3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital Window Sticker (Arduino Controlled)
Step 2Assemble the BBB Arduino and USB BUB...
Follow the instructions provided by Modern Device to assemble the BBB Arduino.
Instructions: http://moderndevice.com/Docs/BBB_RevE_Instructions03.pdf
When assembling the BBB, remember to use an LM7805 voltage regulator in place of the L4931CZ50LDO.  The smaller voltage regulator might work just fine, but we are pulling quite a bit of current to power up to 768 L.E.D.s.  The optional inductor is not needed for this project. You can follow the instructions on creating a solder bridge if you'd prefer to save the inductor, or if you'd rather not deal with the surface mount component. Nevertheless, it is not difficult to solder and I used it on my board.
If you also purchased the USB-BUB follow the assembly instructions to complete it.
Instructions: http://moderndevice.com/Docs/BUB_instructions.02.pdf
When assembling the USB-BUB, I selected Configuration 2, though in practice I only ever use Configuration 1 (no jumper).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:als_liahona(Andrew L. Sandoval)
I've been writing software since I was in the 6th grade. In recent years I've developed for Blue Coat Systems, what I believe is the most advanced code injection and API hooking engine for Windows ev...
more »
