Detect Temperature and Humidity With Raspberry Pi and HTU21 / SHT21
Published
Introduction: Detect Temperature and Humidity With Raspberry Pi and HTU21 / SHT21
About: Software engineer and open source enthusiast
Wondering what's the weather? Let's check it out with your Raspberry Pi! This tutorial provides step by step instructions how to detect temperature and humidity with the dirt cheap I2C sensor HTU21D and open source code on your Raspberry Pi.
If the embedded video does not appear on your mobile device, here is an alternative link. If you like this tutorial, please subscribe to my YouTube channel, give a star to the project in GitHub and have a look at my Instructables and videos.
Step 1: Getting Ready
For this tutorial you need the following hardware components:
  • Raspberry Pi (any model or version)
  • HTU21 module
  • Breadboard
  • Male to female jumper wires (x4)
  • microSD card with Raspian GNU/Linux distribution
  • Power supply
HTU21 (or SHT21) modules are popular for hobby electronics. In general they are available for less than 5 USD per unit.
I have a couple modules here. They have different colors but the sensor is actually absolutely the same on both modules. Beware that the other physical difference is the position of the lines for data and clock. I am going to use the blue HTU21D module for the rest of the tutorial.
Step 2: Wiring
The wiring is simple and takes less than a minute. As shown in the video, using male to female jumper wires connect VIN, GND, SCL and SDA from HTU21D to pins 1, 9, 5, 3 of Raspberry Pi.
Step 3: Installing Software
Boot your Raspberry Pi with Raspbian GNU/Linux distribution, open a terminal or login via SSH. Execute the following commands to download and install the required packages:
sudo apt-get update
sudo apt-get install git build-essential i2c-tools
Step 4: Enabling I2C
  1. Type the following command in a terminal:
    ​sudo raspi-config
  2. Select Advanced Options > I2C
  3. Follow the on screen instructions and reboot Raspberry Pi to compete this step.
Step 5: Reading Temperature and Humidity
I have published free and open source example for reading temperature and humidity on Raspberry Pi using HTU21D. They are available in GitHub. Perform the following steps to use it:
  • Get the source code from GitHub
    git clone https://github.com/leon-anavi/rpi-examples.git
  • Build the example:
    cd rpi-examples
    cd HTU21D/c
    make
  • Run the application:
    sudo ./HTU21D_test
  • The temperature and the humidity will be printed on the screen
  • Enjoy!
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
  • Planter Challenge
    Planter Challenge
7 Comments
Thanks for the project. I have mine working but it is returning values of around 41 Deg C and RH of 78% these values are wildly wrong almost double anyone else see this?
You are welcome. I am glad that the tutorial is useful. I am sorry that you have an issue with your sensor. Double check that you are using properly the examples for reading the data from the sensor. Also please consider checking with another sensor because something might be wrong with the hardware in your sensor.
Hello
Something is wrong, I have the same problem
first sensor read T 44,36 Hum. 84,20
another sensor T 44,06 Hum. 86,23
in the room is T 22 Hum. 64
Hello.I have one question.What does this line do?
unsigned int temp = (buf [0] << 8 | buf [1]) & 0xFFFC;
Retrieves the temperatures according to the datasheet of the I2C sensor.
Thank you!
