:09 PMlemonie says:
Aye, but what did you use - one of them looked like a 220 Ohm, and wired in parallel with the other you'd have less than 100 I think?
L
May 4, 2009. 11:41 PMlemonie says:
Was a bank holiday - I was doing things around the house most of the day. No it's not better to have these resistors in parallel for this application (as you've discovered) L
May 4, 2009. 12:24 AMamayer says:
I don't really see how this is useful. Perhaps if it had variable speed or an visually pleasing housing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:XOIIO
i enjoy inventing, taking apart electronics, and rebuilding them. i also have a hobby of creating batch files, i greatly enjoy programming batch. i also enjoy coding and decoding binary code.
