Dining Table Top From Hardwood Flooring
Introduction: Dining Table Top From Hardwood Flooring
Step 1:
I used hardwood flooring to make a dining table top. It's 4ft x 6ft. It replaces the 3ft x5ft glass top I had before that was scratched and out dated.
I used 3 1/4 red oak unfinished flooring for the center and outer row and 2 1/4 unfinished maple for the insert.
I used a sheet of OSB plywood to nail everything to but I also glued everything together before nailing it.
Step 2: Tools Needed
Mitre saw
Table saw
16 gauge nailing gun
Tape measure
Belt sander
Utility knife
Flat head screw driver
Step 3:
I started by measuring and cutting the plywood to size.
Then I marked where the maple was going to go around the plywood so I had a starting point for the center of the table.
I then started by nailing the first row of flooring on my marks, and building outward from there making sure the sides lined up.
I used a knife to make the cut side of the table to make sure they were lined up.
I also used a flat head screw driver to tap into the plywood and pull into the already nailed prices to make sure the were all tight.
Step 4:
Once the middle of the top was finished I sanded everything to the same height using a belt sander. I started out with 80 grit paper then went to 120.
I then sanded the maple and the outside row
Step 5:
Once everything was sanded I then stained the center and outside row with espresso color stain.
Step 6:
After everything was dried I assembled the outside two rows of the table.
I used hardwood spline to join three sides of the outside so I could still nail through the tongue of the flooring.
I nailed the maple to the outside and put a mitre on all the corners to picture frame the center of the table.
I then cut off the tongue of the flooring for the outside row.
I mitred the outside row to match the maple.
Step 7:
To finish the table I used oak colonial door casing and stained it to match the table
Step 8:
I finished the table by using polyurethane.
I used minwax gloss polyurethane
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    do you not need to account for wood expansion when trapping the flooring in between the border? Usually when laying flooring you need a 3/4" gap along the wall side. Is this not necessary since the table top is so small?
    Thank you KanPo I am in the flooring trade so I naturally saw that hardwood flooring would work and I knew that it would be durable.
    Wow Tapuck 14 !
    I never thought of using flooring planks for tables. This opens up new possibilities in crafting.
    I have refurbish old doors into tables. Your project is so cool.
