3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Digital control of your loudspeakers
If your desktop pc's soundcard is connected to an external amplifier, and you are tired of un/plugging it and switching it on/off, you're going to love this instructable.
Step 1Mounting your amplifier and loudspeaker
I have a Desktop PC that I salvaged from the junk and on which I replaced the motherboard with one I got from my brother.
It is an AMD 1.2 GHz processor with 256 MB and 8 GB HD. The cabinet is an old Compaq Prolinea 4/25s that had a 486SX on it.
It took some effort to adapt the newer motherboard, but now it works. I recently bought a loudspeaker at a fleamarket for 1 US$.
I did't like the fact that I had to plug/ unplug turn On/Off the thing every time I wanted to watch DVD or videos I dowloaded from Youtube
So I thought of installing the amplifier board and speaker inside the cabinet, but then I had to drill more holes for the On/Off switch.
So why not having a virtual control under XP to turn On/Off the amp, so I could use my headphones at night or my speaker during day?
On most motherboards that have a soundcard in them, there are some where a group of pins or terminals where the audio IN/OUT can be obtain. I just played some music an used the input of the amplifier to detect the pins that had the audio signal on. You may also google the web for your own make and model and download the layout to connect your amplier input to the right pins.
So remove the printed circuit board and the speaker from your amplifier and mountem in your pc's cabinet. Make sure the board makes no contact with the metal of it (use somestuff, like plastic spacers) and bolt it.
Then you'll need this:
-A 12 VDC (coil) relay
-A low power NPN transistor (like 2N2222 or BC548)
-A low power diode (Like 1N4148 or 1N4001)
-A 1kOmh - 4.7kOhm low power resitor.
-Some wires
-Solder
-Paste
-Soldering iron
11 comments
Jan 12, 2009. 3:11 PMHycro says:
This is one of the more interesting Instructables I've found on here, now I could turn my sub amp on/off with software on my computer, instead of just hooking a relay to one of the many +12V lines from my power supply in my computer.
Aug 6, 2008. 8:51 AMPadlock says:
Hello, I have a question: Is there a way to create two seperate files, where if you run file1 it sets pinx high, and if you run file2, it sets pinx low? I have no knowledge of vbs, at all. I appreciate the help. I am trying to make a device so that when my computer turns on, it triggers a relay and turns on my external speakers, but when my computer goes off, it turns off the relay and there for turns off my external speakers. So if possible I would need a continuous high, although I could (rather not though) implement it for a momentary high.
Aug 8, 2008. 9:09 AMPadlock says:
*its supposed to be "via" where it says "veiw".
Aug 9, 2008. 5:28 PMPadlock says:
I just don't know the VB. Which is why I came here.
Aug 8, 2008. 4:42 PMPadlock says:
I know batch quite well, I just need to figure out the VB for it. And thats what I was planning to do from the start, too.
Aug 8, 2008. 9:08 AMPadlock says:
When I shutdown my computer, Power is still supplied to my ports, veiw the standby line on my powersupply. So even when my computer is shutdown, the is still power, unless I turn it completely off, which I do not want to do.
Jul 22, 2008. 2:15 PMGjdj3 says:
Nice job. That looks cool and functional (those two things don't go together that often). One suggestion though. Upload the program you wrote so that people who don't program in VB can get it. Other than that though, cool Instructable.
Jul 25, 2008. 9:12 AMGjdj3 says:
Thanks. I'm surprised this instructable didn't get more attention.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:unknownpocketnerd
