Dexter Blood Slide Suckers: Eat At Your Own Risk!
 by Forkable
Contest WinnerFeatured
The more real something is, the more scary.  Ghosts; not really.  Serial killers, biohazards, chemical warfare: Hell ya.  I'm freaked out just thinking about it.
When I saw Martha Stewart's lollipops recipe, I thought it was a good idea but BORING! I tried to brainstorm more gruesome fillings but the lollipop idea was just as boring as before.  Then I started thinking of what’s really scary.  Serial killers! I immediately thought of Dexter and his blood slides.
For any of you who aren’t familiar with the show, Dexter is about a serial killer of the same name, who works by day as a forensic analyst for the Miami police department, and by night, cleansing the city of the evil criminals who slip through the cracks of our faulty judicial system.  Every serial killer has to keep his mementos and Dexter’s trophy case, consists of a box of slides, each containing one drop of blood from each victim.
For this years gruesome Halloween treat, I decided to create a trophy case of my own.  Here’s my recipe and directions for Dexter's blood slide suckers.  They're super simple to make and cheap!
Even if you don’t know about the show, blood slides are still gross.  You can tell people they are blood samples infected with Ebola!  Bio-hazards are super scary!
-Forkable Blog
Step 1: Ingredients and Recipe
  • 1 cup sugar
  • 1/3 cup light corn syrup
  • 2 Tbs water
  • red food dye
  • bamboo skewer or tooth pic
Step 2: Bring Sugar Mixture to a Boil
Bring sugar, corn syrup, and 2 Tbs water to a boil in a small saucepan, stirring until sugar is dissolved. Don’t stir, but occasionally wash down sides of pan with a pastry brush dipped in cold water to prevent crystals from forming; boil until mixture turns golden, 5 to 7 minutes.
Step 3: Pour Sugar Out into Sheets
Line a few baking sheets with Silpat nonstick baking mats or parchment paper.
Pour the melted sugar mixture in a line down the center of the pan.  Using a skewer or the flat edge of a large knife, spread sugar into a thin flat sheet.  Glass slides are pretty thin, so the thinner the better.  It will also be easier to cut in the next steps.
Once you have the mixture spread into a flat sheet, let it cool and harden for 5-10 minutes.  Once the mixture is hard, pull it away from the mat or parchment.  If its super thin, try not to crack it.
Step 4: Cut Sheets into Slides
Place the blade of a large knife (not necessarily your best) directly into your burner to heat.  If you have an electric stove, you can use a lighter.  Once the blade is hot, begin to cut your sheets of sugar into strips.  Cut edges to be the length of a real slide.  Its good to have a glass slide to use as a template.
This step can be a bit annoying.  Don’t worry if you break a few, it happens.  Reheat the blade for each cut.  Between each cut, wash your blade off with water to keep the sugar from burning to your blade.  I don’t suggest using your best knife, since this heating and cooling isn’t the best treatment for your chef’s blade.  If the edges are really rough, dip your finger and water and smooth them out.
Lay your cut slides on your baking tray and refrigerate for at least 15 minutes.
Step 5: Paint On Blood Splatter
Take slides out of fridge.  Using a tooth pic or a bamboo skewer, paint on the blood circle in the center.  You don’t need too much.  A small droplet off the tip of your tooth pic will be enough.  If you put too much on, it will run all over the slide and make a huge mess. Refrigerate again until the dye is dry and you’re done!
Step 6: Serve Suckers
Now how do you eat these beautiful bio-hazards.  Its important to protect your fingers from the dangerous objects.  I suggest serving these suckers with a pile of latex gloves.  It provides an easy way to safely eat these treats as well as up the uncomfortable factor.
You can also serve with tweezers.  I took a quick visit to the Science Surplus Store hoping to find a wooden slide box. No luck!  So I just got one of the cheesy slide kits which came with a cardboard box to display the slides at an angle.  Maybe for next year, I’ll try to find a box on ebay or something.
1-40 of 75Next »
kwatanabe1 says: Oct 31, 2012. 1:12 AM
Can i make it with out corn syrup? because there's no corn syrup in every place we go to and if there are its super expensive. can i use something for an alternative?
yallen says: May 17, 2012. 7:23 AM
If you score the candy before it has fully hardened it wlll be much easier to snap or cut into slides when it has set.
snarfnugget says: May 10, 2012. 2:52 AM
AWESOME!!!! Cant wait for Helloween. Thanx for sharing!
grannyjones says: Apr 12, 2012. 10:59 AM
white vanilla
chefsea says: Mar 11, 2012. 4:18 PM
Love this!
vulcan24 says: Jan 21, 2012. 11:35 PM
XD My Mum loves Dexter and when I showed her this she basically had a heart attack because of its awesomeness! XD "OMGNOWAY!!"
kathrynfarmer says: Nov 4, 2011. 2:23 AM
this is so cool, i did a little something different. i shattered the glass and then went crazy with red food dye. it looks like a crime scene. i made a hell of a mess though and my fingers are red.
EcoJym in reply to kathrynfarmerNov 17, 2011. 8:57 PM
I did the same thing! I got so frustrated trying to cut the lines; the candy kept shattering. It was inevitable then I'd end up with "shattered glass." I took it to a Halloween party and received rave reviews. It looked so real people had a tough time actually eating it!
Thanks so much! This is great!
ViktorijaS says: Nov 14, 2011. 3:36 AM
amazing! thank you!
klimb says: Nov 1, 2011. 12:56 AM
Perfect Dexter Blood Slide box - http://www.amazon.com/Showtime-Dexter-Trophy-Case-slides/dp/B004D45734
klimb says: Nov 1, 2011. 12:51 AM
it might help to build a sort of mold for these by sinking skewers into warm candy to divide at least the longest sides while the candy cools.
finfan7 says: Sep 25, 2010. 9:42 PM
I love the idea but don't these taste bad as plain sugar, no flavour?
tweetspie in reply to finfan7Oct 28, 2011. 3:16 PM
Since when does plain sugar taste bad?
Javin007 says: Oct 28, 2011. 10:01 AM
Man, I wish I'd seen this before our work's Halloween dessert contest. Seems like it wouldn't be too hard to make little cake "slide boxes" too.
Stormed Wolf says: Aug 20, 2010. 1:10 PM
can i substitute the parchment paper for wax paper? or is there a specific reason for using the parchment paper?
TheNerdyDuo in reply to Stormed WolfOct 28, 2011. 7:01 AM
Parchment paper is rated for very high temperatures. If you're pouring "hard ball" stage sugar on wax paper, that 250-260 degrees will melt the wax right out of the paper. And then not only will your slides be all full of wax and a funny texture, they'll also be cloudy.
teenhysterics says: Dec 12, 2009. 11:33 AM
Would adding flavor tint the lollipops at all? I was thinking of making them lemon-flavored.... Any tips? Would they stay clear (assuming I filtered out most all of the pulp)?
Forkable (author) in reply to teenhystericsDec 13, 2009. 3:29 PM
I think adding flavor is a great idea.  Not sure how it would work or if it would tint.  Just experiment and let us know your findings!
teenhysterics in reply to ForkableOct 21, 2010. 11:48 AM
So the lemon flavor I used made it taste like dentist lollipops--not ideal! I want to try them again this year with mint. And Ugifer's comment about adding it right before you pour is definitely a good idea.
Also, thanks for the instructable--they were awesome, and some guy from my dad's work remembered him talking about them last year and asked for the recipe. Definitely a memorable project!
TheNerdyDuo in reply to teenhystericsOct 28, 2011. 6:57 AM
Almond extract is colorless and would be unusual. Orange extract is generally colorless too. You can even buy colorless forms of vanilla extract, though they can run a bit pricey. You might try the Wilton aisle at your local craft store for some other color-free flavors. They make a whole bunch of candymaking stuff.
Ugifer in reply to ForkableJul 27, 2010. 4:22 AM
Mint essence is usually colourless. Add it right before you pour or it will boil out. Great idea by the way.
teenhysterics in reply to UgiferOct 21, 2010. 11:44 AM
Thanks for the tip! I wanna try making these again--I tried lemon last year, and they tasted like dentist lollipops. Euch. But I'll definitely go for mint next time.
meichelbrenner says: Oct 27, 2011. 5:55 PM
I made these and followed the directions precisely. But when someone goes to touch these or eat them, they turn into a really hard-to-chew, taffy like sugar glob. What am I doing wrong?
TheNerdyDuo in reply to meichelbrennerOct 28, 2011. 6:54 AM
It sounds like you've only gotten your sugar syrup to the "soft ball" stage. In order to make a snappy crisp candy (like this or peanut brittle), you need to heat the mixture all the way up to the "hard ball" stage. You could get yourself a candy thermometer, or you could keep a glass of water nearby to drop a little bit of the hot mixture into. With where your mixture was, that little drop would be like a little glob of taffy (i think it actually is taffy at that point, just not pulled yet) and the string that's stuck to your spoon would be like the string you get when you're using a hot glue gun, all stretchy and sticking to stuff. You know it's ready when the drop you pull out of the water is like a tiny hard candy and the strings on the spoon are brittle and (after you've let them cool a minute, be careful you don't burn your hands) snap off in your fingers. It will be a clean break and there will be no stretch in it after it's lost its heat.
elliebike9 says: Oct 26, 2011. 7:02 PM
Love Dexter
love you
Awsome creation!!!!!!!!!!!!!!!!!!
very realistic
anibioman says: Oct 22, 2011. 1:45 PM
these are so cool i happen to be a big fan of dexter (proof is in the pic).
lkuziez9680 says: Oct 3, 2011. 5:00 PM
looks very realistic :) !!
platypuser says: Jul 17, 2011. 4:12 PM
all i can say is wow! :)
mary candy says: Nov 8, 2010. 10:38 AM
I love DEXTER
kdickerson_az says: Oct 7, 2010. 3:31 PM
Do you think it would work to score the hardened candy with a sharp knife and crack it along the line? It may be a good option for those of us without gas...
cyndyg in reply to kdickerson_azOct 28, 2010. 4:30 PM
I am trying to cut my "slides" right now. I'm having trouble cutting them and I tried scoring them but it hasn't made a clean break for me. I'm gonna keep trying!
a1periwinkle says: Sep 29, 2010. 11:00 AM
I purchase small flat mirrors from the dollar tree to use for etching. Usually a box at a time. These displays have a styrofoam bottom with slits. Looks just like what you are using.
binaspencer7 says: Sep 28, 2010. 2:51 PM
no i just tryed..lol.. did not work to well
binaspencer7 says: Sep 24, 2010. 7:17 PM
JUST AMAZING thank you so much for shareing, i am going to make some first thing in the morning also the box that you put them in where did you get that or did you make it?
Forkable (author) in reply to binaspencer7Sep 26, 2010. 9:47 PM
It was a box of science slides I got from the Science Surplus Store. I wish I had a wooden box like Dexter has in the show!
krayonc says: Sep 12, 2010. 8:55 AM
I LOVE the Dexter series so I especially liked this instructable. Very cool!
mafer says: Dec 29, 2009. 9:00 AM
Awesome, can it be done without the corn syrup,because I can't find it in my place.
Forkable (author) in reply to maferDec 31, 2009. 11:56 AM
You could try melting sugar down, its worth experimenting.  I think it will be most successful and easy with corn syrup though.  Its pretty cheap and easy to find at any grocery store in the baking isle.
whiskey_14 says: Dec 2, 2009. 5:59 AM
this made my day!
scoochmaroo says: Nov 3, 2009. 8:57 PM
Dang.  Impressive as always!
1-40 of 75Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
