3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital Window Sticker (Arduino Controlled)
Step 4Assemble the SD-MMC Card Breakout Board
Simply solder a set of header pins to the SD-MMC card breakout board.
Alternatives:
  • Uses wires to connect the SD-MMC card breakout board directly to the printed circuit board in the next step.  Doing so will give you flexibility with where the SD card socket is located in your enclosure.
  • Solder a bare SD card socket to your selected printed circuit board as part of the next step.
Notes:
Only the following pins are used:
  • CS (for SPI access to the SD Card)
  • DI (data input for SPI access to the SD Card)
  • VCC is the 3.3v power source for the card
  • GND is the common ground
  • DO is the data output, which can be connected directly to pin 12 of the Arduino
  • WP is used to detect a missing card.  This will be connected to pin 2 of the Arduino
  • COM needs to be connected to GND
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:als_liahona(Andrew L. Sandoval)
I've been writing software since I was in the 6th grade. In recent years I've developed for Blue Coat Systems, what I believe is the most advanced code injection and API hooking engine for Windows ev...
more »
