3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital Picture Frame
Adding to the million already in circulation, here is the Digital Picture Frame that I built for about $100.. yes, its expensive for what it is but the coolness factor is high in my opinion.. And on the geek scale, it can't get much better than this.
Here is the summary:
Take an old (really old) laptop apart. Cut a couple pieces of Plexiglas, add a bunch of screws to hold it all in place and then add the laptop parts. What you end up with is seen below.
Laptop: ($20)
CivilNote, P266 MMX (OMG its MMX), 160mb of ram (32 onboard + 128 upgrade), 10" LCD
Hard Drive: ($20)
5gb CF Microdrive (completely silent)
Touchscreen ($40)
Two relatively small pieces of Plexiglas ($10)
Bunch of screw (depends on the motherboard of the laptop your using) ($1-2)
4 nicer looking screws (I used brass.. all available at a local hardware store)($5)
NOTE: I'm assuming that windows/linux/macOS is already installed on your hard drive and you can boot into it without needing to enter a password.. because it would be kinda strange having to log into a picture frame :)
Step 1Tools needed.
Tools needed.
Obviously you will need small enough tools to take apart the laptop.. Sadly hammers don't have a great effect on laptops.. We'll skip this part as I'm assuming if you are willing to go any further, its because you know how to take things apart...
For building the Picture Frame, I used a small portable screw driver and drill bit.. Photos below.
You can use any screw driver as its only going to be used for mounting the parts.. not a lot of work..
For the drill bit, I would suggest using a 1/4" as I bought 3/16" screws. This can also be changed to your liking.
215 comments
1-40 of 215next »
Oct 17, 2011. 5:59 AMmrussell12 says:
I wonder if you can actually mod this into a tablet, that would be freaking cool, i mean, all you really need is a battery at this stage and say perhaps...ubantu. I am going to look into this.
Apr 26, 2010. 4:21 PMjbird123 says:
Just wondering where you got these 'extention' screws and stuff from stage 3 image 3? Other than that im ready to go!
Apr 13, 2010. 5:08 AMjbird123 says:
Awesome, might do this next time I get my hands on an old laptop. Even if I dont, still a usefull to keep in mind when making a new mini case for my original xbox (media centre in teh lounge :) )
Mar 1, 2010. 1:59 PMCybergeek004 says:
Can you please tell me what slideshow program you used?
Feb 18, 2010. 10:19 AMtdwp1122 says:
 can you add a link to where you got your touch screen from?
Feb 14, 2010. 8:48 PMwee_man says:
Is there any heat issues with running this for hours on end?
Jan 13, 2010. 5:47 AMD4V!D says:
I am in the middle of making this.  I am using a Dell Inspiron 1150.  The display will no longer stay up and the power supply is frayed near the brick and the plastic flexes a lot so it is no longer useful as a laptop.  I am mounting the power supply behind the glass and extending the power cord.  I would rather shorten the power cord and extend the DC power cord but the Dell power supplies are made poorly so I figure it would be best this way.  I will be using spare plexiglass to make a box for the power supply mounted between the frame.  I am also leaving the battery in so I can transport it to the kitchen for recipes without having to reboot.  Thanks for the graet idea.  I was concerned with other projects posted on instructables due to lack of air flow (my Dell doesn't exactly run cool).  I will post pics once I am finished.
Mar 11, 2009. 9:01 AMalexanderbly says:
I just got a copy of windows XP pro, though I haven't had a chance to run it yet. Does it have different install options? How can I install it to take up the least amount of space? Thanks.
Jan 2, 2010. 5:31 PMblurofred says:
try linux, there are several verstions that are really small.
http://www.damnsmalllinux.org/
or
http://www.delilinux.de/
May 22, 2009. 11:50 AMReCreate says:
Windows XP May Be A little Heavy For Old PC's. Windows XP Requires at least 1.3GB of disk space to be happy,You Could Try Windows 95,Visit win3x.org They have it there,Windows 95 Will Be happy with anything larger than 150BM,And IT can Run With as little as 4MB or RAM.
Jul 30, 2009. 7:49 AMzim_256 says:
You could try to install XP Embedded, it's more lightweight than xp pro.
Jul 30, 2009. 9:32 AMReCreate says:
Windows XP Embedded comes only in preinstalled packages for emulators, Like virtual PC. I would recommend MicroXP, Or tinyXP
Jul 31, 2009. 8:30 AMzim_256 says:
XP Embedded is a commercial, modular version of windows XP. It comes in 2 setup cd's + 1 update. It can be installed on any x86 system. Even the ones with little storage or RAM. You can get a reduced installation in about 200 MB.
Jul 31, 2009. 8:45 AMReCreate says:
Really? Anyways, MicroXP is 200MB
Jul 31, 2009. 10:17 AMzim_256 says:
I googled microxp and it looks fine, just a 100MB cd and it uses very little memory, it's already slipstreamed and available on a 99MB CD so it's a drop-in solution, easier than building a runtime image for XPEmbedded. BUT, it's a modified version with uncertain source so i don't really know what i'm installing and using with microXP, ¿what about malware?. With XPE i can select what to install and is a official release, plus, it has advanced features oriented to slimline pc's like little footprint, hibernate once, resume many, integrated "deep freeze" like feature from ms, the possibility to run from ROM saving only changes to other drive (it can be a optical CD drive for example), etc. Microxp is illegal donwloadable software, but considering the licensing fee for XPE, i'ts out of the target of this instructable (The license cost is higher than the best quality digital photo frame.). Anyway, i'm downloading it to test it in my netbook, the 4 gig ssd is a little tiny for a full XP. Right now i'm using XP Performance Edition and i thought that there wasn't any better o slimmer.
Jul 31, 2009. 11:05 AMReCreate says:
Yeah, Some people consider it legal being stripped down so much that it lacks so many features, such as eyecandy themes, Multiple users and such. Windows has been modded in many ways Original XP>TinyXP>MicroXP MicroXP has so far ran every program i have ever wanted it to, it installed in like 5 Minutes.
Apr 10, 2009. 12:03 PMopanocat5 says:
Get Ubuntu! Its smaller and better for small gadgets like this ubuntu.com
May 22, 2009. 11:54 AMReCreate says:
Yeah,I have Had So Many Problems with Linux,I tried So Many Distros On my PC. Ubuntu - Applacations randomly Exit Slax 5XX-6.10 Konqueror Becomes unstable DSL Linux,NOthing Works. Puppy Linux,This One worked the best,On an other PC. Reactos Is probably the Only Free OS that works the Best,Its not Linux Based though. And Windows,IT works like a Charm,The Only Problems i have On them are Problems i know How to Fix,And that arent too bad. And Windows 7,It Beats Ubuntu Big time.
Apr 11, 2009. 10:00 AMopanocat5 says:
Ah, i get you on the size factor but i have never ever had a single problem with ubuntu
Aug 14, 2009. 3:37 AMeiloxcn says:
……Too expensive……
Dec 18, 2009. 4:47 PMTyMan210 says:
Like a bust of Spock?
Dec 26, 2009. 2:48 PMBroom says:
In carbonite?
Dec 11, 2009. 6:45 PMzack247 says:
no offense, but technically, its just a laptop in a different shape
Dec 11, 2009. 11:39 PMAwesome Possum says:
Plus touchscreen.
Jan 2, 2010. 5:13 PMblurofred says:
lol
Jan 7, 2009. 8:07 AMthebigreddude says:
i am not as familar with laptop motherboards, but is the psu built into it or where did the power come from?
Nov 17, 2009. 11:39 AMCyborgGold says:
Depending on the size of the PSU and the components you use, you may be able to mount the brick inside the frame.  WARNING DANGEROUS:  You could also... if you dare... break open the PSU and mount it (guarding for electrical protection mind you) as to take up less space, though I do NOT recommend this, due to the nature of PSUs.
Feb 25, 2009. 11:04 AMnetspec says:
hi - where did you purchase your touchscreen? I can't seem to find one for $40. Thanks.
1-40 of 215next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:micahdear
