3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Detonators (Blasting Caps)
Detonators (blasting caps) can be made from a used small arms cartridge case and field-manufactured explosives. Detonators are used to initiate secondary high explosives (C-4, TNT, etc.).
This destructable was "borrowed" from The Army's Improvised Munitions Handbook, courtesy of Steal This Wiki.
As the views break 2050, I would like to thank you all for reading, it makes me feel useful. =P
Be sure to read the warnings.
Legal Disclaimer: THIS INSTRUCTABLE IS FOR ENTERTAINMENT PURPOSES ONLY, DO NOT USE THIS ARTICLE TO BLOW THINGS UP, AND BY READING THIS INSTRUCTABLE YOU AGREE THAT I AM NOT LIABLE FOR ANYTHING YOU DO WITH THESE BLASTING CAP(S).
Step 1Materials Needed and Primer Removal
Remove fired primer from a used cart ridge case using a sharpened nail.
37 comments
Jun 9, 2009. 6:22 PMmacgyver603 says:
I would also like to know if black powder or smokeless powder could be used as a primary explosive in the cap.
Jan 25, 2012. 6:08 PMattemptmischief says:
no it can not u need a more sensitive hex peroxide mixture
Jun 10, 2009. 10:00 PMTenz says:
i think all it has to be able to do is ignite the booster and your g2g the use for balsting cap is to ignite a substance that need a hotter burn that reg black powder cuz most fuses use black powered
Jun 16, 2009. 5:25 PMrecyclebin says:
thanks i just made a batch of plastique and am in need of caps
Jan 25, 2012. 6:05 PMattemptmischief says:
sweet how did u make that blasting caps are easy
May 23, 2011. 11:44 PMbenduy says:
DAWINISM
Jan 24, 2011. 4:34 PMHmff says:
Um the chaseing need to be discharged first?
Jun 20, 2009. 7:08 AMlouis_haeb says:
This is insanely dangerous! Basically, you hold a metal cartridge in hand while you ram HE's in it? I didn't know military don't like to have their fingers. It's a chance you posted it only for informational purposes. But, I wouldn't be surprised if some k3wl went and tried it. Darwin Award!
Oct 30, 2010. 7:43 AMMasterMind555 says:
This is millitary, you have the choice either to blow all your enemies up, risking your hand, or go attack them and get shot, risking your life, concidering that, it makes sense
Dec 25, 2009. 8:20 AMColonel88 says:
This tests your stupidity. If you go ahead and do this, you will obviously die because you did not use your common sense and are not smart enough to do this safely hence in a battle or any other dangerous situation where others depend on you, you will only slow down the pros.
Aug 20, 2009. 4:51 PMCountry dude says:
first of all this book was made for the military will out on the field so not everthing is strictly safe and secondly its hard to detonate BP by hitting it
Jul 16, 2009. 11:06 PMTombini says:
If it's shock sensitive like AP then you must take precautions, or you could just not ram it... Anyway explosives are inherantly dangerous so safety is paramount
Jul 4, 2009. 10:42 PMabadfart says:
its like packing a black powder rifle
Jul 6, 2009. 2:19 PMlouis_haeb says:
Black powder is far less sensitive than RDX or Picric acid. Picric acid, in example, is highly sensitive to friction and shock and can be ignited by a spark, a flame, heat or just a bright flash of light. Compare that to BP.
Oct 30, 2011. 11:58 AMpastaking says:
Idea: Camera Flashgun detonation system.
Get a cheapo flashgun and a wireless camera flash hotshoe. Put the explosives near the flashgun, and trigger.
You saw it here first.
(In hindsight, this is probably not the safest idea, but oh well)
Jul 14, 2009. 12:18 PMabadfart says:
ya but this is why you don't use mettle to pack it
Feb 1, 2010. 5:26 PMmr. clean says:
that munitonsbook is the best book ive ever read, its a pyros dream
Jun 6, 2010. 10:57 AMMrMadmonkey4 says:
cool :D
May 13, 2010. 6:14 PMcorey_caffeine says:
looks like a certain handbook i know of.
Aug 2, 2009. 5:52 PMgameboy7oa says:
Humm I believe I own that book.
Aug 7, 2009. 6:39 PMgameboy7oa says:
Yep Yep
Aug 12, 2009. 6:30 PMgameboy7oa says:
I was cleaning out my basement and it was just chilling there covered with dust and i took it. :)
Jun 9, 2009. 10:34 AMmacgyver603 says:
Where did you get all of this information?
Jun 9, 2009. 10:47 AMTenz says:
i think i recognize these pictures... i might be the army improvised munitions handbook if not a military manual from some where cuz the illustration styles and font is the exact same
Jun 9, 2009. 10:49 AMTenz says:
if i am wrong i would like to know as well
Jun 10, 2009. 1:32 PMzekiller2193 says:
I think ur right, probably the Tm 31-120 book. Free copy on internet here
http://onlinebooks.110mb.com/tm%2031-210/31-210-contents.htm
Jun 11, 2009. 8:03 PMmacgyver603 says:
That was an interesting book. Thanks for the link!
Jun 13, 2009. 3:06 AMmattykoose says:
Yeah, pretty sure you should state this isnt your work, as it Is a cutout from the "improvised munitions handbook"....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Gamernotnerd
