Digispark Attiny 85 With Arduino IDE
Published
Introduction: Digispark Attiny 85 With Arduino IDE
About: I am an engineering student and i just love doing electronic (mcu's) and programming (C,C++,JAVA) based projects.
Digispark is a microcontroller board which has ATTINY 85 MCU as its heart and running with 16.5Mhz frequency with 8KB of memory and have 5 GPIO pins, this MCU board is cheapest and smallest Arduino Board available in the market good for wearables and small projects.
Step 1: Get the Board
so first of all you need to buy a Digispark board and the affiliate links are in description:-
https://www.banggood.com/Digispark-Kickstarter-Mic...
https://www.banggood.com/3Pcs-Digispark-Kickstarte...
Step 2: Install Boards
first of all open Arduino ide and then go to preferences and then in additional board magae url paste this given url for Digispark :-
http://digistump.com/package_digistump_index.json
Now go to boards manager and download the Digispark boards.
Step 3: Programming Board
select the given settings
Board- Digispark Default 16.5mhz
Programmer - micronucleus
And hit upload button and you'll get a message at very bottom on arduino ide to plug the device within 60 sec then plug the device and if everything worked fine then you'll get a message micronucleus done thank you that means code has been uploaded and your led will start blinking.
Refer video if having problem.
Thank you
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
