Introduction: Devil Themed IPhone for Halloween
This is just a bit of iPhone fun for Halloween and is super quick and easy to do :)
of course, this will work on all phone brands, mu haaa haa haaaa
Step 1: Get Started
to do this you will need the following:
a phone
sugru
scissors
dry tissue paper
You will need just half a mini pack to make this so line up another project so not to waste any sugru
Step 2: Making the Horns
You will need just 1/4 of a mini pack of sugru for each horn.
Roll the sugru into a cone shape.
Press the cone firmly onto the corner of the phone, making sure that the sugru bonds to the surface.
Once you are happy that you have positioned the cone correctly, you can shape the cone into a horn.
Step 3: Leave to Cure
When you are happy with the shape of the horns, you need to leave the phone overnight so that they cure into a touch silicone rubber.
The best way to make sure that your horns don't deform is to rest your phone upside down.
Step 4: Time to Remove the Horns
When you finally manage to exorcise the devil from your phone, you will need to remove the horns.
1: Cut the bulk of the horn off.
2: Using the back of your finger nail, scrape away the remaining sugru
3: Use a dry piece of tissue paper to remove the remaining residue
Once finished, it's probably wise to apologise to everyone you called while possessed by the devil, I'm sure they will understand...
Halloween Props Challenge
Pocket-Sized Contest
