Water-Resistant, Upcycled Camcorder Case
 by susanrm
Featured
Step 3: Add the padded pouch
Place the camera inside the padded pouch. Draw a rectangle on the front a bit larger than the lens will need. Do the same on the back for the LCD screen, or make it large enough to see the controls as well. I found seeing the LCD screen was adequate, as I could feel the buttons through the case.
Trace the rectangles you made onto the inside of the pouch. I moved my front rectangle over a little to center it better.
The last photo in this step shows a mistake I made. I thought my pouch was too big, so I cut a bit off the side. It turned out I needed that bit to compensate for the extra width needed when the lens was extended, so I had to make up for it in the next steps.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
