Step 4Working on the electronic of the mount;
iImage Information
In the pictures below you will see the other side of the mount. The battery the I used is a 9 Volt battery. I took an old battery apart to be able to use the top of it so that I would be able to unhook it when it needed changed. I also installed the switch at this time. I had to use a piece of plastic to make the mount for the switch. The last part was the plug that I needed for the camera. I use the plugs from a mother board and the plug from an earphone to make that hook up. The wiring was pretty easy. I put one lead from the battery to the switch and from the other side of the switch to one side of the earphone plug. Then I put a wire from the other side of the battery to the other side of the earphone plug.
