Step 9Devloping and fixing
For me the developer took 14 minuets and the fixer took 2 minuets.
When all your chemicals have reached the correct temperature take the developer and pour it into the top of the developing tank, knock it sharply on a table and this should dislodge any bubbles clinging to the film.Leave this to develop for the correct amount of time, shaking the developing tank for 20 seconds every 2 minuets (At this point the more you agitate the developer the higher the contrast of the image, so adjust this to your wishes)
Once the time is up pour away the developer out the top of the developing tank and fill it full of water and pour it out a couple of times, then leave the tank under a running tap letting cold water go into the top for 10 minuets.
Pour all the water out the tank and then pour in the fixing solution, tapping the tank on a table sharply to remove any bubbles again. Then leave it until the correct amount of time has passed and pour away the fixer. Then rinses out the developing tank with cold water a couple more times.
The film is now developed and you can open your tank to remove your brand spanking new and shiny negatives!
What can I do?!
Pour your used fixer and developer into a container (with a lid) that can be easily transported by automobile. Take the container to a photo lab (or even a pharmacy with a one-hour lab) and ask the lab tech for it to be dumped in the Waste or Silver Recovery unit. Don't ask a cashier! If you can, call ahead and ask for the lab supervisor.
If they ask questions:
Say you do your film at home, that it should be safe to pour in, they can ask their supervisor, and it's more money for them because of the silver it contains. The people aren't giving you a hard time, there is often all sorts of warning signs about mixing chlorine/bleach containing chemicals, with another type of chemical, that is all Greek to them. Be patient and let them double check, it's worth it for the environment.
Why?
The unit at professional labs zaps the waste with electricity and using magnets collects the silver and the rest goes down the drain. Not only does the silver not make it into the water supply, it is saved in large canisters which are picked up for recycling!
In the United States: Both Federal and State government agencies regulate the handling and disposal of photographic chemicals. For more info on proper disposal of photographic chemicals, see here (PDF).
Additional Notes: Don't develop film in the kitchen where you eat! These chemicals are toxic. Also, don't eat during the process! Don't pour chemicals down the drain and don't let them make contact with older porcelain it WILL stain any porcelain the finish has worn off of. If this does happen you need to find "Farmers Reducer" and scrub it with a brush, it'll take some elbow grease (Powdered cleanser with bleach might work too).
