Destiny Warlock Bond Kit Assembly
Introduction: Destiny Warlock Bond Kit Assembly
Instruction on how to assemble and finish Destiny Warlock Bond Kit available at my store. I have a few variations of warlock bond but the method technically the same.
Materials Needed :
  • Warlock Bond Kit
  • Contact Glue
  • Sealing material . Can be either PVA glue, Latex glue, Plastidip
  • Spray paint
  • 9v battery
  • Hot glue gun
Step 1: The Parts
This is how the warlock bond kit looks like. The bond made of foam. The armband , smaller pieces and the acrylic part.
Step 2: Assembly
I personally prefer to use contact glue but you also can use superglue or hot glue. Glue the smaller strips to the armband. if you use contact glue , apply on sides that will be glued together , leave it to dry till its tacky and carefully attach them together.
Step 3: Adjusting the Armband Size
The armband was made to be bigger so you can adjust it yourself. Simply measure how much you need to cut. Use a sharp x-acto knife to cut it to desired length and glue the ends together
Step 4: Sealing Your Warlock Bond
Foam cant be spray/painted directly. You will need to seal the piece first. Sealing it will create a thin layer of film that the paint can stick to. You can use either pva glue, latex glue, wood glue, plastidip . In my case, i use latex glue. Carefully seal the armband at least 3 layers.
Step 5: Painting
Wait till the sealing has fully dried. Let it dry overnight to be sure. You can use spray paint or normal acrylic paint with a brush. You can use whatever color you wanted or follow the reference picture.
Step 6: Putting It Together
Some of the warlock bond kit has a 3d printed base for the acrylic part. So you just need to hot glue the bases together. For this Bond of Exile, it doesn't have one so you will need to glue the foam piece together.
Step 7: Acrylic Part
You have to tear the plastic protective cover from the acrylic piece. Start from the edge and work you way thru.
Step 8: Battery
Plug in a 9v battery to the connector and you are done !
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
