Diamond Pasta in Indian Gravy
528
9
4
Published
Introduction: Diamond Pasta in Indian Gravy
I am from Mumbai, India, and this dish is a traditional comfort dish from the Western part of India.
This vegetarian dish can be enjoyed in spring, fall and winter though we enjoy it year long. To make it vegan, skip the optional ghee or clarified butter. For those with peanut allergy, skip the nuts. For those having gluten issues, try other flours instead of whole wheat flour and skip the asafoetida, as simple as that!
Although the list of ingredients is long, quite a few of them are optional. The spices are available in Indian stores but also at Whole Foods and other supermarkets in USA, in most other countries and online like Amazon website.
Keep in mind, this is a very healthy, nutritional dish that can be eaten as lunch or dinner. It is packed with complete proteins, complex carbs, is high in minerals and vitamins. It is quite easy to digest and filling too. You can always reduce the oil content by half if you so desire. Use coconut oil or olive oil to keep it healthy or any other oil that you have at home.
My kids enjoyed it from a very young age, a good way to get my entire family (young and old) to eat their beans and vegetables. It's fragrant, complex, and exotic (for the non-Indians), but easy to make. Yum!
This is my first entry, so please feel free to advice. I appreciate your vote. :)
Step 1: Ingredients:
For the Dough:
  • 5 cups whole wheat flour
  • 1 Tbsp oil
  • 2 tsp salt (to taste)
  • 1 tsp turmeric powder
  • 1 tsp red chili powder
  • 1 tsp coriander-cumin powder (dhanajeera)
  • 3-4 cups of water (approx)
For the gravy/sauce:
  • 2 cups yellow split peas or dal (cooked)
  • Vegetables of your choice:
    • 1 medium carrot (chopped)
    • 1 medium tomato (chopped)
    • 1/2 small onion (chopped)
    • 3-4 cauliflower florets
    • 1 Tbsp green peas (fresh/frozen)
    • 1/4 cup spinach leaves (chopped)
  • 3-5 Tbsp jaggery or molasses (to taste)
  • 2" peeled ginger (minced)
  • 3 tsp salt (to taste)
  • 1 tsp red chili powder (to taste)
  • 1 tsp coriander-cumin powder (dhana-jeera)
  • 5-6 cups of water (approx)
  • Optional ingredients:
    • 3 Tbsp peanuts
    • 2 Tbsp cashew nuts
    • 3 Tbsp raisins
    • 2 garlic cloves, crushed
    • 2 kokam petals
    • 1 stick cinnamon or 1 tsp cinnamon powder
For the Tempering:
  • 1 Tbsp oil
  • 1/4 tsp black mustard seeds
  • 1/4 tsp cumin seeds
  • 1/4 tsp asafaetida or hing (optional)
  • 1 sprig fresh curry leaves
  • 1-2 fresh green chilies (as per taste)
  • 1 dried red chili (optional)
  • 2-3 cloves (optional)
For Garnish:
  • 8-10 sprigs of cilantro (chopped)
  • 1/2 lemon/lime juice (freshly squeezed)
  • 1 tsp ghee or clarified butter (optional)
Step 2: Prepare the Pasta Dough
Method:
1. Sieve the whole wheat flour.
2. Add all the dry ingredients.
3. Add oil and mix well.
4. Knead the dough with water. Depending on the altitude and climate, you will have to adjust the water added.
5. The dough should be pliable enough that you can roll it out. Lightly rub a drop of oil on the surface.
6. Cover in a container or use saran wrap. Keep aside to allow the gluten to make the dough pliable.
Note:
I kneaded the dough by hand but you can use the food processor. Use the correct blades and dough setting as per your food processor.
Step 3: Tempering
Method:
1. Heat oil in a big pot (preferably non-stick to keep oil content low) for tempering.
2. When the oil is hot, add mustard seeds.
3. Once they splutter, ingredients of tempering are added in quick succession.
Note:
Tempering is typically done at the beginning of cooking, before adding the other ingredients to liberate essential oils from cells and thus enhancing their flavors.
Seasoning and spices are an essential component of Indian cooking, adding a subtle aroma to simple dishes and complexity to highly spiced ones. Fresh green and/or dried red chilies provide the heat, but can be omitted from the dish or later removed if you don't like it hot.
Curry leaves are an herb native to South Asia, unrelated to the ground spice mix called curry powder. Once cooked, curry leaves though edible, most people simply push them aside on the plate.They are often available fresh at Indian markets, and freeze well—no need to defrost before cooking with them. Avoid dried curry leaves, which have no flavor or aroma. If you just cannot find them, omit them. It will still taste great.
Asafoetida has a pungent smell but in cooked dishes, it delivers a smooth flavor reminiscent of leeks.
Step 4: Make the Gravy/Sauce
Method:
1. Add all the ingredients for the gravy to the pot right away. Be careful of the hot oil and try not splash.
2. Boil and simmer for 15 minutes or until all the vegetables are thoroughly cooked and tender.
3. Adjust salt and spices as per to your taste.
4. Adjust water level. At this point the gravy seems watery. Once you add pasta, it will thicken.
Note:
I cooked the yellow split peas in the pressure cooker which is quick and easy, If you do not own a pressure cooker, you can boil yellow split peas immersed in water on a stove top until it is completely tender and breaks down into one homogeneous mass.
Turmeric and ginger are known for their anti-inflammatory properties. Ginger and asafoetida make this stew easy to digest.
Step 5: Make the Pasta
Method:
1. Make balls of dough.
2. Roll the balls to make 10-14" rounds approx. The rolled dough should be quite thin and translucent. (200 mm. thick)
3. Cut it into diamond shapes with a pizza cutter or sharp knife.
Note:
I rolled the pasta using a rolling pin but you may try it using the pasta machine. I don't own one but believe that you may need to pass the dough through it only once. Make sure to dust it with flour so that it does not stick to the pasta machine.
If the circle or diamonds are not perfect, you can use cookie cutters or mason jar lids, so don't be scared to try it out.
If you find it hard to cut shapes, keep the rolled dough for 15 minutes aside before you begin cutting.
Step 6: Add the Pasta to the Gravy
Method:
1. Drop the pasta one by one into the boiling gravy. Stir often.
2. Simmer for 5-10 minutes. The pasta will cook quickly and thicken the gravy.
3. Garnish with chopped cilantro and squeeze some lemon/lime juice. Top with dollop of ghee, if desired.
Serve piping hot in soup bowls with poppadoms. Some like to serve it with basmati rice.
Note:
If it is hard to pick up the rolled pasta, stick them in the refrigerator or keep aside for 15-20 minutes.
The uncooked pasta can be stored in freezer bags for later use.
Leftovers can be refrigerated for a day or two. Reheat, adjust water and seasonings as needed.
    • Flowers Challenge
      Flowers Challenge
    • Slow Cooker Challenge
    4 Comments
    This looks terrific! Thank you! I know the servings would depend on how you serve it and individual preferences but can you tell me about how much it makes? I live alone and am wondering how much I would have to freeze. Thanks, Cyndie
    Thank you Cyndie. I make this for my family of four ( my husband, my two teenagers and myself). The portions are large as it is usually our one-pot dinner. It can easily accommodate last minute guest, if needed.
    I would suggest to cut the ingredients by half and refrigerate the leftovers. If you make really small quantities, it maybe hard. for example, not enough dough to knead. Just my 2 cents.
    For the first time you make, make a small batch in step 6 - add pasta to gravy, season accordingly. Serve hot. If you like it, from next time onward you can make all of it. If you do not like it (not likely to happen), then the gravy can be consumed like a soup by reducing the water content slightly. The pasta dough can then be made into tortilla. Nothing goes to waste in my house. :)
    Thanks.
    Jayshree
    Thank you. I hope you try making it as it is not available in any restaurants, even in India!
