Digital Clock From Scratch Using LEDs and 89C51
Published
Introduction: Digital Clock From Scratch Using LEDs and 89C51
About: Robotics is an art and I'm artist :)
Digital Clock using LED’s and 89C51 from scratch
In this Instructable, I will show you how to make Microcontroller Based Digital Clock using LED’s and Atmel 89C51 from scratch.
Its an Alarm clock and also indicates the PM and AM times LED.
Step 1: ​Step 1: What You Will Need
Components we need are
121 LED’s
1 Atmel 89C51
1 40 pin IC base
1 LM 7805
2 20pin SIL connectors (male and female)
1 vero board
117 Resistance 330 ohm
4 Buttons
1 switch
1 usb cable
1 power bank (optional)
1 paper box
1 white paper
1 needle
1 Buzzer(optional)
1 16 Mhz crystal oscillator
2 33pF capacitors
Step 2: ​Step 2: Initial Start
First of all you need the 8 Segment Design for that I use the proteus to design the 8 segment and got a print of that. After printing the segments use hard paper and attach the white segmented paper upon it using gum. Make holes on the LED footprint of all segments just like in the picture below.
Step 3: ​Step 3: Placing and Soldering LED’s
After making the holes place LED’s always remember to note the terminals of LED’s.
Step 4: ​Step 4: Making the Controller Board Circuit
First Cut a Piece of vero board . Attach components to Board . I use 40 pin IC base so that it could be easily programmed and place to the board.Use the schematic diagram to implement the circuit. I have not the alarm but you can use it. And also set the am and pm time LED’s indications. Attach the wires to the LED panel and use the SIL connectors of 20 pins for each sides.
Step 5: ​Step 5: Switch Board
Cut the small piece of vero Board . place 4 push buttons for the time and alarm.
Step 6: ​Step 6: Programming the 89C51
Now time to give a life to the Clock yeh! Its programming time.open the code in keil and make the HEX file after that burn that HEX file into the 89C51.
Step 7: ​Step 7: Case the Clock
Last step is to case the whole into a plastic box as shawn in figure. All Done must Comment thanks alot for your views.Video Will show how its work and look like.
Docx file
Code HEX file.
LED print PDF.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    7 Comments
    Is it common anode or common cathode, sir?
    i liked it. Very good
    sorry i Apologize as it was my first instructuble ...
    its 16 Mhz crystal
    amazing!
    Thank you for sharing :)
