Digger 2.0 - Childrens Toy
8,393
130
9
Published
Introduction: Digger 2.0 - Childrens Toy
Edit: If you like my instructable please vote for it to win the 3D printing contest using the vote link at the top right of screen.
I designed this model from scratch using Fusion360 the software allowed me to test all the moving parts for correct functionality before printing.
The Digger's arm and bucket can rotate 360 degrees the arm or boom moves up and down with the left lever while the bucket moves in and out with the right lever.
The mechanical movement is achieved through some basic linkages and pivot points.
The entire model is made on a 3D printer and requires no additional hardware to assemble.
To assemble you will require the following:
Super glue
Some bulldog clips or clothes pegs to use as clamps
Some sand paper
Some needle nose pliers
Step 1: Print All the Components to Make the Toy
Using your chosen 3D printing software open each STL file. The Components are all orientated for best printing. Only the bucket requires supports to print.
I made this toy using a PrintrBot simple metal with a 0.4mm nozzle sliced in Simplify3D using 0.1mm resolution, 50% infill.
Once you have all your parts printed and cleaned up to your liking assembly is fairly straight forward.
Tip: the supportmaterial in the bucket can be removed by snapping it out with some needle nose pliers, and the parts smoothed with some sandpaper.
The parts should just press fit together but a small amount of super glue is recommended to give the model some strength.
Step 2: Assemble the Base
Starting with the base. take the 3 feet and press them into the 3 holes on the outriggers.
Then take the ring and press it on to the top of the base.
if needed a drop of glue between the parts can be used to ensure they stay together.
Step 3: Arrange the Pegs for Assembly
Arrange your pegs ready for assembly there are:
3x 12mm male and female.
4x 8mm male and female.
1x 8mm male
1x 11mm large male (no hole down the middle)
If using super glue having a number of bulldog clips at the ready will help clamp parts to gather while the glue sets.
Step 4: Assemble the Bucket and Forward Boom
starting with the bucket assemble the forward-boom to the bucket using 12mm male and female pegs.
Step 5: Boom Arm
Assemble Boom arm and 90 degree linkage with 8mm male peg
Step 6: Short Linkage
Assemble short linkage with 8mm pegs in the top hole and 12mm pegs in the bottom hole
Step 7: Long Linkage
Assemble long Linkage with 8mm pegs
Step 8: Bucket Control
Assemble bucket control with 8mm pegs
Step 9: Attach Boom and Bucket to Main Pivot
attach the bucket and boom assembly to the Base-pivot using the 11mm large male peg (no hole down the middle).
This will be a very tight fit.
Step 10: Boom Control
Assemble the boom control using 8mm pegs at the bucket end and 12mm pegs at the base end.
Step 11: Combine Upper and Lower Assemblies
Insert what you have assembled into the top of the base assembly
Step 12: You Have Completed the Assembly
Manipulate all the joints to free them up, they may be stiff to begin with but with movement they will begin to move much easier.
3D Printing Contest 2016
Runner Up in the
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    9 Comments
    I LOVE IT SO COOL
    OMG! I loved playing with this at the playground! Nice job :)
    Nice job creating this. I don't really have a 3D printer but would want one.
    Nice job my boys would love this
    This would be great to have in the middle of a candy dish.
    well designed toy
    Very nice toy digger!!! Love it! Take my vote and thanks for sharing.
    Greetings from Spain!
