Step 7Final Assembly
This last part consists of putting it all together and adding some finishing touches.
Wire the lid. The DC power and line-in go straight to the amp board. Make sure there is enough slack in the wires so that it doesn't bind as the lid opens and closes. Wire up the speakers. Pay attention to the left and right channels. Install the volume potentiometer.
The volume knob is from a knob from an old pot cover. It was shortened and bored out 1/4 inch bit to fit the pot shaft. Use hot glue to attach the knob to the shaft.
Next make the name plates. The nameplates are printed clear labels on 0.025 inch aluminum sheet. The plates are a chance to personalize the box. Attach the plates with Crazy Glue.
The V-emblem fills empty space on the grill. It is made from 1/2 inch angle aluminum. Using a hack saw, cut two pieces of aluminum at an angle. Using a file and or belt sander, finish them so they form a V-shape. Use masking tape to temporarily attach the two ends together. To permanently attach the two ends together take a piece of wire and form it so it fits inside the V-emblem. Place the emblem so that it sits level. Mix up some 5-Minute epoxy. Fill up the V-emblem with the epoxy. Let it sit over night. File and/or sand the emblem. Give the emblem a texture by lightly sanding the surface. Hot glue the emblem to the speaker grill.
The final touch is to age the box. Start by brushing black enamel in the edges and crevices.
It is okay to get messy. Next take paint thinner to remove and blend the black enamel to simulate grease.
Repeat until happy with the look.
Don't like the buzz? During the final assembly, I found that the DC power transformer was "emitting" a 60Hz buzz. Rather than build a notch filter, http://members.shaw.ca/roma/nine.html I decided to leave it. Another option is to run the amp from batteries. Use a 6 AA battery holder and connect up the 9V battery clip and DC Power Plug. Use this set up instead of the power transformer to eliminate the buzz.
Congratulations! You finished! :) Thanks for viewing my Instructable. I hope this project stirs up the creative juices for other Makers!
With a 470uf elect. cap tied to the input and ground ( + to input , left pin , - to ground middle pin )
0.1uf ceramic cap tied to output and ground .
Sorry for my explanation was a complete mistake, I should be wrote (sorry for my english)
"separate the "line in" female plug, to aislate the common earth from the audio in", this should solve your problem, no need to open your power suply,
test it only desoldering :-)
sorry again, hope you´ll be not to lazy to do that, to see what happens
Kindly
cheers
