3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital Picture Frame
Step 6Mounting the Motherboard
1. Center the motherboard on the 2nd piece of Plexiglas and use a permanent marker to mark where to drill the holes that will be needed to mount it into place. Make sure the motherboard is positioned in a way that it is aligned with the LCD attachment. See photo below.
2. Drill the holes
4. Mount hard drive, RAM and any other part that can be mounted to the motherboard. Make sure everything is securely in position before mounting the motherboard as getting to these items afterward can be complicated.
3. Mount the motherboard and all needed or related items. I had speakers that were in the laptop that I also mounted above the motherboard. I used double sided tape to mount the speakers.
- Use at least 4 points so that the motherboard is mounted securely.
- Make sure the motherboard is not touching the Plexiglas as the heat could melt it. Use typical mounting screws. These can usually be salvaged from the laptop. See mounting screws below.
- I used a motherboard that does not require a fan, but make sure to include all original heat dissipation equipment (fan, CPU heat-sink)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:micahdear
