Please look up the definition of a Diffusion Vacuum Pump before continuing!
This pump is made from readily available materials and has been shown to achieve a .022 TORR vacuum!!!!
Use extreme caution when working with vacuum
This pump needs a "Roughing" pump to get down to a near vacuum then it will work as described.
No a refrigerator compressor will not work as a "Roughing" Pump for this
No a vacuum cleaner will not work either!
You will need a refrigeration service type pump for the "Roughing" of the vacuum.
Yes you may have to go to IKEA to get some of the parts!
Step 1: Materials
You will need a stainless steel tube (I used an exhaust pipe section)
Some 1/4 inch copper tube and
stainless steel flat sections.
I found that the local scrap yard had lots of stainless steel parts. Selecting the right few took a couple of trips.
You will also need to know how to braze. I used stainless brazing rod for joining all parts.
I used a stainless 2.75 od exhaust pipe adapter for the body. Some scrap stainless flats for the ends.
All cutting was done with a Dremel and cut-off abrasive wheel.
Several Ikea stainless cups were sacrificed for this build!
eelco_g says: Jan 27, 2013. 9:35 AM
I'm a bit lost. Some background, a working principle and a schematic would make this a great instructable. Also, could you explain a bit more about the construction? For example in step 6, where does the copper coil come from? It's just there all of a sudden without explanation. Thanks.
Random_Canadian (author) says: Feb 21, 2013. 10:59 AM
Sorry about that. I got in the zone with the build. The copper tube is a gravity feed cooling apparatus. Wrap 3-4 coils of copper tube around the body of the pump. Braze this tot he body. Water is gravity fed in a steady drip to facilitate cooling of the pump body and allow the pump to cool the heated oil.
gcr100 says: Sep 13, 2012. 8:19 PM
You win a follower with this pump i am making my own but i have a question can i use 2 fridge compresors in series as a mechanical pum i know that the ideal pump is the rotary vanes one, but here in Mexico they are really expensive i know that one can get a vacuum of 100mbar
rimar2000 says: Apr 16, 2012. 9:44 AM
Awesome project!
Surely you can aluminize using this vaccum pump, isn't?
Random_Canadian (author) says: Apr 16, 2012. 9:48 AM
Thanks!
That is definitely one of the plans!
rimar2000 says: Apr 17, 2012. 5:16 AM
I envy you a bit... Is there something like good envy?
omnibot says: Apr 21, 2012. 9:18 AM
Yep, called "admiration" and "inspiration".
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
