3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Desulfator for 12V Car Batteries, in an Altoids Tin
Step 4Smoke Test 1 - pots instead of fixed resistors for R2 and R4
It's time to test your handiwork!
For those of you who used fixed resistors for R2 and R4, skip this step and go on to the next step, Smoke Test 2.
For those of you who used pots instead of fixed resistors for R2 and R4:
First, turn off S2, put a 555 chip in its socket and a 2A fuse in the fuse holder. Set the pots to their mid-range and attach the plus lead clip of your circuit to the plus terminal of a 12V battery. Attach the ground lead clip of your circuit to the minus probe of a multimeter, and set the multimeter to the 10A AC scale. Briefly touch the plus probe of the meter to the minus terminal of the battery. Check for smoke. No smoke? Good! Try it for 5 seconds, then 10 seconds. Still no smoke? Great!
Check the 555. Hang a scope probe (if you have one) on pin three of the chip and check for pulses. Adjust R4 for peak output at around 1000 Hz (the exact level isn't critical).
Now check the output stage. Turn on S2 and briefly touch the plus probe of the meter to the minus battery terminal. You should see a brief spark and hear a faint 1000 Hz tone come from the coils. The LED will turn on in the presence of output pulses. If it doesn't, but you hear the tone, then the LED may be mounted backwards. If you don't hear the tone, or see smoke, then something is wrong and you'll need to check your output stage wiring.
If the fuse blows try adjusting R2 down a bit (the direction of turn depends on how you have it wired). Smile when you get the meter reading below 0.8A -- you're almost there!
If all is good then adjust R2 so the meter shows no more than 0.7A on the AC scale. This should yield a good output into the battery without overheating the output stage. Finger test the coils, C4, FRED, and the FET. If all are no more than slightly warm after 30 minutes then you're in the clear. You can SLIGHTLY increase the pulse width and the current into the meter a little at a time until the circuit reaches about 1.0A but at this level my charger won't flip into trickle charge mode because the combined currents of the circuit and charger are beyond its trickle threshold. I therefore keep it at around 0.7A. Anything beyond 1.0A gets a bit too toasty after a night's use anyway. Also note that the circuit will tend to consume 0.2A to 0.3A more current and get hotter when the charger is on high charge rate. It's therefore best to stay at or below 0.7A to prevent the current from getting too high as the charger adjusts its charge rate from high to low. Be conservative, especially with an undercharged battery because as the lead sulphate crystals dissolve into the electrolyte the battery voltage climbs and this increases the current and the heat dissipated by the output components.
8 comments
Jun 26, 2009. 11:32 PMrudyg says:
Thank you for the tips! After verifying all the points you raised, I replaced R2 with a variable resistor and found that even at 20 us pulsewidth Q1 still got hot. So I installed a pair of FETs to give me a bit more time per power-on period. Low and behold they both got hot, even at 20us pulses. So I began to ponder my layout (parts placement) and first suspected that perhaps the chokes were causing some feedback to the power on the 555. I separated the power supply connections and separately supplied the 555 with its own power. While doing this I noticed that I could make the waveform on the FET drain look either clean (only pulses) or very noisy (no defined pulses), just by either applying power first to the 555 and then to the chokes and vise versa. This way I found the source of my problem. There seems to be a nasty incoherent mechanism going on where the FETs are just thrashing around non stop whenever power reaches the 555 just a bit later than the chokes. In this mode the power goes through the roof! This made me remember a piece of info where someone discovered that there was a power delay issue between the chokes and the 555 and the fix was to reduce C1 from 100uF to 10uF to shorten the delay for power stabilization on the 555. I will try that next (the 470uH choke I added in the same power feed might even contribute more to the delay...hmmm). Sure hope I don't have to sequence the power. Any thoughts/insights? Thanks for any feedback. Best Regards.
Jun 28, 2009. 11:56 AMrudyg says:
Yes, I have the zener installed. Mine is 14.1V.
I was able to solve my problem.
I determined that the timer consistently went into an uncontrolled oscillating state whenever power was applied simultaneously with the output stage (normal power scheme). When I separated power from L1 and only supplied power to the 555 section (open connection between R1 and L1), it always started up normally.
Concluded that some noise made its way from the output stage to the timer in my specific layout of the circuit.
As I said in the beginning, I additionally placed a 470uH choke for extra protection between L1 and R1. Now I had reason to think that this might contributed to the problems in my circuit, so I removed it.
Next, the reset pin on the 555 timer had to be separated from pin 8 and now has its own 100 ohm resistor with a 100uF capacitor.
Finally, I replaced C1 with a 10uF value.
This then altered the power up scheme of the timer such that the faster time constant via C1 = 10uF allowed pin 8 to stabilize while pin 4 was held low for a bit longer, with its longer time constant resulting from the new 100uF capacitor I added. So the chip is held in positive reset during power up.
No more oscillations. Circuit works very stable now and I was able to go back to just a single FET without it getting hot.
One curious thing, though. I had to reverse the polarity of my LED to work in the circuit. When I look at the voltages on D2, then I see +12V on the cathode and +12V with negative pulses on the Anode (FET switching on and off). So the cathode of my LED has to be placed toward the anode of D2.
Since I can not see very narrow voltage spikes on my small scope, is there any noteworthy effect of the LED circuit on the performance of the desulfator?
Thanks for all your comments. It helped me get on the right track.
Best Regards.
Jun 30, 2009. 11:23 AMrudyg says:
I am still trying to see what I can measure with my Velleman HPS10 scope. At $120 you can not get too demanding. Still trying to get used to it. It has a sample frequency of 10 MHz, giving me 100 ns resolution. I also use a 0.1 Ohm resistor in series with the negative lead for this measurement. Would you be able to let me know at what resolution you see the spike on your scope? On another note: I measured my AC current per your step 5 and it is 0.8 A. I assume this reflects the RMS value of whatever current the circuit puts out? Trouble is that converting this to peak value does not get you there, presumably due to the narrow pulse width the "spike" has. Also, just to clarify, no charger is connected for these readings, correct? My DC current draw is 95 mA. This is somewhat higher than I expected since the 555 should only draw about 16 mA max. Not sure if I am seeing some component of the circuit's AC action here? Any comments on this? As always, thanks for your thoughts! Best Regards.
Jul 9, 2009. 12:12 PMrudyg says:
Hello again, Thanks for the clarification, I realized what you meant. As for my project: I reduced the pulse width from 60 us to 50 us, which lowered the current some. I also replaced C4 with two 50uF caps in parallel and placed a second diode in parallel with D2 (I am using RHRP3060's). This gives me enough wattage capacity to avoid overheating when engine temps max out in 120F summer weather. I have the circuit running now for two weeks on a bad battery and monitoring the "peak voltage" every other day or so to see what happens. In retrospect, since I am using the larger toroids (J.W. Miller series 2300), along with the faster diode RHRP3060, my instantaneous current is likely larger and thus no surprise that D2/C4 were getting a bit warmer. (note: although not a perfect current sharing solution, paralleling these diodes will still provide some offloading as compared to a single device) So, for now I am in the monitoring stage to see what happens with my dead battery (was only holding some 10.5 volts when I started). Had to do some scrambling to find a circuit for measuring the so-called peak voltage. Still not sure if it is the right approach, but going by what others have suggested (www.frontiersprings.com). Not sure what the "correct" peak voltage is that would indicate a healthy battery. Any input? Thanks as always, and Best Regards
Jun 25, 2009. 10:45 PMrudyg says:
Hi, I wonder if you can share some insight into a problem I'm having. I built this circuit from a schematic a fellow by the name of Ron Ingraham published some time ago. It is identical except it does not have your switches and other useful notes attached. I am pretty good at building stuff like this, but from the first moment I turned it on, my FET Q1 blew instantly. I deviated on this build as follows: For the inductors I used the J.W. Miller series 2300 toroids. L1- 1000uH, 2.4 IDC, 0.3 Ohm L2- 220uH, 5.8 IDC, 0.054 Ohm I added a 470uH inductor between R1 and the point where L1 is connected as additional protection for the 555. After re-checking the cicuit and replacing Q1, I disconnected the output stage and verified that my timer portion was fully functional, nice 60us pulse on the gate of Q1, with 940us between next pulse. Temporarily re-connected the output stage while holding my finger on Q1 and within 1/2 sec it was too hot to touch, aborted. I would sincerely appreciate if you could help with most likely "suspects". Best Regards.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:kmpres
