3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Developing Black & White Photo's at Home
Step 5Loading the film spool
THIS STEP MUST BE DONE IN TOTAL DARKNESS!
The film you will be taking out of the cannister is still reactive to light, any light you let onto the film until it is fully developed will expose the film and all your pretty pictures will turn out white.
I do this step under my covers in my room with all the lights off and the windows closed and at night, if anybody comes into your room/threatens to turn the lights on just scream "I'm having some happy alone time!!" at them, and upon seeing you furiously scrabbling under your bed sheets will generally make a swift exit.
The film spool has a clever little mechanism involving small ball bearings so that when you twist it one way then twist it back the film will advance onto the spool and be pulled out the canister. You may have to manually pull a length of film from the cannister to get it started, but once its got going things generally get easier. Once all the film is loaded onto the spool and out the cannister take a pair of scissors and snip the cannister off the end of the film.
This takes some getting used to, especially because you will have to do it in darkness, I recommend sacrificing a film to practice with in the light first, then try with you eyes closed, then give it ago in total darkness.
Also make sure you only touch the film by the edges when you are doing this otherwise you can scratch your negatives.(the third picture is an example of how nasty this can look)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:}{itch
