3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital Picture Frame
Step 3Parts needed.
Parts needed.
  • last photo ←
From Laptop
- Motherboard +CPU
- RAM
- Hard Drive (Pre-installed OS that can load without password)
- Laptop AC Adapter
- LCD + all related parts (power converter and backlight plug)
Other
- Touchscreen (same size as your LCD); easy to find on ebay.
- PCMCIA Wifi card if its not integrated in your laptop.
- IDE to CF adapter; no need for this if your using the original hard drive.
- Plexiglas 2 pieces(add 2 inches to the height and width of the screen so that you end up with a 1 inch border around the computer); you can get this pre-cut at your hardware store or use a jigsaw to cut it.
- Mounting Screws; some of the screws can be salvaged from the laptop and used for fastening the motherboard to the Plexiglas, if you need more they can be found at most computer stores (future shot, best buy, circuit city)
- 4 mains screws+more that will hold everything together. Again this is something that you will need to determine based on the laptop your using.. Mine were 3 inches long. (see picture)
- Various other items (two sided tape, foam tape, usb extension, wall mounting cable) ALL OPTIONAL and can be changed with whatever you have lying around that you think will do the same job.
22 comments
Apr 26, 2010. 4:21 PMjbird123 says:
Just wondering where you got these 'extention' screws and stuff from stage 3 image 3? Other than that im ready to go!
Mar 11, 2009. 9:01 AMalexanderbly says:
I just got a copy of windows XP pro, though I haven't had a chance to run it yet. Does it have different install options? How can I install it to take up the least amount of space? Thanks.
Jan 2, 2010. 5:31 PMblurofred says:
try linux, there are several verstions that are really small.
http://www.damnsmalllinux.org/
or
http://www.delilinux.de/
May 22, 2009. 11:50 AMReCreate says:
Windows XP May Be A little Heavy For Old PC's. Windows XP Requires at least 1.3GB of disk space to be happy,You Could Try Windows 95,Visit win3x.org They have it there,Windows 95 Will Be happy with anything larger than 150BM,And IT can Run With as little as 4MB or RAM.
Jul 30, 2009. 7:49 AMzim_256 says:
You could try to install XP Embedded, it's more lightweight than xp pro.
Jul 30, 2009. 9:32 AMReCreate says:
Windows XP Embedded comes only in preinstalled packages for emulators, Like virtual PC. I would recommend MicroXP, Or tinyXP
Jul 31, 2009. 8:30 AMzim_256 says:
XP Embedded is a commercial, modular version of windows XP. It comes in 2 setup cd's + 1 update. It can be installed on any x86 system. Even the ones with little storage or RAM. You can get a reduced installation in about 200 MB.
Jul 31, 2009. 8:45 AMReCreate says:
Really? Anyways, MicroXP is 200MB
Jul 31, 2009. 10:17 AMzim_256 says:
I googled microxp and it looks fine, just a 100MB cd and it uses very little memory, it's already slipstreamed and available on a 99MB CD so it's a drop-in solution, easier than building a runtime image for XPEmbedded. BUT, it's a modified version with uncertain source so i don't really know what i'm installing and using with microXP, ¿what about malware?. With XPE i can select what to install and is a official release, plus, it has advanced features oriented to slimline pc's like little footprint, hibernate once, resume many, integrated "deep freeze" like feature from ms, the possibility to run from ROM saving only changes to other drive (it can be a optical CD drive for example), etc. Microxp is illegal donwloadable software, but considering the licensing fee for XPE, i'ts out of the target of this instructable (The license cost is higher than the best quality digital photo frame.). Anyway, i'm downloading it to test it in my netbook, the 4 gig ssd is a little tiny for a full XP. Right now i'm using XP Performance Edition and i thought that there wasn't any better o slimmer.
Jul 31, 2009. 11:05 AMReCreate says:
Yeah, Some people consider it legal being stripped down so much that it lacks so many features, such as eyecandy themes, Multiple users and such. Windows has been modded in many ways Original XP>TinyXP>MicroXP MicroXP has so far ran every program i have ever wanted it to, it installed in like 5 Minutes.
Apr 10, 2009. 12:03 PMopanocat5 says:
Get Ubuntu! Its smaller and better for small gadgets like this ubuntu.com
May 22, 2009. 11:54 AMReCreate says:
Yeah,I have Had So Many Problems with Linux,I tried So Many Distros On my PC. Ubuntu - Applacations randomly Exit Slax 5XX-6.10 Konqueror Becomes unstable DSL Linux,NOthing Works. Puppy Linux,This One worked the best,On an other PC. Reactos Is probably the Only Free OS that works the Best,Its not Linux Based though. And Windows,IT works like a Charm,The Only Problems i have On them are Problems i know How to Fix,And that arent too bad. And Windows 7,It Beats Ubuntu Big time.
Apr 11, 2009. 10:00 AMopanocat5 says:
Ah, i get you on the size factor but i have never ever had a single problem with ubuntu
Oct 18, 2009. 10:07 PMareffera says:
i have problem to download pdf files digitall picture frame
Oct 18, 2009. 1:36 PMareffera says:
I NEED
Map electronic circuit digital photo frame PLEASE
Jun 16, 2009. 6:31 PMvinnnie says:
if i select an embedded system instead an CivilNote laptop?because i want a not-shutdown photo frame? I want to build an digital photo frame but i heard that programming a PIC is much better I dont know, Can you give me a recommendation? Thanks
Jun 22, 2009. 7:30 AMchilll2009 says:
PIC is kind-of boring to program. I'd do a digital picture frame with movies too.
Jun 18, 2009. 12:13 PMvinnnie says:
Yes, I want to build a digital photo frame but a dont like to use a Motherboard +CPU, but i want to use an embedded system (purchased) like an cpu, with this system i will to program extra instructions for management the photos, and i want that my digital photo frame always be on (never goes out). Cheers
Mar 10, 2009. 12:52 PMalexanderbly says:
ah, I see. Doesn't XP take up most of the space on that 5 gb drive? That doesn't really leave much space for other files & media. Have you added a larger drive or something since?
Mar 10, 2009. 12:08 AMalexanderbly says:
Is the CF drive you used any different from a CF card? I have a high capacity CF card that I normally use for cameras that I would like to use for this project. thanks.
Jan 1, 2009. 8:10 PMkdcsatx says:
for the touchscreen, what ecactly is is that you used?....was it like a film that cover the screen? waht was the brand you used
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:micahdear
