Step 2Observe the edges
On the other hand--on the other (larger) end--there is not enough of a bevel for the Lumix: when I first mounted it, there was slight vignetting (the hood was just the slightest bit too small in diameter at the edge). I solved this by grinding / sanding away the inside edge of the large opening of the hood ... that did the trick, eliminating the vignetting.
The next couple steps show the sanding operations.
Add Comment
