Step 3Measure & Cut Wood
I did all the cutting with an inexpensive electric jigsaw. For tricky areas, I used a drill to put a hole in the middle of the wood, then inserted the jigsaw bit and started cutting from there.
Feel free to design the box as you like. Mine had 5 pieces:
1) Base. I designed the base with a cut-out to hold the Loreo lens.
2&3) Left & Right sides. I added curves to make it pretty. I used the base of a lamp make the curves clean.
4) Frame. This is what holds the Digital Photo Frame.
5) Foot Rest. A little strip of scrap glued to the bottom to angle the box upwards when resting on a table.
Add Comment
